The Topping D70 Pro DAC features many of the refinements of a high-end audio product. With high-performance chips, ultra-low jitter clocks, the latest interfaces and great versatility, this converter offers exceptional audio reproduction, characterised by magnificent transparency and richness of sound while offering practical and useful features.
The ES 9039SPro DAC chip from ESS is the current flagship of the brand, allowing an efficient and precise decoding. This chip allows it to reach a THD+N lower than 0.00008% @ 1Khz and a dynamic range of 128 db on the RCA output as well as a THD+N of 0.00006% @ 1Khz and a dynamic range of 133dB for the XLR output.
Moreover, these chips support high sampling rates, allowing you to enjoy your PCM files up to 32bit 768kHz and DSD up to DSD512 Native.
The D70 Pro features a new converter to achieve excellence in audio reproduction. This circuit design allows for very low distortion and noise.
This DAC supports the best Bluetooth formats such as LDAC, aptx-Adaptive and apt XHD. High resolution files can be transmitted to it for a superb listening experience, all with the convenience of wireless.
The power of the D70 Pro ensures a very rich and detailed level of sound reproduction.
The D70 Pro has a wide system compatibility; Windows 10, Windows 11, Mac OS, Linux, IOS, Android. Just connect it to your audio source and start playing music. The USB plug is based on the XMOS XU316 chip and a custom Thesycon driver and is therefore very stable.
A driver and a parameterization is necessary for the ASIO application on windows.
With its multitude of features and connections, the D70 PRO from Topping will fit into the vast majority of audio systems, offering many options for use and installation. On the input side, the device offers AES/EBU, Coaxial SPDIF, Optical Toslink and USB.
On the output side, we find balanced XLR and unbalanced RCA. The D70 PRO allows you to select the output so as to send the audio stream only on one of them or on both at the same time.
In addition, the XLR 4V and RCA 2V outputs can be boosted to XLR 5V and RCA 2.5V.
1 | Color display screen |
2 | Menu screen button |
3 | Volume control |
4 | Balanced stereo XLR output |
5 | Stereo RCA output |
6 | Coaxial input |
7 | Optical Toslink Input |
8 | Bluetooth antenna |
9 | USB-B input |
10 | AES/EBU input |
11 | 12V Trigger |
12 | IEC socket/Power switch |
The D70 PRO also provides the function of a preamplifier since it has a volume controller. This volume control function can however be deactivated in order to be able to use the D70 Pro only as a DAC with output levels constantly at their maximums, i.e. 4Vrms for the XLR output and 2Vrms for the RCA output.
The D70 Pro allows you to switch from one mode to another easily. So you can switch from the default mode to the valve mode or the transistor mode quickly and enjoy a different listening experience. If you want to experiment with other types of sounds you can also adjust the different timbres to your taste.
This function allows the D70 PRO to be controlled or to control other devices in order to turn on and off simultaneously.
A new color screen is integrated in the D70 Pro as well as 3 control buttons for a better experience. Moreover this screen can display some information (FTT and VU) according to your needs and desires.
1 | ON/OFF button |
2 | Volume + |
3 | Previous source |
4 | Volume - |
5 | NC |
6 | Filter selection |
7 | Automatic power on |
8 | Mute mode |
9 | Output mode selection |
10 | Next source |
11 | NC |
12 | NC |
13 | Brightness screen adjustment |
"I'm pleased to recommend the Topping D70 Pro Sabre stereo DAC. Not only does it perform well, but it also has the key features you'd expect from a DAC (such as a spectrum analyzer, for example)."
Specifications | ||
Product type | DAC | |
DAC Chip | ES9039SPRO | |
USB interface | XMOS XU316 | |
Input | 1x Optical Toslink 1x USB-B 1x Coaxial SPDIF 1x AES/EBU Bluetooth | |
Supported sampling rates | USB: PCM Up to 32bit 768kHz / DSD Native Up to DSD512 / DSD DoP Up to DSD256 Coaxial, Optical, AES: PCM Up to 24bit 192kHz | |
Supported Bluetooth codecs | Bluetooth : SBC, ACC, LDAC,aptX, aptX HD, aptX Adaptative | |
Ouput | 1x XLR balanced 1x RCA unbalanced | |
THD+N | RCA : <0.00008% @ 1kHz A-Weighted XLR : <0.00006% @ 1kHz A-Weighted | |
THD @ 90Bw (Not Weighted) | RCA : <0.0004% @ 20-20kHz XLR : <0.0002% @ 20-20kHz | |
SNR | RCA : 128dB @ 1kHz A-Weighted XLR : 133dB @ 1kHz A-Weighted | |
Dynamic Range | RCA : 128dB @ 1kHz A-Weighted XLR : 133dB @ 1kHz A-Weighted | |
Fréquency response | RCA : 20Hz - 20kHz (+/-0.5dB) / 20Hz - 40kHz (+/-0.2dB) XLR : 20Hz - 20kHz (+/-0.2dB) / 20Hz - 40kHz (+/-0.2dB) | |
Output voltage | RCA : 2.1Vrms @ 0dBFS (4V Mode) / 2.5Vrms @ 0dBFS (5V Mode ) XLR : 4.2Vrms @ 0dBFS (4V Mode) / 5Vrms @ 0dBFS (5V Mode ) | |
Noise | RCA : <1.0µVrms XLR : <1.0µVrms | |
Channel crosstalk | RCA : -128 dB @ 1Khz XLR : -140 dB @ 1Khz | |
Channel balance | RCA : 0.3dB XLR : 0.3dB | |
Output impedance | RCA : 50 Ohms XLR : 100 Ohms |
General | ||
Power supply | 100V-220V AC 50Hz/60Hz via IEC (cable supplied) | |
Housing material | Aluminium | |
Dimensions | 22.2 x 17.6 x 4.8cm | |
Weight | 1.9kg | |
Color | Silver | |
Package | 1x Topping D70 PRO 1x IR remote control 1x USB cable 1x Power cable 1x Bluetooth Antenna 1x Manual 1x Warranty card |
Input | SPDIF |
Input | Bluetooth |
Input | USB |
Input | Optical |
Input | AES/EBU |
Output | RCA |
Output | XLR |
DAC / ADC Chip | ES9039MPro / ES9039MSPro |
Max sampling rate | 768kHz |
Max sampling rate | DSD512 |
Color | Silver |
Networking | No |
Remote Control | Yes |
