SMSL SU-6 DAC ES9038Q2M XMOS Bluetooth 5.0 aptX HD LDAC 32bit 768kHz DSD512 Silver
SMSL offers with the SU-6 a powerful and affordable DAC, benefiting from a careful design guaranteeing an accurate sound reproduction.
Reference : 15867
175,00 €tax incl.
145,83 € tax excl.
SMSL SU-6
ESS ES9038Q2M DAC
At the heart of the SU-6 is a digital-to-analog conversion chip that converts audio signals with great efficiency. This chip is widely recognized by HiFi enthusiasts. Taking advantage of the HyperStream II 32bit architecture and the Time Domain Jitter Eliminator technology, the ES9038Q2M DAC offers a very clear and transparent reproduction. It also supports high resolution audio streams.
USB XMOS Interface
Another strong point of the SU-6 is its second generation USB XMOS interface. This one allows to take advantage of a USB-C input able to support high sampling rates, up to PCM 32bit 768kHz and DSD512, for a sound of an incredible fidelity.
Bluetooth 5.0
Embedding a Bluetooth 5.0 receiver from Qualcomm, the SU-6 allows you to broadcast your music remotely, from a smartphone or a tablet for example. Moreover, the SU-6 is compatible with the high quality transmission codecs aptX, aptX HD and LDAC, for a restitution equal or superior to CD quality, in wireless.
High quality components
The whole device benefits from a beautiful design, using only audio components. For example, there are four dual OPA1612 PDUs, a clock processing circuit for low jitter and an integrated low noise power supply.
Product typeDAC
Inputs1x USB-C
1x Optical Toslink
1x Coaxial
Bluetooth
Output1x Stereo RCA
DAC chipESS ES9038Q2M
Bluetooth version5.0
Supported Bluetooth codecsSBC, AAC, aptX, aptX HD, LDAC
USB InterfaceXMOS
Supported sampling ratesUSB : PCM up to 32bit 768kHz, DSD up to DSD512
Optical / Coaxial : PCM up to 24bit 192kHz, DSD DoP up to DSD64
USB CompatibilityWindows 7 / 8 / 8.1 / 10
Mac OSX
Linux
USB TransmissionAsynchronous
THD+N0.0001% (-120dB)
Dynamic range125dB
SNR125dB
Output impedance< 10Ω
Consumption5W
Standby consumption< 0.5W
Dimensions140 x 105 x 28mm
Weight350g
ColorSilver
Power cableIncluded
DAC / ADC ChipES9038Q2M
Max sampling rate768kHz
Max sampling rateDSD512
ColorSilver
Remote ControlYes
Bien, bien. Et bien.
J'ai deux Sanskrit mk2, fiables et sans failles, qui m'ont donné une belle confiance en la marque SMSL. Je viens d'acquérir le SU-6 et c'est encore mieux. Logique, je vais continuer à monter en gamme avec SMSL.
C'est hors-sujet mais je l'écris quand même : il y a eu un grand boum de la reproduction sonore autour des années 80, nous traversons un nouvel âge d'or. Vraiment.
This review has been posted for SMSL SU-6 DAC ES9038Q2M XMOS Bluetooth 5.0 aptX HD LDAC 32bit 768kHz DSD512 Silver
