There is recognition problem with USB input, one must restart player after input change..
Sabaj provide me new fw, after flashing only USB working..
I have no complaints about the sound..
This product has been replaced by the Sabaj A20D 2023.
DAC ES9038Pro Headphone Amplifier TPA6120A2 XMOS Bluetooth 5.0 32bit 768kHz DSD512 MQA
The Sabaj A20d DAC is back in an improved and redesigned 2022 version. Its digital/analog conversion stage is based on an ESS ES9038Pro DAC chip, a high-end DAC supporting high sampling rates and ensuring an incredibly accurate reproduction. Particularly complete, the A20d is also equipped with a large panel of connectors with notably an I2S input and a balanced output. This 2022 version also integrates a headphone amplifier stage with balanced and unbalanced outputs. The DAC also benefits from a Bluetooth 5.0 connectivity, allowing to transmit its music wirelessly from a smartphone or a tablet.
At the heart of the A20d 2022 is the ESS ES9038Pro 32bit DAC chip with HyperStream III architecture, the brand's top-of-the-line model, ensuring excellent sound performance with very low distortion and noise. This chip also supports high sampling rates, up to PCM 32bit 768kHz, DSD512 and even MQA. This ES9038Pro chip is directly associated with its own LDO ES9311 regulator, providing a clean and stable electrical signal.
MQA (Master Quality Authenticated) is an award-winning British technology that restores the sound of the original recording. The MQA Master file is authenticated by the artists, producers or rights holders. These files are light enough to stream or download.
The A20d 2022 incorporates an MQA decoder to read these files in order to provide the best possible audio quality. It also supports the MQA-CD format.
The Sabaj A20d 2022 integrates a Bluetooth 5.0 receiver from Qualcomm, allowing you to broadcast your music remotely, from a smartphone for example. The embedded receiver chip also supports the aptX, aptX HD and LDAC transmission codecs, ensuring excellent sound quality and transmission stability.
Despite its compact form factor, the A20d 2022 offers a complete connectivity that will allow an easy integration within the vast majority of audio systems. We find in input USB-C, Coaxial, Optical Toslink and Bluetooth 5.0 connectivity. For the outputs, the Sabaj DAC offers unbalanced stereo RCA or balanced stereo XLR as well as two headphone outputs, unbalanced Jack 6.35mm and balanced Jack 4.4mm.
DPLL is used to eliminate clock jitter. The DPLL value defines the bandwidth of the clock lock. The wider the bandwidth, the easier the locking. The narrower the bandwidth, the more effective the jitter removal.
Some sources (like some TVs for example) have a too high clock jitter, which can cause an inability of the PLL chip to perform its locking, resulting in a jerky sound. Increasing the DPLL can then correct this problem.
The A20d 2022 benefits from a balanced headphone amplifier circuit with a TI TPA6120A2 chip, offering a wide frequency range and a low noise level. The output distortion is only -120dB and a gain control (high = +8dB / low = 0dB) allows the Sabaj A20d 2022 to adapt to a large majority of headphones on the market.
The Sabaj A20d 2022's circuitry uses high quality audio components for a rich and accurate reproduction. It includes a second generation 16-core XMOS XU216 USB interface, supporting high sampling rates up to PCM 32bit 768kHz and DSD512, three dual OPA1612 AOPs and a power purification system with a dedicated filter circuit.
1 | Display |
2 | Multi-function button |
3 | Single-ended Jack 6.35mm headphone output |
4 | Balanced Jack 4.4mm headphone outpût |
5 | Balanced XLR output |
6 | Single-ended RCA output |
7 | Coaxial input |
8 | Optical Toslink input |
9 | USB-C input |
10 | Bluetooth antenna |
11 | Power connector |
Product type | DAC |
Inputs | 1x USB-C 1x Optical Toslink 1x Coaxial Bluetooth 5.0 |
Outputs | 1x Single-ended stereo RCA 1x Balanced stereo XLR 1x Single-ended Jack 6.35mm headphone output 1x Balanced Jack 4.4mm headphone output |
DAC Chip | ESS ES9038Pro |
USB interface | XMOS XU216 |
Output level | RCA : 2Vrms XLR : 4Vrms |
Headphone output power | 2x 2W @ 16Ω 2x 1W @ 32Ω |
Headphone output gain | Low: 0dB High: +8dB |
THD+N | Headphone output: 0.0001% (-120dB) DAC: 0.00006% (-123dB) |
Dynamic range | RCA: 127dB XLR: 131dB |
SNR | RCA: 126dB XLR: 130dB |
Output impedance | Headphone output: near 0Ω DAC: 100Ω |
Bluetooth version | 5.0 |
Supported Bluetooth codecs | SBC, AAC, aptX, aptX HD, LDAC |
USB transmission | Asynchronous |
USB Compatibility | Windows 7 / 8 / 10 / 11 Mac OS X 10.6 and later Linux |
Supported sampling rates | USB : PCM up to 32bit 768kHz, Native DSD up to DSD512 Optical / Coaxial : PCM up to 24bit 192kHz, DSD DoP up to DoP64 |
Dimensions | 210 x 200 x 60mm |
Weight | 1.5kg |
Color | Silver |
Consumption | < 20W |
Input | SPDIF |
Input | Bluetooth |
Input | USB |
Input | Optical |
Output | Jack 6.35mm |
Output | XLR |
Output | Jack 4.4mm |
Output | RCA |
DAC / ADC Chip | ES9038PRO |
Max sampling rate | 768kHz |
Max sampling rate | DSD512 |
Max sampling rate | MQA |
Color | Silver |
Class | Class D / T |
Networking | No |
Remote Control | Yes |
Average votes 3.0 / 5 1 reviews | Why write products reviews ? You can share your feelings about products and help other people by sharing your experience |
Vukašin J.
