TOPPING D70S MQA Balanced DAC 2x AK4497 I2S XMOS Bluetooth 5.0 LDAC 32bit 768kHz DSD512 Silver
The Topping D70S MQA is an extremely versatile and powerful balanced digital to analog converter. With its careful design and intelligent architecture, it offers a realistic, rich and lively sound reproduction, while providing full connectivity.
By buying this product you get 64 loyalty points
Reference : 15002
649,00 €tax incl.
540,83 € tax excl.
Topping D70S MQA
Balanced DAC 2x AK4497 I2S XMOS Bluetooth 5.0 LDAC 32bit 768kHz DSD512 Black
Topping D70S MQA DAC Symétrique 2x AK4497 Bluetooth 5.0 LDAC I2S XMOS 32bit 768kHz DSD512
MQA Support
The D70S MQA supports Master Quality Authenticated (MQA) files. These allow you to enjoy sound reproduction as close as possible to the original recording in the studio, while still being light enough to be played back for broadcast.
Dual AKM AK4497 DAC
The D70S MAQ's digital-to-analog conversion stage has two AKM AK4497 DAC chips, one DAC chip per channel. This architecture provides better channel separation, while ensuring optimized overall performance, including extremely low THD+N.
Bluetooth 5.0
Incorporating a Qualcomm CSR8675 chip, the D70S MQA features Bluetooth 5.0 reception, allowing you to stream your music remotely. The chip supports the standard SBC and AAC codecs, as well as the high-definition codecs aptX, aptX LL, aptX HD and LDAC, providing much higher quality playback. In addition, the DAC on the Qualcomm CSR8675 chip is not used here, as conversion is performed by the two AK4497 converters.
USB XMOS Interface
The USB input of the D70S is associated with a 16-core XMOS XU216 interface chip, supporting PCM audio streams up to 32bit 768kHz, DSD Native up to DSD512, as well as MQA decoding. A custom Thesycon driver is used, to enable the best playback performance via ASIO.
AK4118 Digital Receiver
The SPDIF inputs are associated with an AK4118 digital receiver chip. The latter allows very low jitter while supporting sample rates up to PCM 24bit 192kHz.
CPLD & Accusilicon Clocks
The D70S MQA uses an Altera MAX II CPLD. This takes care of the signal processing of the Accusilicon femtosecond clocks and signal optimization. This combination of CPLD and Accusilicon clocks allows an extremely low jitter level to be achieved, while perfectly synchronizing the digital signal processing and optimization for better signal quality and stability.
A more than complete connection system
The D70S MQA offers a wide range of connectors to meet all needs. These include AES/EBU, USB-B, Bluetooth 5.0, Optical, Coaxial and I2S. The USB and I2S inputs support high-resolution files up to PCM 24bit 768kHz and native DSD512. The Bluetooth input is compatible with the LDAC transmission codec, allowing support for 24bit 96kHz files.
Topping D70S MQA also allows to select the active outputs. It is thus possible to use only the balanced XLR output, the unbalanced RCA output or to output on both at the same time.
1Balanced XLR output
2Single-ended RCA output
3I2S HDMI input
4Bluetooth antenna connector
5Optical Toslink input
6Coaxial input
7USB-B input
8AES/EBU input
9Power connector
10Power button
Highly compatible I2S LVDS input
The D70S MQA's HDMI I2S input has several settings, making it compatible with most I2S interfaces. The "IIS Phase", "IIS DSDR" and "DSD FLAG" parameters can be adjusted.
5.1Power button
5.2Volume +
5.3Previous input
5.4Volume -
5.5NC
5.6Filter selection
5.7Auto standby
5.8Mute
5.9Output selection
5.10Next input
5.11NC
5.12NC
5.13Brightness setting
A switch on the back of the unit allows you to select the input voltage between 230V AC and 115V AC. Before connecting the appliance and switching it on, be sure to select the input voltage that corresponds to the voltage delivered by your power supply network.
Topping D70S MQA review by Audio Science Review
" Another stellar DAC is released by Topping in the form of D70s giving us another option to purchase. Instrument grade performance is provided. Yes, our tests are so good that even in best of the best we can expose a few tiny rough corners. But in the larger picture it is hard to hold back anything but top praise for this level of engineering. "
Test du Topping D70S MQA par Audio Science Review
Product typeBalanced DAC
Inputs1x I2S LVDS HDMI
1x USB-B
1x Optical Toslink
1x SPDIF Coaxial
1x AES/EBU
Bluetooth 5.0
Outputs1x Balanced XLR
1x Single-ended RCA
Supported sampling ratesUSB : PCM up to 32bit 768kHz, Native DSD up to DSD512, DoP up to DSD256, MQA up to 32bit 384kHz
I2S : PCM up to 32bit 768kHz, Native DSD up to DSD512
Coaxial / Optical / AES : PCM up to 24bit 192kHz
Supported Bluetooth codecsAAC, SBC, aptX, aptX LL, aptX HD, LDAC
Measurements @ USB In, 96kHz
RCA line outputXLR line output
THD+N @ A-Weighting, 20kBw, volume = -2dB< 0.00015% @ 1kHz< 0.0001% @ 1kHz
THD @ No-Weighting, 90kBw, volume = -2dB< 0.0004% @ 20Hz-20kHz< 0.0002% @ 20Hz-20kHz
SNR @ A-Weighting124dB @1kHz127dB @ 1kHz
Dynamic range @ A-Weighting124dB @1kHz127dB @ 1kHz
Frequency response20Hz - 20kHz (±0.1dB)
20Hz - 40kHz (±0.3dB)
Output voltage2.5Vrms @ 0dBFS5Vrms @ 0dBFS
Noise @ A-Weighting< 1.3µVrms< 2µVrms
Output impedance100Ω200Ω
Power supply100-240VAC (switchable, power cable included)
Dimensions25 x 19.5 x 5cm
Housing materialAluminum
ColorSilver
Package1x Topping D70S MQA
1x Remote control
1x USB cable
1x Power cable
1x Bluetooth antenna
InputAES/EBU
InputI2S via HDMI
DAC / ADC ChipAK4497EQ
Max sampling rateDSD512
Max sampling rate768kHz
ColorSilver
Remote ControlYes
Topping
product very good quality, great sound, i am very satisfied.
This review has been posted for TOPPING D70S MQA Balanced DAC 2x AK4497 I2S XMOS Bluetooth 5.0 LDAC 32bit 768kHz DSD512 Silver
The Topping D70S MQA is an extremely versatile and powerful balanced digital to analog converter. With its careful design and intelligent...
