SMSL DO200 DAC 2x ES9068AS XMOS Bluetooth 5.0 LDAC 32bit 768kHz DSD512 MQA
SMSL offers with its DO200 a small, powerful and complete DAC. Its digital/analog conversion stage is equipped with 2x ESS9068AS DAC chip, able to offer a transparent, rich and precise sound reproduction. Added to this DAC is an excellent XMOS XU216 USB interface. The association of these two components allows the support of high sampling rates, up to PCM 32bit 768kHz, DSD512 as well as the decoding of MQA files.
By buying this product you get 52 loyalty points
Reference : 15726
529,00 €tax incl.
440,83 € tax excl.
This product has been replaced by the new version, the SMSL DO200 MKII DAC 2x ES9068AS XMOS XU316.
SMSL DO200
DAC 2x ES9068AS XMOS Bluetooth 5.0 32bit 768kHz DSD512 MQA
SMSL DO200 DAC ES9068AS XMOS Bluetooth 5.0 32bit 768kHz DSD512 MQA
MQA Decoding
MQA (Master Quality Authenticated) is an award-winning British technology that restores the sound of the original recording. The MQA Master file is authenticated by the artists, producers or rights holders. These files are light enough to stream or download.
The DO200 incorporates an MQA decoder to read these files in order to provide the best possible audio quality.
Bluetooth 5.0 - QCC5125
Particularly practical, the DO200, in addition to its connectivity, is equipped with a Bluetooth 5.0 receiver from Qualcomm. This one supports the classic codecs SBC and AAC, as well as the high quality codecs aptX, aptX-HD and LDAC, allowing to reach a restitution close to that of the CD, in wireless.
A readable and practical screen
The DO200 is equipped with a beautiful, bright and readable display, protected by a tempered glass window. It clearly displays all the essential information for a comfortable use of the device.
1Audio format
2Active output display. When blank, two active output at the same time
3Phase indicator
4Volume level
5Sampling rate. When Bluetooth input, display the decoding format
Flexible connectivity
The back of DO200 reveals a particularly complete connectic, allowing the DAC to adapt to the great majority of audio systems. On the input side, we find USB-B, I2S via HDMI, AES/EBU, Optical, Coaxial and of course Bluetooth. On the output side, the DO200 provides single-ended stereo RCA and balanced stereo XLR.
1Multifonction knob
2Screen
3IR Receiver
4RCA Output
5Bluetooth antenna
6Optical input
7Power supply connector
8Balanced XLR output
9AES/EBU Input
10I2S via HDMI Input
11Coaxiale input
12USB-B input
13Power button
Product typeDAC
DAC Chip2x ES9068AS
InputsBluetooth 5.0
1x AES/EBU
1x I2S via HDMI
1x Coaxial
1x USB-B
1x Optical Toslink
Sorties1x Single-ended stereo RCA
1x Balanced stereo XLR
THD+N0.00008% (-122dB)
Dynamic rangeXLR : 129dB
RCA : 125dB
SNR129dB
Output impedance< 10Ω
USB transmission modeAsynchronous
Supported sampling ratesUSB, I2S : PCM up to 32bit 768kHz, DSD up to DSD512
Optical, Coaxial, AES/EBU : PCM up to 24bit 192kHz, DSD DoP up to DSD64
Supply voltage100-240VAC (Power cable included)
Consumption5W
Standby consumption< 0.5W
Dimensions / Weight210x40x170mm / 1,2kg
RemoteYes
Housing materialAluminum
Package1x SMSL DO200
1x Remote control
1x Antenna
1x USB Cable
1x Power cable
InputI2S via HDMI
InputAES/EBU
DAC / ADC ChipES9068AS
Max sampling rate768kHz
Max sampling rateDSD512
Max sampling rateMQA
Remote ControlYes
Simply amazing!
The DO200 is a linear Dac with an overall signature of being crystal clear and dead silent with the noise floor.
The midrange of DO200 is clean, detailed, vivid, and very wide.
The bass feels sharp and deep, dense, but not overbearing in amount.
The treble is clean, airy and brightly open, with good extension up to the highest treble notes.
The soundstage is not just wide, but also deep.
Overall an awesome Dac from SMSL
For more follow me in Instagram @darkwish_aesthetics
This review has been posted for SMSL DO200 DAC 2x ES9068AS XMOS Bluetooth 5.0 LDAC 32bit 768kHz DSD512 MQA
SMSL offers with its DO200 a small, powerful and complete DAC. Its digital/analog conversion stage is equipped with 2x ESS9068AS DAC chip, able to...
