SMSL DO100 PRO Balanced DAC
The SMSL DO100 PRO balanced DAC is an evolution of the DO100 offered by the brand. The DO100 PRO benefits from numerous improvements. It features two ES9039Q2M DAC chips and a third-generation XU316 USB XMOS interface, enabling it to support high-resolution streams up to PCM 32bit 768kHz, DSD512 and MQA/MQA-CD.
4.6 / 5
Reference : 19150
219,00 €tax incl.
182,50 € tax excl.
SMSL DO100 PRO Balanced DAC 2xES9039Q2M XMOS XU316 Bluetooth 5.1 32bit 768kHz DSD512 MQA
Photo of SMSL DO100 PRO DAC
The SMSL DO100 PRO balanced DAC is an evolution of the DO100 offered by the brand. The DO100 PRO benefits from numerous improvements. It features two ES9039Q2M DAC chips and a third-generation XU316 USB XMOS interface, enabling it to support high-resolution streams up to PCM 32bit 768kHz, DSD512 and MQA/MQA-CD. An HDMI ARC port also enables the DO100 PRO to be linked to a TV as well as to active speakers or an amplification system, for a high-quality, immersive sound experience. A QCC5125 Bluetooth receiver chip completes the DO100 PRO's versatility, enabling wireless transmission with high-definition codecs: SBC, AAC, aptX, aptX HD, LDAC. Numerous digital inputs and two balanced RCA and XLR analog outputs make this a device of choice.
DO100 PRO DAC highlights
SMSL DO100 PRO: Dual DAC ES9039Q2M
SMSL has chosen to integrate two ES9039Q2M DAC chips into the DO100 PRO DAC, enabling it to achieve a high level of performance. In fact, these two digital/analog conversion chips give the DO100 PRO a dynamic range and SNR of -131dB, as well as a THD+N of 0.00005%.
Photo of SMSL DO100PRO ES9039Q2M DAC chips
Photo of the XMOS XU316 USB interface of the SMSL DO100 PRO DAC
SMSL DO100 PRO: XMOS XU316 USB interface and 6xOPA1612
The DO100 PRO's XMOS XU316 USB interface, coupled with six OPA1612 AOs, enables the DO100 PRO to support high-resolution PCM 32bit 768kHz and native DSD streams up to DSD512. So you can enjoy the best possible sound quality for your music listening sessions.
SMSL DO100 PRO: Support for MQA/MQA-CD streams
The DO100 PRO's digital and optical inputs support MQA x8 decoding as well as MQA-CD. So you can enjoy studio-quality recordings via Toslink optical, SPDIF coaxial and USB-C inputs.
SMSL DO100 PRO MQA flow support
SMSL DO100 PRO Bluetooth 5.1
SMSL DO100 PRO: Bluetooth 5.1
The cutting-edge DO100 PRO is equipped with Qualcomm's latest-generation QCC5125 Bluetooth receiver chip. Operating in Bluetooth 5.1, the DO100 PRO is capable of receiving SBC, AAC, aptX, aptX HD and LDAC codecs.
SMSL DO100 PRO: HDMI ARC port
An HDMI ARC input on the rear panel of the DO100 PRO enables it to retrieve the sound signal from a television. The DO100 PRO DAC can therefore be combined with a TV, active speakers or an amplification system to offer an immersive home cinema experience.
HDMI ARC port on SMSL DO100 PRO
SMSL DO100 PRO: USB compatibility with video game consoles
The USB-C port on the DO100 PRO is compatible with many video game consoles, including the PS4, PS5 and Nitendo Switch. It supports USB1.1 and USB2.0 protocols.
USB1.1 supports 24bit 96kHz streams only. To take advantage of USB compatibility with the PS5 or Nitendo Switch, the DO100 PRO must be in USB1.1 mode. After switching between USB 2.0 and USB 1.1, the DO100 PRO must be restarted for the change to take effect.
SMSL DO100PRO compatible with video game consoles
SMSL DO100 PRO: Low-noise power supply
SMSL has developed a low-noise power supply module to cleanly power the entire DO100 PRO.
