SMSL SU-X DAC 2x ES9039MSPRO
SMSL unveils a state-of-the-art DAC with its SU-X model. The SU-X adopts not only two ESS Technology ES9039MSPRO DAC chips, but also an XMOS XU316 USB interface, enabling it to decode high-resolution PCM 32bit 768kHz and native DSD sampling streams up to DSD512.
4.7 / 5
By buying this product you get 99 loyalty points
Reference : 18626
999,00 €tax incl.
832,50 € tax excl.
Shipping date: 22-04-2025.
SMSL SU-X DAC 2x ES9039MSPRO XMOS XU316 Bluetooth 5.1 aptX LDAC 32bit 768kHz DSD512 MQA-CD
Photo of DAC SMSL SU-X
SMSL unveils a state-of-the-art DAC with its SU-X model. The SU-X adopts two ESS Technology ES9039MSPRO DAC chips, but also an XMOS XU316 USB interface, enabling it to support high-resolution sampling rate PCM 32bit 768kHz and native DSD up to DSD512. It also incorporates an MQA decoder and accepts MQA-CD streams. A high-end Bluetooth 5.1 chip from Qualcomm enables it to decode high-resolution codecs for wireless transmission quality. In terms of aesthetics, the SMSL brand's signature sober, elegant design is evident, with a high-quality aluminum casing and a large IPS color display in tempered glass. The rear panel features full connectivity, with numerous digital inputs including an I2S input via HDMI connector, and two stereo RCA and XLR analog outputs.
SMSL SU-X DAC highlights
SMSL SU-X: two ES9039MSPro DAC chips and XMOS XU-316 USB interface
The SMSL SU-X DAC incorporates two of ESS Technology's flagship ES9039MSPro chips. Two 32bit 8-channel chips specially designed for professional and high-end audiophile applications. These SABRE DAC chips incorporate HyperStream IV architecture. A third-generation XMOS XU316 USB interface completes the chipset for exceptional performance. The SU-X DAC is therefore able to decode high-resolution PCM 32bit 768kHz, DSD DOP64 and native DSD codecs up to DSD512.
Photo of DAC ES9039MSPRO chips
Photo of the MQA decoding process
SMSL SU-X: Support for MQA and MQA-CD streams
The SU-X is also equipped with an MQA decoder, enabling you to enjoy audio files as close as possible to studio recording quality. The SU-X's SPDIF inputs also accept MQA-CD streams.
SMSL SU-X : Bluetooth 5.1
A latest-generation Qualcomm chip enables the SU-X DAC to support high-definition Bluetooth codecs: SBC, AAC, aptX HD and LDAC. This greatly enhances the quality of wireless reception with the SU-X DAC.
Bluetooth functionality of the SMSL SU-X DAC
SMSL SU-X: audiophile-quality components
The SMSL SU-X DAC adopts an eight-channel parallel circuit design, enabling it to achieve an ultra-low distortion level of 0.00005% and a high degree of stability. It also features 21 dual AOPs and a new CK-03 clock processing circuit for considerable jitter reduction. A second PLL eliminates jitter on SPDIF signal transmission. For its power supply, it features two linear power supply groups with several ultra-low-noise regulated power supplies independently supplying clean, stable current to the digital and analog stages of the SU-X DAC.
Photo of DAC SMSL SU-X transformers
A stable, clean power supply
The SU-X's digital and analog stages are powered independently by two linear power supplies.
Photo of SMSL SU-X DAC OPAs
Numerous AOPs
The SU-X incorporates no less than 21 operational amplifiers.
Photo of the SMSL SU-X DAC clock circuit
Optimized clock circuit
The CK-03 jitter reduction clock circuit greatly improves SU-X stability.
Photo of SMSL SU-X DAC connectors
Top-of-the-range connectors
SMSL SU-X connectors are high-end connectors with gold-plated contacts for optimum conductivity and resistance to corrosion and oxidation.
SMSL SU-X: high-end appearance
On the front of the SU-X DAC, a large IPS color display in tempered glass shows information on the current playback track. A large, robust and durable potentiometer is located to the right of the display.
