TOPPING DX3 Pro DAC 2x AK4493EQ XMOS XU208 32bit/768kHz Headphone amplifier Bluetooth apt-X HD Black
Topping's DX3 Pro fulfills both functions of DAC and headphone amplifier. It offers excellent performance when connected to a digital source by wire or Bluetooth. Multiple operating modes available support an integration into a more complex chain as well.
Reference : 13453
219,00 €tax incl.
182,50 € tax excl.
Topping DX3 Pro DAC & Headphone Amplifier
XMOS XU208, Duo AK4493EQ, OPA1612 / 768kHz 32-bit DSD512 native / Bluetooth apt-X HD
DX3 Pro Topping
Compact DAC with many features
Its traditional use is that of a DAC + headphone amplifier. An additional line output is available and allows a connection with analog devices such as active speakers. Conversely, it is also possible to disable the preamplifier stage, which isolates the DAC signal in order attack an external preamplifier.
High-fidelity components
Definitely designed for high fidelity, the DX3 Pro only integrates components recognized for their audio performance.
As USB interface, a U208 XMOS chip drives the USB input. The latter supports high-frequency digital audio streams and offers a native DSD compatibility as well.
The digital to analog conversion is processed by two AK4493EQ 32-bit DAC chip. This is a modernised version of the AK4490EQ which enjoys a distortion and a signal to noise ratio more favorable than its parent while retaining all the technologies that have established its success. It includes the famous Velvet Sound with increasingly accurate digital filters.
DX3 works with high accuracy and low harmonic distortion OPA1612 operational amplifier. This OPA brings precise and fine sound thanks to its low electronic noise (1.1-nV / √Hz) and low distortion (0.000015% @ 1kHz). This model especially offers a swing of 600mV at a load of 2 kΩ, which enables the DX3 to drive most advanced heaphones while providing large dynamic range, stable gain and wide headroom to preserve THE spatial depth of your high-definition music.
Unpacking and features detail
Video French / English
Connectivity
Connectivity Topping DX3PRO
The DX3 Pro is equipped with a USB input 32bit768kHz (XMOS U208), two coaxial inputs and an input optics 24bit192kHz (AK4493EQ).
As output, the DX3 Topping displays a 3.5mm jack and a line-out. The output stage develops 2x1000mW @ 32Ω or 2x125mW @ 3000Ω.
The distant connectivity is not left behind since the device is equipped with a Bluetooth receiver which supports SBC ACC, apt-X, apt-X II, apt-X HD.
Remote control included
Remote control Topping DX3. Pro
The DAC DX3 Topping is delivered with a black compact remote. The latter allows to remotely control the volume, select tracks, outputs, filters...etc.
This remote support is one of the few devices to combine function & DAC Preamplifier / remote control headphone amplifier in this price range.Thanks to this remote control compatibility, Topping's DX3 pro is one of the few devices from this price range to combine function of DAC, Preamplifier, headphone amplifier and remote control.
Test by Audio Science Review
Audio Logo science review
The DX3 Pro was the subject of a detailed comparative analysis on the part of the platform of Audio Science Review studies (in English).
Click here to access it.
TypeDAC
headphone amplifier
DAC chip2x AK4493
SPDIF ChipAK118
OPAOPA1612
OPA2140
InputsOptical
Coaxial
Bluetooth
USB-A
Outputs3.5mm (headphone)
RCA line output
Bluetooth SupportSBC / ACC / apt-X / apt-X II / apt-X HD
Headphone Output Power2x1000mW @ 32Ω
2x125mW @ 300Ω
Output level2Vrms @0dBFS
THD+N<0.0004% @ 1kHz
<0.0005% @ 20Hz-20kHz
Frequency response20Hz-20kHz (+/- 0.35dB)
SNR>120dB @ 1kHz
Output ImpedanceLess than 0.1Ω
Dimensions120 x 165 x 40mm
Power SupplyDC15V 1A via Jack DC 5.5/2.1mm
Parts supplied
DX3 PRox1
Power Supply 15VDC 1A via Jack DC 5.5/2.1mmx1
USB cablex1
Bluetooth antennax1
Remote control (Battery CR2032)x1
OutputJack 3.5mm
6 reviews
yannick
Tres bon DAC , le materiel TOPPING me surpprent toujours.
This review has been posted for TOPPING DX3 Pro DAC 2x AK4493EQ XMOS XU208 32bit/768kHz Headphone amplifier Bluetooth apt-X HD Black
Superbe combo
Je venais de commander mes enceintes et ampli après ecoute en auditorium. ( Elipson Facet 14F et Atoll In100). J'étais principalement à la recherche d'un outil me permettant d'écouter des musiques via mon smartphone en Bluetooth Aptx. Sur les conseils d'un ami ( merci Peter), j'ai acheté ce petit appareil faisant à la fois bluetooh et Dac ( et d'autres comme usb / casque ... que je n'utilise pas encore).
Je suis - poir cette utilisation - tres satisfait. Le bluetooth ne présente aucune perte alors que je suis en wifi avec la console et le smartphone. Surtout, le rendu son est vraiment bon : basses, batteries et voix. La telecommande fonctionne également parfaitement ( pile fournie).
 (3)
topping dx3 pro
amazing product top sound quality, arrived in perfect condition, great service thank you
TOPPING DX3 Pro...really good product.
I was looking to improve the sound of my system based on an integrated amplifier Yamaha CA-800 plus a couple of Epicure 10 (2 ways speaker) both coming from the '70s connected via DAC (USB Sound Blaster external card) to a Lenovo T420 Win7 with a JRiver player. The sound improve really a lot, deeper bass and more defined mid range tones. Even as a headphone amplifier there's no compare with my previous DAC. The quality of service from Audiophonics has been very good (fast shipment, clear & good communication). Happy with my new DX3 Pro!
Great little dac/amp
A great looking device that feels and sounds great!
Recommended!
Topping's DX3 Pro fulfills both functions of DAC and headphone amplifier. It offers excellent performance when connected to a digital source...
