SMSL D400PRO DAC AK4191 AK4499EX XMOS XU316 Bluetooth 5.0 32bit 768kHz DSD512 MQA Silver
SMSL presents with its D400Pro a DAC as versatile as it is powerful, benefiting from rigorous design and top-quality components. It is based on two AKM digital/analog conversion chips: an AK4191 and an AK4499EX. As a result, it delivers transparent, precise sound reproduction.
Reference : 18246
699,00 €tax incl.
582,50 € tax excl.
Shipping date: 25-04-2025.
SMSL D400Pro
SMSL D400Pro DAC AK4191 AK4499EX XMOS XU316 Bluetooth 5.0 32bit 768kHz DSD512 MQA
SMSL presents with its D400Pro a DAC as versatile as it is powerful, benefiting from rigorous design and top-quality components. It is based on two AKM digital/analog conversion chips: an AK4191 and an AK4499EX. As a result, it delivers transparent, precise sound reproduction. What's more, its complete connectivity means it can be integrated into the vast majority of audio systems, and its Bluetooth 5.0 wireless connectivity means you can control it remotely.
AKM AK4191 + AK4499EX DAC
With its architecture incorporating both an AK4191 and AK4499EX DAC chips, the SMSL D400Pro manages to deliver excellent performance, with notably low levels of distortion and noise. The result is sound quality of incredible precision and fidelity. What's more, these conversion chips are capable of decoding PCM streams up to 32bit 768kHz and native DSD up to DSD512.
XMOS XU-316 USB interface
The D400Pro's USB-B input features a 3rd-generation XMOS XU-316 interface. Capable of efficient decoding and in association with the device's DAC chips, this USB input allows you to enjoy high-resolution audio streams up to 32bit 768kHz and DSD512.
High-ended components
The D400Pro uses top-quality components to maximize performance. These include 5 dual high-end OPAs, a proprietary CK-03 clock circuit that drastically reduces jitter. The SPDIF circuit also uses a PLL to reduce jitter. As for the power supply stage, it incorporates several voltage regulators to deliver a clean, stable electrical signal to the audio circuits.
MQA & MQA-CD
The SMSL D400Pro incorporates an MQA (Master Quality Authenticated) decoder, enabling it to read this type of file, guaranteeing sound quality as close as possible to studio recording. It can also be connected to a CD player to read and decode the MQA-CD format.
Bluetooth 5.0
In addition to its comprehensive and versatile connectivity, the SMSL D400Pro features a Bluetooth 5.0 receiver, so you can stream music wirelessly from a smartphone, for example. What's more, the device supports the high-resolution codecs aptX, aptX HD and LDAC for high quality wireless sound.
1Screen
2IR receiver
3LED indicator
4Multifunction button
5Balanced XLR output
6Bluetooth antenna
7Single-ended RCA output
8AES/EBU input
9Coaxial input
10Optical input
11USB input
12I2S input
13Power input
14Power button
Modern design
The SMSL D400Pro features a robust, modern aluminum chassis with a unique design. Its front features a beautiful screen, protected by a layer of tempered glass.
Product typeDAC
DAc chipsAKM AK4191 + AK4499EX
InputsBluetooth 5.0
1* AES/EBU
1* Coaxial
1* Optical
1* USB-B
1* I2S via HDMI
Outputs1* Single-ended stereo RCA
1* Balanced stereo XLR
Output levelRCA : 2.5Vrms
XLR : 5Vrms
Output impedanceRCA : 100 Ohm
XLR : 200 Ohm
THD+NRCA : 0.00008% (-121dB) (No-wt)
XLR : 0.00006% (-124dB) (No-wt)
Dynamic rangeRCA : 126dB
XLR : 132dB
SNRRCA : 126dB
XLR : 132dB
USB transmissionAsynchrone
USB compatibilityWindows 7 / 8 / 8.1 / 10 / 11 (with driver)
Mac OSX 10.6 or later
Linux
MQA decoderUSB
Optical
Coaxial
MQA-CD decoderOptical
Coaxial
Supported sampling ratesUSB / I2S : PCM up to 32bit 768kHz, DSD up to DSD512
Optical / Coaxial : PCM up to 24bit 192kHz
Supported Bluetooth codecsSBC, AAC, aptX, aptX HD, LDAC
Consumption< 10W
Standby consumption< 0.5W
Dimensions254*189*46mm
Weight1.9kg
ColorSilver
Package1* SMSL D400Pro
1* Power supply
1* Antenna
1* Remote control
SMSL D400Pro DAC AK4191 AK4499EX XMOS XU316 Bluetooth 5.0 32bit 768kHz DSD512 MQA SMSL D400Pro DAC AK4191 AK4499EX XMOS XU316 Bluetooth 5.0 32bit 768kHz DSD512 MQA SMSL D400Pro DAC AK4191 AK4499EX XMOS XU316 Bluetooth 5.0 32bit 768kHz DSD512 MQA SMSL D400Pro DAC AK4191 AK4499EX XMOS XU316 Bluetooth 5.0 32bit 768kHz DSD512 MQA SMSL D400Pro DAC AK4191 AK4499EX XMOS XU316 Bluetooth 5.0 32bit 768kHz DSD512 MQA
InputAES/EBU
InputI2S via HDMI
DAC / ADC ChipAK4499EX
DAC / ADC ChipAK4191
Max sampling rate768kHz
Max sampling rateDSD512
Max sampling rateMQA
ColorSilver
Remote ControlYes
SMSL presents with its D400Pro a DAC as versatile as it is powerful, benefiting from rigorous design and top-quality components. It is based on two...
