SMSL M7 USB DAC / Headphone Ampli XMOS XU208 2x AK4452 32Bit / 768KHz DSD512
4.7 / 5
By buying this product you get 20 loyalty points
Reference : 11913
209,00 €tax incl.
174,17 € tax excl.
The SMSL M7 is the brand newDAC USB / Headphone Amplifierof the brand. The latter is a very high fidelity device which integrates two AKM converters AK4452 and an Asynchronous USB interface XMOS XCore U208, just that.
This M7 SMSL will allow you to decode PCM audio files up to 32bits / 768kHz, kHz as well as DSD files 2.8224 / 5.6448 / 11.2896 / 22.5792 MHz.
SMSL M7 DAC Hi-Res audio
The headphone amplifier chip used is the TPA6120A2 (datasheet available in the "download" tab of this page), with ultra-low distortion and a driver capacity of 30 to 600 Ohm headphones.
This DAC / Headphone Amplifier is equipped with quality components (TRIAD Transformer, Nichicon FW capacitors, LM4562 Audio Chips ...) and incorporates very precise clocks in order to significantly reduce the Jitter.
Versatile and modern, this SMSL M7 will easily fit into your high-fidelity audio system due to its high-end performance and its sleek, simple design. Its value for money is simply incomparable, this SMSL will know how to get you long and pleasant hours of listening.
General technical characteristics:
  • DAC AKM: 2x AK4452
  • USB XMOS: XCore200 XU208
  • THD + N: RCA (0.00068%) / Jack 6.35mm (0.0036%)
  • Signal Noise Ratio: RCA (107dB) / 6.35mm Jack (101dB)
  • Dynamic range: 116dB
  • Asynchronous USB Transmission
  • Supported Sampling Rates: Up to 32Bit / 768kHz in USB - Up to 24Bit / 192kHz in Optical and Coaxial
  • Support DSD: 2.8224MHz / 5.6448MHz / 11.2896MHz / 22.5792MHz
  • Transformer TRIAD (USA) high quality
  • Very low audio clocks Jitter
  • RCA Output Level: 4Vrms
  • Certified Hi-Res Audio, by the Japan Audio Society
Headphone amplifier part:
  • Texas Instruments chip: TPA6120A2 very low distortion
  • Supports headphones with an impedance between 30 and 600 Ohm
  • 138mW - 32 Ohm @ THD 0.1%
  • 110mW - 64 Ohm @ THD 0.1%
  • 58mW - 150 Ohm @ THD 0.1%
  • 30mW - 300 Ohm @ THD 0.1%
Compatibilities:
  • Headphone Amplifiers / Amplifiers / Active Speakers
  • Windows (With Driver)
  • Mac OS and iOS
  • Support OTG
Weight, package, accessories:
  • Powered by 110-220V
  • Power Consumption Operational: 4.3W
  • Standby Power Consumption: 0.9W
  • Inputs: USB-B / Optical / Coaxial
  • Outputs: RCA Stereo / Headphones Jack 6.35mm
  • Weight: 911g
  • Dimensions: 188x84x51mm
  • Black color
  • Comes with: Power cable / USB cable
Caractéristiques SMSL M7 DAC
Clock low Jitter SMSL M7
SMSL M7 Connectique arrière
Taille dimensions SMSL M7
OutputJack 6.35mm
3 reviews
Super DAC
Un peu sceptique au départ, mais à l'écoute vite rassuré voir enthousiaste. La spacialisation est remarquable, les instruments bien nets et différentiés, et le son excellent.Les aigus extrêmes sont peut-être un peu "criards", mais c'est vraiment pour pinailler. L'impression d'ensemble est étonnante de précision et plein de petits détails que je n'avais pas remarqués sur mes albums préférés sont présents. La dynamique est également au rendez vous. Bref un super achat à un prix somme toute abordable et je pense que cet ampli dac a des qualités qui sont présentes sur des modèles beaucoup plus chers.
Un tout petit bémol cependant, l'appareil siffle un peu ( du au transfo intégré ?) si il est posé sur du bois; Mettre un peu de feutrine sous les pieds et tout rentre dans l'ordre.
This review has been posted for SMSL M7 USB DAC / Headphone Ampli XMOS XU208 2x AK4452 32Bit / 768KHz DSD512
Commandé le 5. 11 reçu le 9.11
Livraison sans souci, emballage impeccable.
Surprise, notice très réduite en chinois et anglais!
Ne serait il pas possible d'avoir pour un matériel commandé en France et livré à partir de la France une notice, même si celle ci est réduite au strict minimum, traduite en français!
Cela étant après quelques tâtonnements et téléchargement du logiciel Xmos adapté, l'appareil est reconnu .
En ce qui concerne les réglages par ce fameux bouton unique
il faut y passer un moment avant de comprendre , quant aux différents filtres j'en suis toujours à rechercher les différences
du rendu sonore.
Cela étant ce petit appareil à prix très raisonnable donne, couplé à un petit ampli My amp et enceintes Focal Chorus, un son très détaillé
avec Jriver comme lecteur avec convolution pour fichiers PCM
Ayant pour le moment peu de fichiers DSD, en attente de tester si effectivement lecture en DSD natif.
Conclusion: Bon rapport qualité prix, mais manque de description plus détaillée pour une prise en main facile et rapide sans se prendre la tête!
Bon dac-ampli casque
Acheté il y a peu, je suis pleinement satisfait de ce petit dac ampli casque. Je vais commencé mon compte rendu par l'aspect le plus négatif; l'absence totale de notice en Français! Seulement un petite feuille de la taille d'un post it, en chinois. Ne connaissant pas cette langue....
Enfin bref.
Après avoir fait travailler mes petites notions d'anglais, j'arrive à faire fonctionner cette petite merveille, qui, une fois le drivers xmos installer envoi sacrément bien. Spatialisation assez déroutante en comparaison du wolfson qui équipe mon ampli Hifi. La, la scène est toujours profonde, les enceintes s'effacent totalement pour laisser place aux instru et voix. Le jeux stéréo est un peu moins marqué que le wm8741 mais il y a plus de détails qui fourmillent. En utilisation ampli casque, vraiment rien a redire. Je dispose d'un fidelio x2, facile à alimenter. Mon seul regret sur l'appareil, c'est (peut être que c'est possible) l'utilisation strict, en dac, avant un ampli Hifi, sans contrôle de volume.
Pour conclure, ce qu'il faut retenir
C'est un excellent dac/ampli casque avec deux puces akm, une supère variété de format que peu peuvent se vanter de proposer dans cette gamme de prix. Mais qu'il est un peu difficile à prendre en main pour qui n'est pas bilingue
