RME ADI-2 FS Balanced ADC DAC Headphone Amplfier SPDIF ADAT AES/EBU SteadyClock FS 24Bit 192kHz
The RME ADI-2 FS is a compact and extremely flexible 2-channel ADC/DAC converter. Despite its small size, the unit allows high quality conversion to and from SPDIF, AES and ADAT up to 192kHz. Its ability to use these 3 formats gives the ADI-2 FS more than complete compatibility!
By buying this product you get 74 loyalty points
Reference : 14311
749,00 €tax incl.
624,17 € tax excl.
RME ADI-2 FS
RME ADI-2 FS ADC DAC Symétrique Amplificateur Casque SPDIF ADAT AES/EBU SteadyClock FS 24Bit 192kHz
Highlights
Balanced analog inputs and outputs, monitoring via headphone output, SteadyClock FS for optimal conversion quality, 3-level hardware I/O level control and D-D and A-A modes make the ADI-2 FS a complete and versatile unit. Its professional level sound reproduction quality also allows it to work as an extension of other converters.
The ADI-2 FS is equipped with two servo-balanced analog line inputs on XLR and 6.35mm jack combo connectors, one XLR output, one 6.35mm jack output and an amplified headphone output also on the front panel 6.35mm jack connector. The digital stage integrates an ADAT-compatible optical input and output and an AES/EBU-compatible coaxial input and output. This rich connectivity allows the ADI-2 FS to be integrated into the majority of systems.
The analog inputs use the advanced circuit architecture of the ADI-2 Pro, offering low noise and distortion as well as an extended frequency response. Three different settings for the input/output stages allow full compatibility.
The RME ADI-2 FS also uses the SteadyClock FS clock technology allowing a significant reduction of jitter, guaranteeing exceptional sound quality.
For its conversion stage, the ADI-2 FS also uses the technology of the ADI-2 Pro with an AKM ADC from the AK557x range and an AK4490 DAC, supporting sampling rates of up to 192kHz and allowing a wide limitation of distortion while offering a dynamic range of 120dBA.
While the device is particularly comprehensive, it also benefits from clear markings, intuitive function buttons and numerous LED indicators that make it easy to use and quick to get to grips with.
High Power² Headphone output
The ADI-2 FS uses a slightly reduced version of the Extreme Power output stage of the ADI-2 Pro. With a power of up to 0.7W per channel, an output impedance of 0.1Ω, a maximum output level of +19dBu and a very low THD of -110dB, the High Power² circuit will work with any headphones.
Power supply
Power is supplied by an external AC adapter with lockable connector. Thanks to a wide operating voltage range from 9 to 15V, the ADI-2 FS can also be powered by a battery for mobile use.
Product typeDAC
ADC
Analog inputsJack 6.35mm TRS or XLR
Digital I/O (AES / ADAT / SPDIF)Coaxial
Optical
Analog outputsJack 6.35mm
XLR
1x Jack 6.35mm headphone output
Analog inputs
InputsXLR or Jack 6.35mm TRS (electronically balanced)
SNR (@ +19dBu)117dB RMS unweighted, 121dBA
Frequency response5Hz - 20.5kHz @ 44.1kHz, -0.1dB
3Hz - 45.5kHz @ 96kHz, -0.5dB
2Hz - 92.7kHz @ 192kHz, -1dB
THD (@ -1dBFS)-114dB, 0.00015%
THD+N (@ -1dBFS)-112dB, 0.00025%
Channel separation> 110dB
Max input level+19dBu
Input impedanceBalanced: 36kΩ
Unbalanced : 18kΩ
Switchable input sensitivity+4dBu, +13dBu, +19dBu, @0dBFS
Analog outputs
OutputsBalanced XLR
Balanced / Single-ended Jack 6.35mm TRS
Frequency response10Hz - 20.2kHz @ 44.1kHz, -0.1dB
5Hz - 44.9kHz @ 96kHz, -0.5dB
3Hz - 88kHz @ 192kHz, -1dB
THD@ -1dBFS : -112dB, 0.00025%
@-3dBFS : -116dB, 0.00016%
THD+N (@ -1dBFS)-110dB, 0.00032%
Max output level+19dBu
Output impedanceBalanced XLR :150Ω
Single-ended TS : 100Ω
Switchable output sensitivity+4dBu, +13dBu, +19dBu, @0dBFS
Headphone output
OutputJack 6.35mm TRS single-ended
Output impedance0.1Ω
Output level (@ 0dBFS, charge >= 100Ω)+19dBu (6.9Vrms)
Max power (load 32Ω)0.7W per channel (0.01% THD, +16dBu, 4.9Vrms)
THD (load 32Ω @ +15dBu)-110dB, 0.0003%
ANA MODE (Analog input to analog output)
SNR@ +19dBu : 123dB RMS unweighted, 126dBA
@ +13dBu : 119dB RMS unweighted, 122dBA
@ +4dBu : 112dB RMS unweighted, 115dBA
Frequency response (@ -0.5dB)1Hz- 120kHz
THD+N (@ +19dBu)-116dB, 0.00016%
Channel separation> 120dB
Max I/O level+22dBu
Digital stage
ClocksInternal, ADAT In, SPDIF In
Jitter suppression of external clocks> 50dB (2.4kHz)
Effective clock jitter influence on AD and DA conversionNear 0
Supported sample rates with external clocking (SPDIF)28kHz - 200kHz
Supported sample rates with external clocking (ADAT)40kHz - 49kHz
Internal clocks32kHz, 44.1kHz, 48kHz, 64kHz, 88.2kHz, 96kHz, 176.8kHz, 192kHz
Other featuresPLL ensures zero dropout, even at more than 100ns jitter
Digital Bitclock PLL for trouble-free varispeed ADAT operation
I/O formatOptical (Toslink, ADAT)
RCA (SPDIF, AES/EBU)
RCA input level< 0.2Vpp
ADATStandard 8 channels : 24bit 48kHz
Double speed (S/MUX) 4 channels : 24bit 96kHz
Quad speed (S/MUX4) 2 channels : 24bit 192kHz
Power supply9 - 15VDC 9W (included power supply)
Consumption5.2W (430mA @ 12V)
Max consumption10W (830mA @ 12V)
Dimensions (LxPxH)215 x 130 x 44mm
Weight900g
Case materialAluminium
ColorBlack and silver
Package1x RME ADI-2 FS
1x Power supply
InputXLR
InputJack 6.35mm
OutputJack 6.35mm
OutputOptical Toslink
OutputCoaxial SPDIF
ColorSilver
ClassN/A
The RME ADI-2 FS is a compact and extremely flexible 2-channel ADC/DAC converter. Despite its small size, the unit allows high quality conversion...
