SMSL D12 DAC AK4493S XMOS XU316 Bluetooth 5.0 32bit 768kHz DSD512 MQA
The SMSL D12 is a compact and powerful DAC, using an AKM AK4493S digital to analog conversion chip to provide dynamic, musical and accurate sound. This one, in association with a modern USB interface XMOS XU316, also allows the support of high resolution audio streams up to PCM 32bit 768kHz, DSD512, as well as the decoding of MQA files.
Reference : 17242
189,00 €tax incl.
157,50 € tax excl.
SMSL D12
The SMSL D12 is a compact and performant DAC, using an AKM AK4493S digital to analog conversion chip to provide dynamic, musical and accurate sound. This one, in association with a modern USB interface XMOS XU316, also allows the support of high resolution audio streams up to PCM 32bit 768kHz, DSD512, as well as the decoding of MQA files. On the connectivity side, the D12 is simple and efficient with USB-C input and Bluetooth 5.0 wireless connectivity. The output is done in RCA or via the headphone output 6.35mm on the front.
Product typeDAC
InputsBluetooth 5.0
1* USB
Outputs1* Stereo RCA
1* Jack 6.35mm headphone output
DAC chipAKM AK4493S
USB interfaceXMOS XU316
Output level2.3Vrms
Gain+2.5dB
Output power400mW @ 16Ω
300mW @ 32Ω
THD+N0.00015% (-116dB)
Dynamic range120dB
SNR120dB
USB compatibilityWindows 7 / 8 / 8.1 / 10 / 11
Mac OSX10.6 ou ultérieur
Linux
Android
iOS
Sony PS5 (UAC1)
Nintendo Switch (UAC1)
Supported sampling ratesPCM up to 32bit 768kHz
DSD up to DSD512
Supply voltage5VDC via USB-C
Consumption< 10W
Standby consumption< 0.5W
Dimensions (L*P*H)139*102.5*33mm
Weight355g
Package1* SMSL D12
1* Remote control
1* Antenna
2USB-C to USB-A cable
The SMSL D12 is a compact and powerful DAC, using an AKM AK4493S digital to analog conversion chip to provide dynamic, musical and accurate sound....
