TOPPING DX3 PRO V2 DAC 2x AK4493EQ Headphone Amplifier TPA6120A2 Bluetooth LDAC XMOS XU208 32bit 768kHz Silver
The DAC combo and headphone amplifier DX3 Pro from Topping returns in a revised and improved V2, benefiting in particular from new practical features and ensuring even better audio performance. However, it takes up the excellent base of its older brother in order to offer an efficient and affordable device.
By buying this product you get 23 loyalty points
Reference : 14049
239,00 €tax incl.
199,17 € tax excl.
This product is now replaced by the Topping DX3Pro+.
Topping DX3 Pro V2
DAC 2x AK4493EQ Headphone Amplifier TPA6120A2 Bluetooth LDAC XMOS XU208 32bit 768kHz DSD512 Silver
DAC 2x AK4493EQ Amplificateur Casque TPA6120A2 Bluetooth LDAC XMOS XU208 32bit 768kHz DSD512 ArgentDAC 2x AK4493EQ Amplificateur Casque TPA6120A2 Bluetooth LDAC XMOS XU208 32bit 768kHz DSD512 Argent
Bluetooth 5.0 LDAC
If the DX3 Pro already had Bluetooth connectivity, it is enhanced in this V2. The CSR8675 chip offers Bluetooth in version 5.0 and supports, in addition to aptX and aptX-HD for high audio quality, LDAC, which allows 24-bit file playback. In addition, the internal DAC of the CSR8675 chip is not used. This is directly linked to the two AK4493 DACs, which are much more efficient, for digital/analog decoding.
USB XMOS XU208
The XMOS XU208 chip used for the USB interface of the DX3 Pro V2 supports files with high sampling rates. Thus, using this USB input it is possible to enjoy PCM files up to 32bit 768kHz and up to DSD512 Native. Topping also took the time to offer a custom version of the Thesycon USB driver to ensure better compatibility with computers running Windows.
Dual AK4493 DAC
The heart of the DX3 Pro V2 is most certainly its digital-to-analog conversion stage. It uses two AKM AK4493EQ chips, one per channel, which greatly contributes to the audio performance of the device and also allows it to support high sampling rates.
S/PDIF AK4118 Receiver
On the S/PDIF Coaxial and Toslink Optical inputs side, the DX3 Pro V2 uses an excellent AKM AK4118 receiver chip to get the most out of these connectors, supporting PCM sampling rates up to 24bit 192kHz.
DAC + Preamplifier Application
The DX3 Pro V2 offers the possibility to be used as a DAC combo and preamplifier to be associated with an amplifier or active speakers. To do this, simply set the output mode to preamplifier. The signal is decoded by the DAC section of the DX3 Pro V2 and the volume level can be adjusted directly via the front panel button or the supplied remote control.
TPA6120A2 Headphone Amplifier
The DX3 Pro V2 also features a very good headphone amplification stage based on a TPA6120A2 chip. It allows to develop a power of 2x 700mW under 32Ω or 2x 125mW @ 300Ω allowing the DX3 Pro V2 to accompany a very large majority of headsets. In addition, the gain is selectable, in 0dB or 9dB.
