SMSL C100 DAC AK4493S XMOS XU316 Bluetooth 5.0 32 bit 768kHz DSD512 MQA
The SMSL C100 presents itself as a compact and affordable DAC, but with the same care given to the more expensive models of the brand. Its components are indeed specially selected for their quality and efficiency, allowing the C100 to provide a precise sound reproduction. It adds to this a complete connectivity and a Bluetooth wireless connectivity for a foolproof versatility.
Reference : 17084
115,00 €tax incl.
95,83 € tax excl.
SMSL C100
DAC AK4493S XMOS XU316 Bluetooth 5.0 32bit 768kHz DSD512 MQA
SMSL C100 DAC AK4493S XMOS XU316 Bluetooth 5.0 32bit 768kHz DSD512 MQA
AKM AK4493S DAC
The digital / analog conversion stage of the SMSL is based on the use of a AKM AK4493S DAC chip. This model ensures excellent performances with notably a THD+N reaching here 0.00013% for a restitution at the same time precise, rich and dynamic.
XMOS XU316 USB Interface
The use of a USB XMOS XU316 interface allows the C100 to read high resolution files for the most faithful sound reproduction possible. It supports audio streams up to PCM 32bit 768kHz and DSD512 via its USB-B input.
CK-03 Clock Circuit & Filtered Power Supply
Like the vast majority of SMSL devices of this generation, the C100 embeds the proprietary CK-03 clock circuit, allowing excellent synchronization of the clock signals for the lowest possible jitter. On the other hand, the power supply circuit benefits from an efficient filtering system, allowing to provide a clean and stable power supply to all the audio circuits from a single USB-B port.
MQA Decoder
In addition to supporting high resolution PCM and DSD streams, the SMSL C100 is able to decode MQA (Master Quality Authenticated) files. These files allow to enjoy a very high sound quality, as close as possible to the original signal captured in a recording studio.
1Screen
2Touch button
3MQA LED indicator
4IR receiver
5Stereo RCA output
6Optical Toslink input
7Coaxial input
8Bluetooth antenna
9USB / power supply input
Prodcut typeDAC
DAC chipAKM AK4493S
InputsBluetooth 5.0
1* USB-C
1* Optical Toslink
1* Coaxial
Outputs1* Stereo RCA
USB transmission modeAsynchronous
USB compatbilityWindows 7 / 8 / 8.1 / 10 / 11
Mac OSX 10.6 or later
Linux
Output level2Vrms
THD+N0.00013% (-117dB)
Dynamic range121dB
SNR121dB
Supported sampling ratesUSB : PCM up to 32bit 768kHz, Native DSD up to DSD512
Optical / Coaxial : PCM up to 24bit 192kHz
Consumption< 5W
Standby consumption< 0.1W
Dimensions (W*D*H)77.5*95*32mm
Weight190g
Housing materialAluminum
Package1x SMSL C100
1x Remote control
1x Antenna
1x USB-A to USB-C cable
DAC / ADC ChipAK4493S
Max sampling rate768kHz
Max sampling rateDSD512
Max sampling rateMQA
Remote ControlYes
DAC audiophile a prix mini
C’est mon troisième DAC Smsl. J’ai commencé par un Su9 couplé à un ampli casque. Puis un C200 couplé à un ampli classe D pour des enceintes bibliothèque. Et maintenant ce C100 pour la tv. Donc en gros prix 400€ / 200€ / 100€. Clairement le SU9 est beaucoup plus précis et défini. Mais le C100 a des graves impressionnants (différence puce AK versus ES ?). C’est le moins cher des Dac que j’ai trouvé avec une entrée optique, une télécommande et des composants audiophiles. Dans les inconvénients : alimentation non fournie, prévoir un chargeur USB. Alors que ses grands frères ont un câble secteur. Les aigus sont aussi moins bon mais le boîtier est plus compact. 5 étoiles pour les performances versus le prix mais selon le besoin le modèle au dessus peut être plus adapté… ou pas !
This review has been posted for SMSL C100 DAC AK4493S XMOS XU316 Bluetooth 5.0 32 bit 768kHz DSD512 MQA
The SMSL C100 presents itself as a compact and affordable DAC, but with the same care given to the more expensive models of the brand. Its...
