TOPPING D30 PRO Balanced DAC 4x CS43198 32bit 384kHz DSD256 Black
Powerful and compact balanced DAC, the digital-to-analog conversion stage of the Topping D30 Pro is based on no less than four Cirrus Logic CS43198 chips. These enable it to support high sample rates up to 32bit 384kHz PCM and DSD256, while offering incredible performance in terms of distortion level, THD+N and dynamics.
3.7 / 5
Reference : 15169
299,00 €tax incl.
249,17 € tax excl.
Topping D30 Pro
Topping D30 Pro DAC Symétrique 4x CS43198 32bit 384kHz DSD256 Noir
Quad DAC CS43198
The use of four Cirrus Logic CS43198 digital-to-analog conversion chips provides a total of 8 balanced channels. This special design provides the DAC with greater output capacity while improving overall sound quality and measured performance.
XMOS USB Interface
Il D30 Pro utilizza un chip XMOS XU208 a 8 core per la sua interfaccia USB. Questo supporta file ad alta risoluzione fino a 32bit 384kHz PCM e DSD256. Inoltre, il D30 Pro utilizza un driver Thesycon personalizzato per prestazioni ottimali.
Complete connections
The D30 Pro will adapt to any system, with a complete range of inputs: USB-B, Toslink Optical, Coaxial and RCA stereo. It offers both unbalanced stereo RCA and balanced XLR outputs.
High quality components
The Topping D30 Pro benefits from careful design in every respect. It uses an Altera PLC for clock signal processing and eight independent LDOs to provide a clean and stable power supply for the audio circuit.
Topping D30 Pro review by Audio Science Review (Amir)
" Consistent with tradition, Topping D30Pro produces excellent objective resultsNeedless to say, I am happy to strongly recommend the Topping D30Pro DAC. "
Test du Topping D30 Pro par Audio Science Review (Amir)
Product typeDAC
Inputs1x USB-B
1x Optical Toslink
1x Coaxial
1x Stereo RCA
1x Balanced stereo XLR
DAC Chips4x Cirrus Logic CS43198
Sampling ratesUSB : PCM up to 32bit 384kHz
Native DSD up to DSD256, DSD DoP up to DSD128
Coaxial / Optical : PCM up to 24bit 192kHz, DSD64 (DoP)
THD+N @ A-WeightingRCA : < 0.0001% @ 1kHz
XLR : < 0.00009% @ 1kHz
THD @ No-Weighting 45kBwRCA : < 0.0004% @ 20Hz-20kHz
XLR : < 0.0004% @ 20Hz-20kHz
SNR @ A-WeightingRCA : 127dB @ 1kHz
XLR : 132dB @ 1kHz
Dynamic range @ A-WeightingRCA : 127dB @ 1kHz
XLR : 132dB @ 1kHz
Frequency responseRCA : 20Hz-20kHz (±0.1dB) / 20Hz-40kHz (±0.3dB)
XLR : 20Hz-20kHz (±0.1dB) / 20Hz-40kHz (±0.3dB)
Voltage outputRCA : 2Vrms @ 0dBFS
XLR : 4Vrms @ 0dBFS
Noise @ A-WeightingRCA : < 0.9µVrms
XLR : < 1.1µVrms
CrosstalkRCA : -116dB @ 1kHz
XLR : -145dB @ 1kHz
Output impedanceRCA : 20Ω
XLR : 40Ω
Dimensions174 x 138 x 45mm
Weight870g
Housing materialAluminum
Package1x Topping D30 Pro
1x Remote control
1x Power cable
1x USB cable
DAC / ADC ChipCS43198
Max sampling rateDSD256
Max sampling rate384kHz
Remote ControlYes
3 reviews
Substandard product
This DAC does not work with some CD players/transports. According to Topping, this depends on the DAC's hardware. Note that the same CD player works with other DACs, but not with this one. This is a known issue that has been discussed a lot on AudioScienceReview. In my opinion, the D30Pro is therefore a substandard product that should be withdrawn from the market, or at least potential buyers should be informed of this problem before purchase.
Modern dacs weren't really designed with this type of low res source in mind.
Many sources using SPDIF toslink are also problematic (mostly "mass market" devices).
This review has been posted for TOPPING D30 PRO Balanced DAC 4x CS43198 32bit 384kHz DSD256 Black
A very strong contender
I've tried and tested a LOT of cheap/mid-ranged DACs in my time and this has to be one of my all time favorites. It's a nerdy 4 DAC chip design and it presents the most convincing soundstage I've ever heard in any DAC to date. No, it's not perfect in every aspect (nothing is), but at this price point it's damn close to unbeatable. For example, it easily outshines the otherwise appraised Gustard X16 DAC, even though the latter has the upper hand vs the D30 pro when it comes to detail retrieval. A five star rating is given relative to its price - well done, Topping!
son HIFI
je l'ai connecté en XLR à mon topping A90, son précis ,net , qui s'exprime sans retenu avec une puissance bien présente.
les voix sont chaudes ..bon achat
Powerful and compact balanced DAC, the digital-to-analog conversion stage of the Topping D30 Pro is based on no less than four Cirrus Logic CS43198...
