SHANLING EH1 DAC Headphone Amplifier Silver
With its EH1, Shanling unveils a compact, high-performance desktop DAC with a modern design. It embeds a Cirrus Logic CS43198 DAC chip, enabling it to support high-resolution sampling rates up to PCM 32bit 768kHz and native DSD up to DSD512. Headphone amplification relies on two SGM8262-2 OPAs and gain control for output power of up to 2x1015mW into 32 ohm on its balanced jack 4.4mm headphone output.
Reference : 20040
199,00 €tax incl.
165,83 € tax excl.
Shipping date: 16-04-2025.
Shanling EH1 DAC Headphone Amplifier CS43198 SGM8262 32Bit 768kHz DSD512 Silver
Shanling EH1 picture
With its EH1, Shanling unveils a compact, high-performance desktop DAC with a modern design. It embeds a Cirrus Logic CS43198 DAC chip, enabling it to support high-resolution sampling rates up to PCM 32bit 768kHz and native DSD up to DSD512. Headphone amplification relies on two SGM8262-2 OPAs and gain control for output power of up to 2x1015mW into 32 ohm on its balanced jack 4.4mm headphone output. The EH1 is therefore able to drive a wide range of headphones and earphones available on the market.
The interface features the essentials, with a USB input and a stereo RCA output, but a host of additional functions make the EH1 a DAC of choice, such as bass and treble tone control, UAC1.0 protocol support and a coaxial SPDIF digital output. To top it all off, two operating modes, Line-out or Pre-out, are available for the RCA output. This allows the Shanling EH1 to be used with a power amplifier, active speakers, preamplifier or integrated amplifier, for example.
Shanling EH1 key features
Shanling EH1: USB DAC and powerful headphone amplifier
The EH1 benefits from audiophile components offering a superior level of performance. Indeed, the CS43198 DAC chip offers a SNR of 122dB and a distortion level of just 0.0004%, as well as enabling conversion of high-resolution sampling rates up to PCM 32bit 768kHz and DSD512. Added to this are two SGM8262-2 OPAs driving the two single-ended 6.35mm jack and balanced 4.4mm jack headphone outputs, each offering a maximum output power of 2x399mW and 2x1015mW into 32 ohm respectively. The result is a clean, dynamic and powerful sound for pleasant headphone listening.
Les performances du Shanling EH1
Shanling EH1: USB to coaxial SPDIF conversion
The EH1 can convert digital signals from its USB input to a coaxial SPDIF output. This makes it ideal for pairing with other Hi-Fi devices, such as a vintage DAC or active speakers.
Sortie numérique du Shanling EH1
Shanling EH1: advanced features
Les deux modes de sortie du Shanling EH1
DTwo RCA output modes
The EH1 can be used as a DAC only with pre-out mode, or as a preamplifier with line-out mode. Output mode selection is simply made via a switch.
Contrôle de tonalités du Shanling EH1
Tone control
Two potentiometers on the front panel of the EH1 control the bass and treble tones. Adjustment is +/-6dB for bass and +/-10dB for treble.
Compatibilité UAC1.0 du Shanling EH1
USB UAC1.0 compatibility
In particular, compatibility with USB UAC1.0 protocol means you can connect your favorite game consoles to the EH1, such as the Nintendo Switch, and enjoy a more immersive gaming experience.
Shanling EH1: LED indicator on volume control knob
The EH1's main volume control knob is surrounded by a color LED indicator showing the sampling rate currently being processed by the device.
Indicateur LED du Shanling EH1
Shanling EH1: USB or DC jack power supply
The Shanling EH1 lets you choose between power supply via its USB-C input for greater simplicity, or power supply via its DC 5V jack port for greater stability.
Les deux modes d'alimentation du Shanling EH1
Shanling EH1 overview
1Jack 4.4mm balanced headphone output
2Jack 6.35mm single-ended headphone output
3Headphone output gain control
4Volume
5Bass control
6Treble control
7ON/OFF button
85V DC power input
9USB-C input
10Coaxial output
11RCA stereo output
12RCA output mode switch: Line-out/Pre-out
Tachnical characteristics
Product typeDAC / Headphone amplifier
DAC chipCS43198
OPA2x SGM8262-2
Input1x USB-C
Outputs1x RCA stereo (pre-out/Line-out)
1x Coaxial
1x Jack 6.35mm single-ended headphone output
1x Jack 4.4mm balanced headphone output
RCA output (line-out)
Output level2.38V
Frequency response20Hz-40kHz (-1.2dB)
THD+N0.0007% (A-wt, high gain)
Dynamic range123dB
Channel separation114dB
SNR122dB (A-wt, high gain)
Noise116dB
Output level2x63mW @ 32Ω, low gain, USB-C/Jack DC power supply
2x250mW @ 32Ω, high gain, USB-C power supply
2x399mW @ 32Ω, high gain, jack DC power supply
Frequency response20Hz-40kHz (1.5dB)
THD+N0.007% (A-wt @ 1Vrms, high gain, 32Ω)
Dynamic range119dB
Channel separation75dB
SNR119dB (A-wt, high gain)
Noise110dB
Output impedance0.4Ω
Jack 4.4mm Balanced headphone output
Output level2x250mW @ 32Ω, low gain, USB-C/Jack DC power supply
2x980mW @ 32Ω, high gain, USB-C power supply
2x1015mW @ 32Ω, high gain, jack DC power supply
THD+N0.008% (A-wt @ 1Vrms, high gain @ 32Ω)
Dynamic range119dB
Channel separation99dB
Noise104dB
Output impedance0.8Ω
Power supply5V DC via USB-C or Jack DC (power adapter sold separately)
ColorSilver
Dimensions156 x 90 x 36.5mm
Weight392.5g
Package1x Shanling EH1
1x USB-A to USB-C cable
1x USB-A to jack DC power cable adapter
1x 3.5mm jack to 6.35mm jack adapter
OutputCoaxial SPDIF
OutputJack 4.4mm
OutputJack 6.35mm
DAC / ADC ChipCS43198
Max sampling rate768kHz
Max sampling rateDSD512
ColorSilver
SHANLING EH1 DAC Headphone Amplifier CS43198 SGM8262 32Bit 768kHz DSD512 Silver
With its EH1, Shanling unveils a compact, high-performance desktop DAC with a modern design. It embeds a Cirrus Logic CS43198 DAC chip, enabling it...
