SMSL SU-8S Balanced DAC ES9068AS USB XMOS 32Bit 768kHz DSD512 MQA
The SMSL SU-8s is a symmetrical DAC featuring the new ESS ES9068AS digital to analog conversion chip. This last one supports high sampling rates, up to PCM 32bit 768kHz and DSD512 and ensures a clear and dynamic restitution. This DAC is associated with a USB XMOS XU216 32bit interface, promoting a beautiful sound transparency. Moreover, the SU-8s is also able to read MQA (Master Quality Authenticated) files, allowing to enjoy a sound reproduction as close as possible to the original recording.
By buying this product you get 34 loyalty points
Reference : 15425
349,00 €tax incl.
290,83 € tax excl.
SMSL SU-8s
SMSL SU-8s DAC Symétrique ES9068AS USB XMOS 32Bit 768kHz DSD512 MQA
Displaying a complete connectic panel, the SMSL DAC will adapt to all situations and all systems. We can find in input USB-B, Coaxial, Optical, but also a Bluetooth 5.0 reception. This last one is compatible with the codecs of transmission aptX and aptX-HD, allowing to reach a high sound quality in wireless. Finally, on the output side, the SU-8s offers single-ended RCA and balanced XLR.
Finally, all the components are integrated in a beautiful and robust CNC machined aluminum case with a front panel display for easy and convenient use. It is also delivered with a remote control to control it remotely.
1IR Receiver
2Screen
3Multifunction knob
4Power connector
5Bluetooth antenna
6Optical input
7RCA Output
8USB Input
9Coaxial input
10Balanced XLR output
SMSL SU-8S test by Audio Science Review
"We are so lucky that, despite the low cost of these devices, they continue to compete with each other to snatch the last bit of performance. There's really no fault to be found."
Test du Loxjie A30 par Audio Science Review
Product typeDAC
Inputs1x USB-B
1x Optical
1x Coaxial
Bluetooth 5.0
outputs1x Single-ended stereo RCA
1x Balanced stereo XLR
THD+N0.00009% (-121dB)
Dynamic rangeXLR : 130dB
RCA : 123dB
SNR130dB
Output impedanceXLR : 207Ω
RCA : 142Ω
USB transmission modeAsynchrone
USB compatibilityWindows 7 / 8 / 8.1 / 10
Mac OSX
Linux
Supported sampling ratesUSB : PCM up to 32bit 768kHz, Native DSD up to DSD512
Optical / Coaxial : PCM up to 24bit 192kHz, DSD DoP up to DSD64
Supported Bluetooth codecsSBC, aptX, aptX-HD
Power supply100-240V 50~60Hz (power cable included)
Operating consumption5W
Standby consumption< 0.5W
Dimensions187.5 x 154 x 40mm
Weight0.79kg
SMSL SU-8s DAC Symétrique ES9068AS USB XMOS 32Bit 768kHz DSD512 MQA SMSL SU-8s DAC Symétrique ES9068AS USB XMOS 32Bit 768kHz DSD512 MQA
DAC / ADC ChipES9068AS
Max sampling rate768kHz
Max sampling rateDSD512
Remote ControlYes
2 reviews
SMSL SU-8S
DAC suitable for high-quality active PC speakers.
It doesn't seem like a suitable adept for a large lineup, but absolutely ideal for a PC.
I run it with a Genelec 8330CP speaker via XLR and the sound is fine.
This review has been posted for SMSL SU-8S Balanced DAC ES9068AS USB XMOS 32Bit 768kHz DSD512 MQA
Tiptop.
Je cherchais un DAC avec réglage du volmue et lélécommande, pas cher, AVEC sortie XLR. J'ai vu que ses fonctionalités étaitent plus que complètes. Je l'ai pris.
Il est placé entre 2 sources, et des moiteurs actifs (d'où besoin des sorties XLR !) ; moniteurs actifs pour utilisation "à la maison".
Le SU-8S ne chauffe pas du tout, il est froid en fonctionnement, signe d'un bon design.
Il est tout pti rikiki, et c'en est rigolo car le rendu des Dynaudio Core59 au bout des câbles XLR de 5m (1er prix) est tout l'inverse :-)
La télécommande est un peu directionnelle mais à 6m ca marche nickel sans cafouiller. L''écran du SU-8S est petit, mais à 6m il indique très lisiblement le niveau du volume ; j'ai coché dans les réglages, d'éteindre l'écran au bout de 5s, comme ça il se fait complètement oublié. Simple et efficace ce SU-8S.
Merci Audiophonics de proposer ce pti DAC au RQP au plafond ; et merci pour livraison & service tjs au top.
Cdt
The SMSL SU-8s is a symmetrical DAC featuring the new ESS ES9068AS digital to analog conversion chip. This last one supports high sampling rates,...
