SMSL SANSKRIT 10TH MKIII DAC USB AK4493S XMOS XU316 32bit 768kHz DSD512 Gray
SMSL comes back with an updated version of the Sanskrit, the Sanskrit 10Th MKIII, taking back the compact and practical design of the former model while improving its performances thanks to new components. We thus find there a powerful, versatile and affordable DAC with a neat design.
4.0 / 5
Reference : 16943
135,00 €tax incl.
112,50 € tax excl.
SMSL Sanskrit 10Th MKIII
SMSL Sanskrit 10Th MKIII DAC USB AK4493S XMOS XU316 32bit 768kHz DSD512 Gris
In this edition of the DAC, the digital/analog conversion stage is equipped with the new AKM AK4493S chip, ensuring precise and dynamic sound reproduction. This is associated with a USB XMOS XU316 interface, supporting high resolution audio streams up to PCM 32bit 768kHz and DSD512. The Sanskrit's CK-03 clock system allows for perfect signal synchronization and therefore a significant reduction in jitter. Finally, the power supply stage includes a powerful filtering system to provide a clean and stable electrical signal to all audio circuits.
Rotating screen
The design of the Sanskrit is designed to take up a minimum of space on your desk or in your HiFi system. It can be placed in three different ways. An accelerometer automatically changes the orientation of the screen.
1IR Receiver
2Screen
3Power / input selection button
4RCA output
5Coaxial input
6Optical input
7USB input
8Auxiliary power input
Product typeDAC
DAC chipAKM AK4493S
USB interfaceXMOS XU316
Inputs1x USB-C
1x Optical Toslink
1x Coaxial
Output1x Stereo RCA
Output level2Vrms
THD+N0.00013% (117dB)
Dynamic range121dB
SNR121dB
CompatibilityWindows 7 / 8 / 8.1 / 10 /11
Mac OS X 10.6 or later
Linux
Supported sampling ratesUSB : PCM up to 32bit 768kHz, DSD up to DSD512
Optical / Coaxial : PCM up to 24bit 192kHz
Consumption< 5W
Standby consumption< 0.1W
Dimensions75*45*144mm
Weight320g
ColorGray
Remote ControlYes
Package1x SMSL SANSKRIT 10TH MKIII
1x USB-A to USB-C cable 1.2m
DAC / ADC ChipAK4493S
Max sampling rate768kHz
Max sampling rateDSD512
ColorGray
Remote ControlYes
Équilibré
Très détaillé sans être fatiguant dans le haut du spectre, pas de colorations notables, un grave somptueux déjà présent lorsque alimenté par un simple chargeur 5 Volt, l'association avec l'alimentation LPSU25 Audiophonics, ajoute du punch et un peu plus de matière. La scène sonore peut être très large suivant les enregistrements, belle profondeur également. Une toute petite étoile en moins pour l'alimentation via USB C, qui pour l'instant ne permet pas l'adjonction d'un câble de qualité digne de la LPSU25. SVP Audiophonics Workshop ;)
This review has been posted for SMSL SANSKRIT 10TH MKIII DAC USB AK4493S XMOS XU316 32bit 768kHz DSD512 Gray
SMSL comes back with an updated version of the Sanskrit, the Sanskrit 10Th MKIII, taking back the compact and practical design of the former model...
