SMSL D300 ROHM DAC BD34301EKV XMOS XU208 Bluetooth 5.0 32bit 768khz DSD512
The SMSL D300 is an affordable and very powerful DAC, based on a high-end ROHM conversion chip. This last one offers excellent measurements for a sound restitution as rich as precise. The whole circuit and the components used are thought to provide a very beautiful sound reproduction. The device is also very versatile, with a complete set of connectors that will be able to adapt to the great majority of HiFi systems.
4.8 / 5
By buying this product you get 39 loyalty points
Reference : 15798
399,00 €tax incl.
332,50 € tax excl.
SMSL D300
SMSL D300 DAC ROHM BD34301EKV XMOS XU208 Bluetooth 5.0 32bit 768kHz DSD512
ROHM BD34301EV DAC
New for this D300, it uses a DAC ROHM BD34301EKV chip, real flagship of the brand. This one ensures a THD+N of -116dB and a sound restitution of a great transparency. It also supports high resolution audio streams.
XMOS XU-208 USB Interface
The USB-B input of the D300 embeds a XMOS XU-208 32bit chip. It allows the decoding of USB audio streams and offers a nice audio precision. Associated with the ROHM DAC, it allows the D300 to read high resolution streams, up to 32bit 768kHz PCM and native DSD512.
CK-03 Clock processing circuit new design
The D300 also embeds a brand new CK-03 clock signal processing circuit. The goal of this circuit is to achieve an ever lower jitter level. In particular, it ensures that the coaxial and optical inputs have a jitter as low as that of the USB input.
Integrated shielding
The SMSL DAC benefits from a shielding of its low noise power supply stage. This process allows to limit efficiently the interferences and the noise for a pure and precise sound.
Low consumption
The D300's power supply is also optimized for low power consumption. It uses low-noise discrete components.
Bluetooth 5.0
With its Qualcomm receiver chip and antenna, the D300 supports Bluetooth 5.0, so it can connect to your connected devices, like a smartphone, for convenient remote streaming. It also supports the high-definition codecs aptX, aptX HD and LDAC.
1Screen
2IR Receiver
3Volume button
4FN Button (configurable)
5Menu button
6ON/OFF - Input selector button
7RCA Output
8Balanced XLR output
9Coaxial input
10Optical input
11Bluetooth antenna
12USB-B input
13Power connector
Test du SMSL D300 par Audio Science Review (Amir)
" It is refreshing to both see the refined look of SMSL desktop products in this DAC and use of a new option in DAC chip technology. Performance is excellent... "
Product typeDAC
Inputs1x USB-B
1x Optical
1x Coaxial
Bluetooth 5.0
1x Balanced stereo XLR
DAC ChipROHM BD34304EKV
Output levelRCA : 2Vrms @ fixed volume, 2.3Vrms @ variable volume
XLR : 4Vrms @ fixed volume, 4.5Vrms @ variable volume
THD+N0.00015% (-116dB)
Dynamic rangeRCA : 125dB
XLR : 127dB
SNRRCA : 124dB
XLR : 127dB
Output impedanceRCA : 100Ω
XLR : 200Ω
USB Transmission modeAsynchronous
USB CompatibilityWindows 7 / 8 / 8.1 / 10 / 11
Mac OSX
Linux
Supported sampling ratesUSB, I2S : PCM up to 32bit 768kHz, Native DSD up to DSD512
Optical, Coaxial : PCM up to 24bit 192kHz, DSD DoP up to DSD64
Supported Bluetooth codecsSBC, AAC, aptX, aptX HD, LDAC
ConsumptionWorking : 5W
Standby : < 0.5W
Dimensions208 x 185 x 41mm
Weight1.05kg
Package1x SMSL D300
1x Remote control
1x Power cable
1x Antenna
1x USB Cable
DAC / ADC ChipROHM BD34301EKV
Max sampling rate768kHz
Max sampling rateDSD512
Remote ControlYes
13 reviews
Bon appareil : Très joli son pour des formats étendus
Acheté pour écouter la musique numérique de mon ordinateur au bureau avec un ampli de puissance + enceinte il fait parfaitement son travail avec une sonorité chaleureuse, détaillée pour des formats étendus. En PCM aucun soucis, les 32 bits 768 kHz couvrent largement mes besoins, le son est fluide et agréable. Par contre en DSD natif, et j'ai appris que c'est inhérent à ce format, avec ma configuration initiale je perdais la modulation du son qui reste à 100% et ai du intercaler un pré-ampli analogique pour ne pas ébranler les murs (et exploser mes enceintes)
This review has been posted for SMSL D300 ROHM DAC BD34301EKV XMOS XU208 Bluetooth 5.0 32bit 768khz DSD512
Remarquable
Surprenant, ce petit appareil. Il n'a peut-être pas la meilleure fiche technique, mais voilà : il FAIT de la MUSIQUE ! Et avec une précision telle (je l'utilise comme dac-préampli) que je distingue nettement le caractère des divers câbles que j'utilise en sortie. Un très bon RCA, par exemple, "sonne" mieux qu'un XLR courant.
On frôle le haut de gamme pour un prix très abordable.
Grand coup de chapeau au Japon et à la Chine !
A Dac
This Dac wont impress you at the start that's for shure but give it a little time and you will be pleased with warm no fatigue sound.At first i thought it wont be my cup of tea sort of speak but when you play high quality music through d300 it becomes very satisfying and you just find yourself changing album after album and wasting your time in a positive way.
excellent DAC
C'est mon premier achat chez Audiophonic et je recommande fortement ce site.
Choix des produits aux meilleurs prix, conseils et compétences.
Après 1 mois et demi d'utilisation de ce DAC S.M.L.S D300, je suis très content de mon achat.
Ce DAC sonne plutôt analogique et à pris place au coeur de mon installation.
Il est relié en USB derrière un mini-Pc Daphile qui gère ma collection de musique dématérialisée jusqu'au DSD.
Le bluetooth accepte des flux jusqu'à 24/48, très pratique pour lancer un streaming depuis un téléphone à la volée.
Il est relié à ma TV en optique.
Et à mon vieux lecteur CD/SACD SONY en coaxial et remplace avantageusement le DAC d'origine de celui-ci.
Ce DAC est agréable sur tout les styles musicaux.
Il manquerait peut-être un peu de tenue dans l'Infra-grave.
Mais à ce prix, rien de rédhibitoire.
Bref très satisfaite de cet achat pour le prix.
j'en rajoute une couche !!!
aujourd'hui mon revendeur hifi m'a prêté un drive heed obelisk dt pour tests.....le drive va rester à la casa car couplé au D300 cela donne un truc super musical !!! avec le oyaide dst-75 cela donne de la matière et beaucoup de délicatesse tout en gardant une dynamique très naturelle....
ne sous-estimez pas ce petit dac,c'est une merveille de musicalité !!!!
The SMSL D300 is an affordable and very powerful DAC, based on a high-end ROHM conversion chip. This last one offers excellent measurements for a...
