By buying this product you get 79 loyalty points
Balanced DAC ES9038Pro 32bit 768kHz DSD512 Silver
The Topping D90LE is a high-end DAC, benefiting from an intelligent and careful design for high performance. It features an ESS ES9038Pro conversion chip, an XMOS interface and an Altera Max II CPLD. The D90LE is also versatile, with a complete connectivity and an integrated Bluetooth receiver.
D90LE
D90SE
MQA Decoding
No
Yes
MQA Logo
No
Yes
The D90LE features an ESS Sabre ES9038Pro DAC chip, using the 32-bit HyperStream architecture to achieve an extremely high level of performance for incredibly accurate and transparent sound reproduction.
The D90LE performs independent I/V (current/voltage) conversion for the 8 channels of the ES9038Pro and then connects them in parallel. This technique allows for an ever increasing level of performance.
Equipped with a Qualcomm CSR8675 chip, the D90LE offers Bluetooth 5.0 reception, convenient for remote music streaming directly from your smartphone. In addition, this chip supports the codecs aptX, aptX HD, aptX LL and LDAC, allowing to achieve a high quality sound in wireless.
The USB input of the D90LE uses a 2nd generation XMOS XU2013 16-core chip. This chip supports high sampling rates, up to 32bit 768kHz PCM and DSD512, as well as MQA. This chip is associated with a custom Thesycon driver.
The D90LE benefits from a complete range of connectivity to adapt to all systems. We can find AES, USB-B, Optical, Coaxial, I2S LVDS via HDMI as well as Bluetooth 5.0 connectivity. For its outputs, the D90LE offers single-ended RCA and balanced XLR.
The D90LE offers a selectable output system. The audio stream can be routed to the XLR output, the RCA output or both. Moreover, it also allows to choose an output level. Thus, the XLR output can work in 4V or 5V and the RCA output in 2V or 2.5V.
In addition to the DAC mode with a fixed output level, the D90LE offers a DAC + preamplifier mode. In this mode, you can control the volume level. Thus, the D90LE can be directly associated with a power amplifier or active speakers.
The Topping D90LE uses an Altera Max II CPLD to process the clock signal and thus optimize the quality of digital signals, significantly reducing jitter.
" It is not every day that every barrier we have seen in DACs gets shattered to new levels. We are seeing extreme attention to every aspect of this design to squeeze this much performance out of this ESS DAC. Just when we though the race was over, here comes one more over achiever! "
| Specifications | |
| Product type | Balanced DAC |
| Inputs | 1x USB-B 1x AES 1x Coaxial 1x Optical Toslink 1x I2S LVDS via HDMI Bluetooth 5.0 |
| Outputs | 1x Stereo RCA 1x Stereo XLR |
| DAC Chip | ESS ES9038Pro |
| USB interface | XMOS XU216 |
| Supported Bluetooth codecs | SBC, AAC, aptX, aptX LL, aptX HD, LDAC |
| Supported sampling rates | PCM up to 32bit 768kHz DSD up to DSD512 |
| RCA Line out measurements @ USB, 96kHz | |
| THD+N @ A-Weighting | < 0.00007% @ 1kHz |
| THD @ No-Weighting, 90kBw | < 0.0008% @ 20Hz-20kHz |
| SNR @ A-Weighting | 127dB @ 1kHz |
| Dynamic range @ A-Weighting | 127dB @ 1kHz |
| Frequency response | 20Hz-20kHz (±0.1dB) 20Hz-40kHz (±0.3dB) |
| Output level | 2.1Vrms @ 0dBFS (Mode 4V) 2.6Vrms @ 0dBFS (Mode 5V) |
| Noise @ A-Weighting | < 1.3µVrms |
| Crosstalk | -124dB @ 1kHz |
| Channel balance | 0.3dB |
| Output impedance | 100Ω |
| XLR Line out measurements @ USB, 96kHz | |
| THD+N @ A-Weighting | < 0.00005% @ 1kHz |
| THD @ No-Weighting, 90kBw | < 0.0003% @ 20Hz-20kHz |
| SNR @ A-Weighting | 134dB @ 1kHz |
| Dynamic range @ A-Weighting | 134dB @ 1kHz |
| Output level | 4.2Vrms @ 0dBFS (Mode 4V) 5.2Vrms @ 0dBFS (Mode 5V) |
| Noise @ A-Weighting | < 1.1µVrms |
| Crosstalk | -139dB @ 1kHz |
| General | |
| Dimensions | 222 x 160 x 45mm |
| Package | 1x Topping D90LE Silver 1x IR Remote control 1x USB cable 1x Bluetooth antenna 1x Power cable |
| Input | Optical |
| Input | I2S via HDMI |
| Input | SPDIF |
| Input | Bluetooth |
| Input | AES/EBU |
| Input | USB |
| Output | RCA |
| Output | XLR |
| DAC / ADC Chip | ES9038PRO |
| Color | Silver |
| Networking | No |
| Remote Control | Yes |
