TOPPING D50S DAC 2x ES9038Q2M XMOS U208 Bluetooth 5.0 LDAC 32bit 768kHz DSD512 Silver
The Topping D50s is the direct evolution of the D50, a proven DAC that is particularly appreciated by many customers and audiophiles. While this new model is largely based on the design and architecture of its little brother, the main evolution is in connectivity since the D50s now offers Bluetooth support. The device can now also be controlled via remote control and its audio performance has been revised upwards.
4.8 / 5
Reference : 14046
249,00 €tax incl.
207,50 € tax excl.
Topping D50s
DAC 2x ES9038Q2M Bluetooth aptX LDAC 32bit 768kHz DSD512 XMOS U208 Silver
DAC 2x ES9038Q2M Bluetooth aptX LDAC 32bit 768kHz DSD512 XMOS U208 BlackDAC 2x ES9038Q2M Bluetooth aptX LDAC 32bit 768kHz DSD512 XMOS U208 Black
For the rest, we find all the tip components of the previous version such as two ESS ES9038Q2M conversion chips, a latest generation USB interface module XMOS U208 or OP1612 operating amplifiers, all integrated in a beautiful and robust aluminum housing. Topping once again offers us an extremely qualitative material whose design aims at excellence.
Double ES9038Q2M
The D50s is one of the best components on the market for high quality rendering and an advanced audio experience. Thus, the core of the device is composed of two ESS ES9038Q2M conversion chips operating in parallel so that all channels benefit from a detailed signal and are processed with precision. In addition, these chips, combined with the other components of the device, allow the D50s to support high sampling rates up to PCM 32bit 768kHz, DSD512 and DoP64.
XMOS XU208
For its USB interface, the D50s uses an excellent second generation XMOS XU208 XMOS chip. The brand is renowned for the performance of its components, ensuring accurate and rich reproduction. In addition, this interface allows the USB input of the D50s to support files up to 32bit PCM 768kHz and DSD512.
The D50s comes with drivers Thesycon custom optimized for Windows, providing better support for native DSD. This is therefore a perfectly suitable choice for music lovers who love the very high definition.
Bluetooth 5.0 LDAC
If the D50s is Hi-Res certified, it also benefits from Hi-Res Wireless (wireless) certification as well as Sony LDAC transmission protocol support, ensuring the best performance in terms of bit rate, stability and sampling rates supported for Bluetooth. The Bluetooth 5.0 connectivity of the device is enabled by a CRS8675 chip supporting LDAC, AAC, SBC, aptX, aptXLL and aptX-HD protocols. The Bluetooth stream is decoded by the DAC ES9038Q2M. Bluetooth can be disabled in the D50s menus.
High Performances TI OPA1612 SoundPlus and LME49720 OPA
The D50s is also equipped with two OPA1612 SoundPlus operating amplifiers and a TI LME49720, forming the device's low-pass filter. These PDOs offer excellent performance and ensure lossless signal transmission. The LME49720 operational amplifier is mounted on a DIP8 bracket and can therefore be changed to modify the sound of the device.
CNC Unibody Aluminium Case
All the components of the D50s are integrated in a beautiful and robust Aluminium case, CNC machined in a single metal part. While this case offers a sober and modern aesthetic, it also has very good mechanical properties and greatly limits the impact of interference on the D50s circuits.
Auto On/Off Feature
A practical feature, the D50s is able to switch on and off automatically depending on whether or not it receives a valid signal. Of course, this feature can still be disabled in the device menus. Similarly, the display of the device can be set to turn off after 30 seconds without any action taken, to avoid the visual discomfort that can result from an on screen. The brightness of the screen can also be adjusted.
Easy to use
The D50s has two unique buttons on its front panel to control all the camera's features. The first is a simple button, the second is a 4-way joystick. The device is also delivered with an infrared remote control, allowing remote control.
Complete connectivity
On the connector side, the D50s from Topping offers a complete panel to adapt to the vast majority of uses. It includes Coaxial, Optical, USB and a connector to improve Bluetooth signal reception. At the output the device has a stereo RCA connection.
DAC + Preamplifier function
The D50s is therefore a DAC but also offers an adjustable volume. It can therefore operate as a DAC combo + preamplifier and be directly connected to an amplifier or active speakers.
