SMSL M200 Balanced DAC AKM4497EQ XMOS U208 Bluetooth 5.0 768kHz DSD512 Black
Balanced desktop DAC with native DSD XMOS USB interface, SPDIF & Bluetooth 5.0 192kHz. Delivered with its infrared remote control.
4.5 / 5
By buying this product you get 36 loyalty points
Reference : 14552
369,00 €tax incl.
307,50 € tax excl.
SMSL M200
Balanced DAC AKM4497EQ 768kHz DSD512
The M200 in SMSL is a compact DAC with volume control using a AKM AK4497EQ DAC chip. It is able to decode files with a sampling frequency up to 768kHz and natively supports DSD up to DSD512 through its USB interface XMOS.
Besides its high definition USB input, it includes a S/PDIF interface and a Qualcomm Bluetooth 5.0 interface with support for high definition audio protocols (UAT, LDAC, apt-X HD, SBC, AAC).
It has a balanced and a single-ended output stage in order to comply with the requirements of any complex or compact audio installation.
Balanced DAC AK4497EQ
Equipped with a DAC AKM AK4497EQ 32-bit integrated in a balanced circuit, SMSL M200 uses the famous Velvet Sound architecture. This allows the disclosure of the lowest sound details which are ordinarily lost in audible distortion. The device offers a great SNR of 125dB with a very low THD of 0.00015%.
Velvet Sound technology available in DAC AK4497EQ offers 6 different digital filters in order to meet your own listenning preferences as well as the specifications of your audio system as a whole. (Super Slow roll-off, Short Delay Slow Roll-Off, Slow Roll-Off, Low dispertion, Short Delay Sharp Sharp Roll-off and roll-off).
Finally AKM AK4497EQ The chip is mainly a native DSD decoder, making the M200 an ideal choice for high-definition music enthusiasts.
The M200 is capable of operating in pure DAC mode with DSD signals to bypass completely the volume control feature and keep only the strictly audio information without performing any modification to the signal.
USB, SPDIF & Bluetooth 5.0
The DAC has a SPDIF input interface, a USB interface, a Bluetooth interface and offers wide input connectivity. It can be connected to your digital sources via an optical or coaxial connector (S / PDIF to 192kHz-24bit), a USB-2 type B connector (USB XMOS to 768kHz-32bit & DSD512) and via bluetooth.
Its Qualcomm quad-core Bluetooth 5.0 receiver supports UAT / LDAC / APTX-hd / AAC / SBC standards and can accept wireless digital streams up to 192kHz-24bit.
OLED screen & Volume knob
On its front panel, a wide knob makes it easy to adjust the volume. An OLED screen displays the volume status to easily find your favorite configuration. It also shows all information necessary to verify that the filedecoding is optimal (detected sampling rate, type of active input...).
Infrared remote included
The M200 comes with an infrared remote control. The latter offers the possibility to control all the unit functions : setting on / off, volume control, mute, filter selection, source selection,screen display mode, pairing bluetooth ...
TypeDAC with volume
InputsOptical
Coaxial
USB-B
Bluetooth
OutputsBalanced stereo XLR
Single-ended stereo RCA
Output levelsRCA: 2Vrms
XLR: 4.1 Vrms
THD + N0.00015% (-116dB)
DynamicRCA: 123dB
XLR: 125dB
SNR125dB
Bluetooth standardUAT-192kHz 24bit
LDAC-96kHz 24bit
apt-X HD-48kHz 24bit
apt-X-44.1kHz 16bit
SBC-16bit 44.1kHz
AAC-16bit 44.1kHz
USBXMOS asynchronous
USB SupportWindows 7, 8, 10
Mac OS X10.6 +
Linux
Sampling supportedUSB: 44.1 - 768kHz 32bit
S / PDIF: 32 - 192kHz 24bit
DSDUSB: DSD64, DSD128, DSD256, DSD512
Power supplyDC 5V
Power consumption3.5W
0.1W idle
Dimensions160x43x168mm
Weight0.68kg
Package contents
SMSL M200x1
Bluetooth antennax1
Power supplyx1
USB-A to USB-B cablex1
User manualx1
2 reviews
Très bon DAC.
Excellent DAC, relié en XLR à des monitoring (Dynaudio LYD 7). Le son est très bon dans tous les registres. L'étoile en moins c'est pour la notice qui est plus que sommaire et pas de version française en plus.. Notice qu'il faut bien lire d'ailleurs car par exemple pour que la télécommande fonctionne il faut d'abord appuyer sur une touche. Au début j'ai cru qu'elle ne marchait pas.
This review has been posted for SMSL M200 Balanced DAC AKM4497EQ XMOS U208 Bluetooth 5.0 768kHz DSD512 Black
endgame Amp
I'm not going to dwell too much into details and such. I'll just make it short and straight to the point. It's a magnificent desktop toaster (it gets hot. but I got a rebel amp that beats it to the punch and can cook an egg if needed to, so, not that of an issue), with probably the cleanest output I've had the pleasure to lay my ears onto. THX has come to revolutionize the market. I can't stop bragging and loaning my unit to friends, so that they can suck it up, and hear for themselves that it is CLEAN. And pairing it with a good dac (hybrid,tube,solid, you name it), believe me, what you'll be hearing is what the DAC outputs and nothing else. So, if you are really looking just for an amp, (no soundstage, coloration, separation and all that crap, messing around with the source audio) this is it. In all seriousness, just buy the damned thing and go on with your life. no need to look more, or you get this, or the Monolith THX... and then, close your wallet.
cheers
Well, my 2cents.
