SMSL SU-6 DAC ES9038Q2M XMOS Bluetooth 5.0 aptX HD LDAC 32bit 768kHz DSD512 Black
SMSL offers with the SU-6 a powerful and affordable DAC, benefiting from a careful design guaranteeing an accurate sound reproduction.
Reference : 15866
175,00 €tax incl.
145,83 € tax excl.
Last items in stock !
Shipping date: 29-04-2025.
SMSL SU-6
ESS ES9038Q2M DAC
At the heart of the SU-6 is a digital-to-analog conversion chip that converts audio signals with great efficiency. This chip is widely recognized by HiFi enthusiasts. Taking advantage of the HyperStream II 32bit architecture and the Time Domain Jitter Eliminator technology, the ES9038Q2M DAC offers a very clear and transparent reproduction. It also supports high resolution audio streams.
USB XMOS Interface
Another strong point of the SU-6 is its second generation USB XMOS interface. This one allows to take advantage of a USB-C input able to support high sampling rates, up to PCM 32bit 768kHz and DSD512, for a sound of an incredible fidelity.
Bluetooth 5.0
Embedding a Bluetooth 5.0 receiver from Qualcomm, the SU-6 allows you to broadcast your music remotely, from a smartphone or a tablet for example. Moreover, the SU-6 is compatible with the high quality transmission codecs aptX, aptX HD and LDAC, for a restitution equal or superior to CD quality, in wireless.
High quality components
The whole device benefits from a beautiful design, using only audio components. For example, there are four dual OPA1612 PDUs, a clock processing circuit for low jitter and an integrated low noise power supply.
Product typeDAC
Inputs1x USB-C
1x Optical Toslink
1x Coaxial
Bluetooth
Output1x Stereo RCA
DAC chipESS ES9038Q2M
Bluetooth version5.0
Supported Bluetooth codecsSBC, AAC, aptX, aptX HD, LDAC
USB InterfaceXMOS
Supported sampling ratesUSB : PCM up to 32bit 768kHz, DSD up to DSD512
Optical / Coaxial : PCM up to 24bit 192kHz, DSD DoP up to DSD64
USB CompatibilityWindows 7 / 8 / 8.1 / 10
Mac OSX
Linux
USB TransmissionAsynchronous
THD+N0.0001% (-120dB)
Dynamic range125dB
SNR125dB
Output impedance< 10Ω
Consumption5W
Standby consumption< 0.5W
Dimensions140 x 105 x 28mm
Weight350g
Power cableIncluded
DAC / ADC ChipES9038Q2M
Max sampling rate768kHz
Max sampling rateDSD512
Remote ControlYes
7 reviews
Fait le job, mais très très bien
Petit DAC ultra simple ce qui ne l’empêche pas d’être très efficace. Surpris par une qualité de fabrication plus haute qu’attendu. La qualité sonore est excellente. L’essayer c’est l’adopter, pour un prix très compétitif.
This review has been posted for SMSL SU-6 DAC ES9038Q2M XMOS Bluetooth 5.0 aptX HD LDAC 32bit 768kHz DSD512 Black
SMSL SU-6 DAC
Solid DAC
This SU-6 is very nice with excellent build quality. The sound is clear, highly resolving and neutral. The wireless sound using the LDAC codec is also of high quality. I am very impressed with the performance of this DAC.
Fast delivery. The item was securely packaged.
Thanks seller.
Oh my it's AMAZING
Unbelievable audio transfiguration, I connect it to my desktop pc and a SMSL DA-9 amplifier, guys just buy it, you will listen to another universe with that thing!
Bon en avant
Trois jours après être passé d'un S.M.S.L. sanskrit 10th au DAC SU-6 est un véritable bon en avant. Plus de Définition & d'aération - plus de peps dans le Grave et l'ensemble du spectre réellement bien plus Précis.
On touche presque la dynamique - la définition & l'analyse d'une très bonne platine vinyle.
L'alim. intégrée et le gros afficheur (modulable) sont aussi un Plus.
Bref, encore merci Mr D. Aubert pour vos précieux renseignements.
Parfait
Ce sac m a permis de transformer enfin ma vielle cdp-x3000es en drive. Look, perfs, rapport qualité prix nickel.merci audiophonics.
 (3)