Front view of the SMSL SU-X DAC
Overview of SMSL SU-X DAC connectors
Connector diagram for SMSL SU-X DAC
1IPS color display in tempered glass
2LED indicator
3IR receiver
4Multi-function button
5RCA analog output
6IEC power socket
7USB-B input
8USB-C input
9Toslink optical input
10SPDIF Coaxial input
11I2S input via HDMI
12Bluetooth antenna connector
13AES/EBU input
14Balanced XLR stereo output
Product typeDAC
DAC chip2 x ES9039MSPRO
USB interfaceXMOS XU-316
Inputs1x USB-C input
1x USB-B input
1x Toslink optical input
1x SPDIF coaxial input
1x AES/EBU input
1x I2S input via HDMI
Bluetooth 5.1
Outputs1x Stereo RCA output
1x XLR stereo balanced output
Line output levelRCA : 2.5Vrms
XLR : 5.2Vrms
THD+N0.00005% (-126dB) (un-weighted)
Dynamic rangeRCA : 128dB XLR : 135dB
USB transmissionUSB 2.0 Asynchronous
System compatibility (USB)Windows 7 / 8 / 8.1 / 10 / 11 (with driver)
Mac OSX 10.6 et plus, Linux (without driver)
Supported bluetooth codecsSBC, AAC, aptX, aptX HD et LDAC
Supported sample ratesUSB: PCM 32bit 768kHz, DSD DOP256, DSD512 and MQA.
Toslink optical, SPDIF coaxial, AES/EBU: PCM 24bit 192kHz, DSD DOP64, MQA-CD.
Power consumption< 20W
Standby power consumption< 0.5W
Dimensions250 x51 x 217mm
ColorSilver
Weight2.7kg
Package1x DAC SMSL SU-X
1x Power cable
1x Remote control
Photo of SMSL SU-X DAC measurements
InputI2S via HDMI
InputAES/EBU
DAC / ADC ChipES9039MPro / ES9039MSPro
Max sampling rate768kHz
Max sampling rateDSD512
Max sampling rateMQA
ColorSilver
Remote ControlYes
3 reviews
Bon dac,un peut cher..
En remplacement d'un Do100 pro,il y a effectivement du mieux : on perçois plus de détails dans la musique,image stéréo plus précise,un sentiment de son plus propre.
La ou je reste plus critique : il y a multiples réglages possibles de filtres dsp,oversampling qui a mon sens colire le son de façon artificiel.Je préfère le mode sans filtre.
En sortie rca,j'ai constaté qu'il faut abaisser le niveau de 3 db sinon niveau de sortie trop élevé et fait saturer mon ampli
This review has been posted for SMSL SU-X DAC 2x ES9039MSPRO XMOS XU316 Bluetooth 5.1 aptX LDAC 32bit 768kHz DSD512 MQA-CD
Dac SMSL SU-X
L'équipe d Audiophonics est très réactive que ce soit pour des questions sur des futurs achats ou en sav.
Et je les en remercies.
SMSL SU-X
A peine écouté une heure et déjà un gain en tout sur mon installation.
Magnepan MG12 ampli SABAJ A30A cordon usb B usb A vers PC Deezer Hi-fi qualité 32 bit 384000 Hz.
Un cran au dessus du SABAJ seul que j'aime beaucoup déjà.
Plus de clarté de rapidité une basse plus profonde mais toujours aussi bien tenue.
Encore plus d'informations tout simplement ce qui moi me motive personnellement dans la recherche du son.
Je ne peux que recommander cet appareil qui sonne merveilleusement bien à mes oreilles.
Reste à voir la fiabilité dans le temps.
C'est toujours la même question avec ces fabrications chinoises car celui là est à 1000 euros quand même.
On en attend à ce prix une fiabilité pour quelques années.
SMSL unveils a state-of-the-art DAC with its SU-X model. The SU-X adopts not only two ESS Technology ES9039MSPRO DAC chips, but also an XMOS XU316...
