By buying this product you get 52 loyalty points
DAC ES9039MSPro XMOS XU316 Bluetooth 5.0 aptX HD LDAC 32bit 768kHz DSD512 MQA
The SMSL DO300 DAC takes the technical base of the DO200 MKII while updating its components for improved performance. Its digital/analog conversion stage is now equipped with an ES9039MSPro DAC chip, capable of offering a transparent, rich and precise sound reproduction. In combination with an XMOS XU316 USB interface, the DO300 supports high sampling rates, up to 32bit 768kHz PCM, DSD512 as well as MQA and MQA-CD decoding. The clock circuit has also been improved, the DO300 now uses the CK-03 architecture developed by the brand and allowing to reach a very low jitter level.
MQA (Master Quality Authenticated) is an award-winning British technology that restores the sound of the original recording. The MQA Master file is authenticated by the artists, producers or rights holders. These files are light enough to stream or download.
The DO300 includes an MQA decoder to play these files in order to provide the best possible audio quality. The device also supports the decoding of MQA-CD.
Particularly practical, the DO300, in addition to its connectivity, is equipped with a Bluetooth 5.0 receiver from Qualcomm. This one supports the classic codecs SBC and AAC, as well as the high quality codecs aptX, aptX-HD and LDAC, allowing to reach a restitution close to that of the CD, in wireless.
The DO300 is equipped like its big brother with a beautiful screen, bright and readable, protected by a tempered glass window. This one clearly displays all the essential information for a comfortable use of the device.
The back of DO300 reveals a particularly complete connectic, allowing the DAC to adapt to the great majority of audio systems. On the input side, we find USB-B, I2S via HDMI, AES/EBU, optical, coaxial and of course Bluetooth. On the output side, the DO300 provides single-ended stereo RCA and balanced stereo XLR.
1 | Multi-function button |
2 | Screen |
3 | IR receiver |
4 | RCA output |
5 | Bluetooth antenna |
6 | Optical input |
7 | Power connector |
8 | Balanced XLR output |
9 | AES/EBU input |
10 | I2S HDMI input |
11 | Coaxial input |
12 | USB-B input |
13 | Power button |
Product type | DAC |
DAc chip | ES9039MSPro |
Inputs | Bluetooth 5.0 1x AES/EBU 1x I2S via HDMI 1x Coaxial 1x USB-B 1x Optical Toslink |
Outputs | 1x Single-ended stereo RCA 1x Balanced stereo XLR |
THD+N | 0.00005% (-125dB) |
Dynamic range | XLR : 134dB RCA : 128dB |
SNR | XLR : 134dB RCA : 127dB |
USB transmission mode | Asynchrone |
Supported sampling rates | USB, I2S : PCM up to 32bit 768kHz, DSD up to DSD512 Optical, Coaxial, AES/EBU : PCM up to 24bit 192kHz, DSD DoP up to DSD64 MQA, MQA-CD |
Geenral | |
Supply voltage | 100-240VAC (power cable included) |
Consumption | < 10W |
Standby consumption | < 0.5W |
Dimensions / weight | 210*43*185mm / 1.2kg |
Remote control | Yes |
Housing material | Aluminum |
Color | Black |
Package | 1x SMSL DO300I 1x Remote control 1x Antenna 1x USB cable 1x Power cable |
Input | SPDIF |
Input | Bluetooth |
Input | AES/EBU |
Input | USB |
Input | Optical |
Input | I2S via HDMI |
Output | XLR |
Output | RCA |
DAC / ADC Chip | ES9039MPro / ES9039MSPro |
Max sampling rate | DSD512 |
Max sampling rate | MQA |
Max sampling rate | 768kHz |
Color | Black |
Networking | No |
Remote Control | Yes |
