SMSL DO300EX DAC AK4191+AK4499EX Headphone Amplifier XMOS XU316 Bluetooth 5.1 LDAC 32bit 768kHz DSD512 MQA-CD Silver
SMSL unveils, with the DO300EX, a powerful, high-quality DAC/headphone amplifier. It incorporates quality components such as the AK4499EX DAC chip coupled with an AK4191 digital filter interface, an XMOS XU316 USB interface, 5 OPA 1612A, a TPA6120A2 headphone amplifier chip and the latest-generation Qualcomm QCC5125 Bluetooth chip. Moreover, an MQA decoder is integrated into the DO300EX.
By buying this product you get 47 loyalty points
Reference : 18146
479,00 €tax incl.
399,17 € tax excl.
Shipping date: 18-04-2025.
SMSL DO300EX
SMSL unveils, with the DO300EX, a powerful, high-quality DAC/headphone amplifier. It incorporates quality components such as the AK4499EX DAC chip coupled with an AK4191 digital filter interface, an XMOS XU316 USB interface, 5 OPA 1612A, a TPA6120A2 headphone amplifier chip and the latest-generation Qualcomm QCC5125 Bluetooth chip. Moreover, an MQA decoder is integrated into the DO300EX. This DAC is capable of decoding high-resolution audio streams up to PCM 32bit 768kHz, DSD512 and MQA-CD. Performance on the headphone amplifier side is also very good, and it's notable that the clock circuit is based on the DO300's, using the CK-03 architecture developed by the brand to achieve very low jitter. The DO300EX features a full range of connectors that can be adapted to numerous configurations and input sources. In addition, the exterior features a rather imposing screen and small aesthetic details, making this a pleasant-looking device.
AKM chips: AK4191 and AK4499EX
The DO300EX incorporates an AK4499EX DAC chip coupled with an AKM AK4191 digital filter interface. This chip combo and the DO300EX's symmetrical architecture enable it to decode up to PCM 32bit 768kHz and DSD up to DSD512. They also accept MQA streams and offer a distortion level of less than 0.00006% (-124dB).
Third-generation XMOS USB interface
A 16-core XMOS XU316 USB interface is integrated into the DO300EX. This interface enables it to process high-resolution streams (PCM 32bit 768kHz and DSD512) via its USB-C input port. This may be ideal for users wishing to use their computer as a source device. The interface is coupled with no less than 5 OPA1612A.
Bluetooth 5.1
A Qualcomm QCC5125 chip enables the SMSL DO300EX to support AAC, SBC, aptX, aptX HD and LDAC codecs. So you can enjoy high-resolution files in wireless transmission.
A high-performance headphone amplifier
On the front of the DO300EX are two headphone outputs: a balanced 4.4mm jack and an unbalanced 6.35mm jack. The headphone amplifier circuit incorporates a TPA6120A2 chip.  The DO300EX can be adapted to a lot of different types of headphones, thanks to its wide range of connectors and high output power: 2x 2000mW / 16Ω, 2x 1000mW / 32Ω.
MQA decoder
The DO300EX's MQA decoder enables it to support MQA-CD streams via its coaxial and Toslink optical inputs. This DAC therefore offers the possibility of enjoying professional audio quality, with retransmission as close as possible to the original sound recorded and worked on in the studio.
Ultra low noise power supply
SMSL has specially designed an ultra-low-noise regulated linear power supply for its DO300EX DAC. This is complemented by a network of several low-noise regulated power supplies, providing a stable, reliable, efficient and low-noise overall power supply system.
Remote control
The DO300EX remote control provides access to all basic functions such as volume control, play/pause/previous/next functions and input source selection.
Complete connectivity
1Display
2Bluetooth antenna
3Volume control
46.35mm jack unbalanced headphone output
54.4mm jack balanced headphone output
6Balanced stereo XLR output
7Unbalanced stereo RCA output
8Coaxial input
9Toslink optical input
10I2S input via HDMI
11USB-C input
12Bluetooth antenna
13IEC power socket
14Power switch
Product typeDAC
Headphone amplifier
Inputs1x USB-C
1x Coaxial
1x Optical Toslink
1x I2S via HDMI
Bluetooth
Outputs1x Stereo RCA analog output
1x XLR stereo balanced output
1x 4.4mm jack balanced headphone output
1x 6.35mm jack unbalanced headphone output
Supported sample ratesPCM 32bit 768kHz, DoP64, DoP256 DSD512, MQA, MQA-CD
Output levelXLR : 5.2Vrms
RCA : 2.5Vrms
Headphone outputs power2x 2W / 16Ω
2x 1W / 32Ω
THD+NXLR & RCA : 0.00006% (-124dB, unweighted)
Headphone outputs : 0.0001% (-120dB, unweighted)
Dynamic rangeXLR : 132dB
Headphone outputs : 127dB
SNRXLR : 132dB
Output impedanceXLR : 200Ω
RCA : 100Ω
Headphone outputs : near 0Ω
Heaphone outputs gainLow : 0dB
High : +7dB
USB transmission2.0 asynchronous
USB compatibilityWindows 7/8/8.1/9/10/11 (with driver)
Mac OS 10.6 and +
Linux
MQA decodingMQA : USB, Optical Toslink, Coaxial
MQA-CD : Optical Toslink, Coaxial
Supported bluetooth codecsAAC, SBC, aptX, aptX HD, et LDAC
Power consumption< 20W
Standbye power consumption< 0.5W
ColorSilver
Dimensions222 x 307 x 39mm
Weight1.54kg
Package1x DAC / Headphone amplifier DO300EX SMSL
1x Mains cable
1x USB cable
1x Bluetooth antenna
1x Remote control
InputI2S via HDMI
OutputJack 4.4mm
OutputJack 6.35mm
DAC / ADC ChipAK4191
DAC / ADC ChipAK4499EX
Max sampling rateMQA
Max sampling rate768kHz
Max sampling rateDSD512
ColorSilver
ClassN/A
Remote ControlYes
SMSL unveils, with the DO300EX, a powerful, high-quality DAC/headphone amplifier. It incorporates quality...