SMSL DO100 PRO power supply board
SMSL DO100 PRO overview
SMSL DO100 PRO connection diagram
1Display
2IR remote control sensor
3DSD LED indicator
4MQA LED indicator
5Standby LED indicator
6Volume control knob
7Stereo RCA output
8XLR balanced stereo output
9Coaxial input
10Toslink optical input
11HDMI ARC input
12Bluetooth antenna
13USB-C input
14IEC power supply
15Power switch
Product typeDAC
DAC chip2x ES9039Q2M
USB interfaceXMOS XU316
AOP6x OPA1612
Inputs1x USB-C input
1x Toslink optical input
1x Coaxial SPDIF input
1x HDMI ARC
Bluetooth
Outputs1x RCA Stereo
1x XLR balanced stereo
Supported sampling ratesUSB: PCM 32bit 768kHz, DSD DoP256, DSD512 and MQAx8/MQA-CD
Toslink optical and SPDIF coaxial: 24bit 192kHz, DSD DoP64 and MQAx8/MQA-CD
Supported Bluetooth codecsSBC, AAC, aptX, aptX HD et LDAC
Output levelRCA : 2.5Vrms
XLR : 5Vrms
THD+N0.00005% (-124.5dB non-weighted)
Dynamic rangeXLR : 131dB RCA : 127dB
SNRXLR : 131dB RCA : 127dB
Output impedance100 ohms
USB TransmissionAsynchronous
USB compatibilityWindows 7/8/8.1/10/11 (with driver)
MAC OSX 10.6 et + / Linux (without driver)
Power consumption<10w
Standby : <0.5W
Dimensions189x45x186mm
Weight1.45kg
Package1x SMSL DO100 PRO DAC
1x USB-C cable
1x Bluetooth antenna
1x IR remote control
1x Mains cable
SMSL DO100 PRO measurements
InputHDMI ARC
DAC / ADC ChipES9039Q2M
Max sampling rateDSD512
Max sampling rateMQA
Max sampling rate768kHz
Remote ControlYes
7 reviews
Primeira experiência com a Audiophonics
A Audiophonics tem uma reputação inquestionável. No entanto, a minha primeira compra foi efetuada no dia 2 de julho, por volta das 2h da manhã, e esperava, no mínimo, que a encomenda fosse expedida ainda nesse mesmo dia. Para minha surpresa, isso não aconteceu.
Ainda assim, mantenho a expectativa de que a qualidade do serviço e do suporte esteja à altura das excelentes avaliações que tenho lido.
This review has been posted for SMSL DO100 PRO Balanced DAC 2xES9039Q2M XMOS XU316 Bluetooth 5.1 32bit 768kHz DSD512 MQA
SMSL DO100 Pro – Short Review
This is my first DAC, so I don’t have much to compare it with, but I specifically needed a DAC with HDMI input for my TV and balanced outputs. After some research and recommendations from the Audio Science Review forum, I chose the SMSL DO100 Pro.
For the price, it’s a very good DAC. It feels solid and performs exactly as expected. Standard shipping took 6 days, which was reasonable. It works perfectly with my MacBook Pro M3 Max via USB, with no issues or connectivity problems.
Overall, I’m satisfied with the purchase and would recommend it to anyone looking for a DAC with HDMI and balanced outputs at a good price.
Bon rapport qualité/prix
Ne recherchant pas l'excellence à tout prix, mon oreille, d'ailleurs, ne me le permet pas puisqu'elle n'identifie pas les différences entre les formats MP3, FLAC et HiRes, ce petit DAC a une conversion et une restitution sonore qui me conviennent.
J'utilise les entrées optique (tv via le player de ma box) et coaxiale (lecteur réseau) et la sortie RCA (ampli intégré9.
La télécommande, qui fonctionne avec 2 piles R03 non fournies, s'apprivoise vite à condition de consacrer 2 minutes à lire la notice d'utilisation (en anglais)
bon produit difficile a utiliser car pas de notice en français
Bel upgrade
J'utilisais un petit dac audiophonics usabre, et c'est un sacré progrès. Je ne suis pas un grand spécialiste hifi, toutefois, ce dac produit un son très équilibré très détaillé et ne pardonne pas les mauvais enregistrements. J'en suis très satisfait, l'affichage est très lisible, ce que je reprochais au toppind d50III. Pour le prix il me semble impossible d'être decu
The SMSL DO100 PRO balanced DAC is an evolution of the DO100 offered by the brand. The DO100 PRO benefits from numerous improvements. It features...
