SMSL VMV D3 Balanced DAC R2R 4x PCM1704 32bit 768kHz DSD512 MQA
SMSL VMV delivers with its D3 a real piece of jewelry, containing a concentrate of technologies within a perfectly thought architecture. The brand offers a high performance R2R DAC, whose digital/analog conversion stage embraces no less than four Burr Brown PCM1704U-J chips, supporting both high resolution streams and delivering an incredibly musical and dynamic sound.
By buying this product you get 349 loyalty points
Reference : 15775
3 499,00 €tax incl.
2 915,83 € tax excl.
SMSL VMV D3
Balanced R2R DAC 4x PCM1704 32bit 768kHz DSD512 MQA
SMSL VMV D3 DAC Symétrique R2R 4x PCM1704 32bit 768kHz DSD512 MQA
SMSL VMV delivers with its D3 a real piece of jewelry, containing a concentrate of technologies within a perfectly thought architecture. The brand offers a high performance R2R DAC, whose digital/analog conversion stage embraces no less than four Burr Brown PCM1704U-J chips, supporting both high resolution streams and delivering an incredibly musical and dynamic sound. The whole device shows a remarkable attention to detail on the part of the brand, wishing to offer audiophiles a high-performance solution.
4x DAC R2R PCM1704U-J
Four copies of the legendary Burr Brown PCM1704U-J DAC chip are in charge of the conversion of the digital audio streams. These R2R, two per channel in a balanced design, allow the SMSL VMV D3 to reveal a magnificent sound reproduction, as musical as precise.
USB XMOS Interface
The D3 DACs are directly associated with a 16-core XMOS XU216 USB interface. This allows to process the USB audio stream efficiently and quickly. It also supports high resolution files up to native DSD512 and PCM 32bit 768kHz for an incomparable precision reproduction.
Accusilicon clocks
The clock system incorporates two Accusilicon ultra-low phase noise oscillators in a PLL arrangement. This design ensures extremely low jitter, resulting in a very pure sound.
CPLD Altera MAX II
These clocks are used in conjunction with an Altera MAX II CPLD, which is responsible for perfectly processing and synchronizing the clock signals for the lowest possible jitter.
Low noise power supply
The power supply stage of the SMSL VMV D3 is not to be outdone since it integrates a custom low noise toroidal transformer, designed in the UK by Noratel. Thus, the power supply stage of the D3 is able to provide a clean and stable electrical signal to all the audio circuits of the device.
Digital filtering
The D3 incorporates a high quality SM5847 hardware digital filter, which is responsible for the oversampling function.
Thought out to the last detail
All the circuits have been optimized and each component carefully selected. Whether it is the seven OPA1612 AOPs, the specially developed low noise discrete components or the power supply regulation, nothing is left to chance to allow the D3 to provide an incredibly rich sound reproduction.
Connectivity
The SMSL VMV D3 is equipped with a complete connectic to adapt to all needs and all HiFi systems. It offers a large panel of inputs, with USB-B, I2S via HDMI, Toslink optical, coaxial and AES/EBU. It also provides a BNC input to take advantage of a dedicated external clock. For its outputs, the SMSL VMV DAC offers both single-ended RCA and balanced XLR.
1Screen
2ON/OFF Button
3Input selector
4RCA Output
5AES/EBU Input
6Coaxial
7Clock input
8optical input
9Power input
10Balanced XLR line output
11I2S Input
12USB-B Input
Un design moderne
All the components are integrated in a beautiful and solid CNC machined aluminum case. The power and audio circuits are physically separated to avoid any interference.
Product typeDAC R2R
DAC Chip4x PCM1704U-J
Inputs1x USB-B
1x OpticalToslink
1x Coaxial
1x AES/EBU
1x Balanced stereo XLR
THD+N0.001%
Dynamic range112dB
SNR112dB
USB transmission modeAsynchronous
USB CompatibilitéWindows 7 / 8 / / 8.1 / 10
Mac OSX
Linux
Supported sampling ratesUSB, I2S : PCM up to 32bit 768kHz, DSD up to DSD512
Optical, Coaxial, AES/EBU : PCM up to 24bit 192kHz
MQA Support
Consumption10W
Standby consumption< 0.8W
Housing materialAluminum
Dimensions280 x 240 x 51mm
Weight3.96kg
Power cableIncluded
Input
  • AES/EBU
  • Optical
  • SPDIF
  • USB
Output
  • RCA
  • XLR
DAC / ADC Chip
  • PCM1704UK
Max sampling rate
  • 768kHz
  • DSD512
  • MQA
Color
  • Black
Networking
  • No
Remote Control
  • Yes
SMSL VMV delivers with its D3 a real piece of jewelry, containing a concentrate of technologies within a perfectly thought architecture. The brand...