OTG Compatibility
The Topping D50s supports the OTG standard. It is therefore possible to connect a compatible smartphone or Android tablet to it to send your audio files directly. For iOS devices, it is necessary to use the Camera Adapter Lightning to USB.
Dimensions
Package content
DAC 2x ES9038Q2M Bluetooth aptX LDAC 32bit 768kHz DSD512 XMOS U208 Black<span id=" />
Test du Topping D50s par Audio Science Review
" One of our favorite DACs has grown up and become even better. The D50s solidly eliminates the ESS IMD hump, adds the much needed remote control and Bluetooth without a premium in pricing. "
Product typeDAC
Inputs1x USB-B
1x Optical Toslink
1x Coaxial S/PDIF
Bluetooth 5.0
Output1x Stereo RCA
Supported sampling ratesUSB : PCM up to 32bit 768kHz, Native DSD up to DSD512, DSD DoP up to DSD256
Optical / Coaxial : PCM up to 24bit 192kHz, DSD DoP64
Bluetooth Version5.0
Supported Bluetooth protocolsAAC, SBC, aptX, aptX-LL, aptX-HD, LDAC
Measures (Coaxial input, 96kHz)
THD+N @ A-Weighting< 0.0003% @ 1kHz
<0.0004% @ 10-20kHz
SNR @ A-Weighting> 122dB @ 1kHz
Frequency response20Hz - 20kHz (+/-0.1dB)
Output level2Vrms @ 0dBFS
Noise< 2µVrms
Crosstalk-130dB @ 1kHz
Power supply5V DC 1A (power supply not included / power cable included)
Dimensions11.9 x 11 x 2.6cm
Case materialCNC Machined Aluminium
Weight510g
ColorSilver
Mesures avec Audio Precision
Topping D50s DAC 2x ES9038Q2M Bluetooth aptX LDAC 32bit 768kHz DSD512 XMOS U208 NoirTopping D50s DAC 2x ES9038Q2M Bluetooth aptX LDAC 32bit 768kHz DSD512 XMOS U208 NoirTopping D50s DAC 2x ES9038Q2M Bluetooth aptX LDAC 32bit 768kHz DSD512 XMOS U208 NoirTopping D50s DAC 2x ES9038Q2M Bluetooth aptX LDAC 32bit 768kHz DSD512 XMOS U208 NoirTopping D50s DAC 2x ES9038Q2M Bluetooth aptX LDAC 32bit 768kHz DSD512 XMOS U208 Noir
DAC / ADC ChipES9038Q2M
Max sampling rateDSD512
Max sampling rate768kHz
ColorSilver
Remote ControlYes
4 reviews
Good detailed DAC
I ordered this DAC together with the Topping P50 linear power supply. I have also a Toppin D90 (AKM chip) DAC in my living room and bought this for a smaller room.
Compared to my D90 it has a more analytical 'cooler' sound. I like the D90 a tad more, but that is a matter of personal talste. Also the D90 was much more expensive. This is still a very good DAC for the price though. Therefore I give it 4 stars.
This review has been posted for TOPPING D50S DAC 2x ES9038Q2M XMOS U208 Bluetooth 5.0 LDAC 32bit 768kHz DSD512 Silver
Experience
With 2xOPA827 amazing DAC
Great DAC
This is my second D50s, already purchased a black one so my initial review is there. After several months of use I can still safely recommend this device for its features, sound and small footprint. Completely free of any background noise working on a 10$ mobile phone charger. No clicking/popping/needle dropping on sample rate or PCM/DSD change except 384KHz where it makes a loud click on switching, but I really don't have anything recorded with such a frequency. BT also works flawlessly and you can even turn it off. Replaced its buffer opamp with AD797, OPA627, OPA1622, and it sounds different with each of these. OPA627 gives emphasis to the bass while OPA1622 gives emphais to the details and vocals. AD797 also colors the sound in very positive way, at least to my ears.
God details but cold sound.
I gave 5 star to the Audiophonics aftersale. The dac don't meet my taste, it's full detailed with a wide scene but the sound isn't emotional. I returned the Topping and I put back in the system my old dual AK4399, it's a DIY kit like the Audiophonics DAC Module AKM AK4495SEQ. The voices are more realistic compared to the sabre.
The Topping D50s is the direct evolution of the D50, a proven DAC that is particularly appreciated by many customers and audiophiles. While this...