Remote control
1Auto ON/OFF
2Filter selection
3Headphone output
4Volume -
5Previous input
6Volume +
7Power button
8Screen brightness
9Gain setting
10Line output
11Next input
12Dual line + headphone output
13Mute mode
DAC 2x AK4493EQ Amplificateur Casque TPA6120A2 Bluetooth LDAC XMOS XU208 32bit 768kHz DSD512 ArgentDAC 2x AK4493EQ Amplificateur Casque TPA6120A2 Bluetooth LDAC XMOS XU208 32bit 768kHz DSD512 ArgentDAC 2x AK4493EQ Amplificateur Casque TPA6120A2 Bluetooth LDAC XMOS XU208 32bit 768kHz DSD512 ArgentDAC 2x AK4493EQ Amplificateur Casque TPA6120A2 Bluetooth LDAC XMOS XU208 32bit 768kHz DSD512 Argent
Product typeDAC and Headphone amplifier
Inputs1x USB-B (XMOS XU208)
1x Optical Toslink
2x S/PDIF Coaxial
Bluetooth
Outputs1x Stereo RCA Line Output
1x Jack 3.5mm Headphone Output
DAC Output, USB 96kHz Input Measurements
THD+N @ A-Weighting< 0.0004% @ 1kHz
< 0.0005% @ 20Hz-20kHz
SNR @ A-Weighting> 120dB @ 1kHz
Frequency response20Hz - 20kHz (+/-0.35dB)
Output level2Vrms @ 0dBFS
Noise< 2µVrms
Crosstalk-135dB @ 1kHz
Channel balance< 0.1dB
Output impedance100Ω
Headphone output, USB 96kHz Input Measurements
THD+N @ A-Weighting< 0.001% @ 1kHz, Output = 77mW (32Ω)
< 0.002% @ 20Hz - 20kHz, Output = 77mW (32Ω)
< 0.0006% @ 1kHz, Output = 13.4mW (300Ω)
< 0.0006% @ 20Hz - 20kHz, Output = 13.4mW (300Ω)
Frequency response20Hz - 20kHz (+/-0.2dB)
Output level5.8Vpp @ G=0dB
17.3Vpp @ G=9dB
Noise< 3µVrms @ G=0dB
< 7µVrms @ G=9dB
Crosstalk-70dB @ 1kHz
Channel balance0.5dB
Output impedance< 10Ω
Output power700mW x 2 @ 32Ω, THD+N < 1%
125mW x 2 @ 300Ω, THD+N < 1%
Alimentation15VDC 1A (power supply included)
Case materialAluminium
Dimensions120 x 165 x 40mm
Weight400g
ColorSilver
Package1x Topping DX3 Pro V2
1x Bluetooth Antenna
1x Remote Control
1x USB Cable
1x Power supply
OutputJack 3.5mm
ColorSilver
Remote ControlYes
2 reviews
un modèle de neutralité
Un peu froid à la première écoute , il fait la transition de mon premier dac, un FIIO Q1 II, et nécessite un temps d'adaptation un peu long pour finalement faire apparaitre son potentiel; une fidélité sans fioriture.
l'utilisation en ampli casque est satisfaisante, avec un AKG K371 casque on ne peut plus neutre, l'écoute est vraiment très réussi.
pour ma part je ne m'embête pas avec la sortie ligne et branche mes différents amplis sur la sortie casque, rien a redire, juste le volume à monter à -10db, niveau de sortie amplement suffisant.
Côté fiabilité j'espère que la prise jack sortie casque tiendra le choc au vu des nombreux changements que j'effectue (2 amplis + plusieurs casques).
le relais de la sortie son m'a fait un petit caprice en refusant de se connecter au démarrage, puis tout est rentré dans l'ordre après plusieurs redémarrages, depuis plus de problème.
Le seul petit reproche que je me permettrait est celui du gain réglable certes, mais pas vraiment progressif, on passe de 0db à +9db, une position intermédiaire aurait permis plus de modulation, ceci dit à +9db cela convient.
je suis globalement très satisfait de ce petit dac ampli casque qui a, je dirais, tout d'un grand.
sa neutralité exemplaire, dénué de toute coloration, satisfaira l'oreille des puristes.
en attendant d'essayer un de ses grands frères...
This review has been posted for TOPPING DX3 PRO V2 DAC 2x AK4493EQ Headphone Amplifier TPA6120A2 Bluetooth LDAC XMOS XU208 32bit 768kHz Silver
Marc . 06
Excellent appareil qui tient ses promesses. La musicalité est là : l'utilisation des processeurs AKM 4493 EK est une évolution et une amélioration des AKAM 4490 réputés pour leur musicalité et utilisés dans certains amplis Haut de Gamme chez Marantz ,Denon ,Onkyo, etc...( voir sur le site de Asahi Kasei)
A noter les entrées nombreuses et variées qui permettent pratiquement tout les branchements.
Lisez attentivement le mode d'emploi, certaines fonctions ne sont opérationnelles qu'après (1 petit "reset")la mise en marche suivante:
1) Appui sur le bouton cranté de façade;2) Insert du jack de l'alimentation….accès aux réglages.
En mode DAC ,l'affichage permet de contrôler la fréquence de sortie de vos fichiers numériques et de vos appareils.
Exemples constatés:
-Samsung Galaxie 7:la carte Son permet la sortie des fichiers son jusqu' à 24bits 192 khz( Le DX3 affiche 192 khz en permanence)
-Portable Asus Zenbook 13.3 pouces Full HD I7 ou I5 carte son limitée à 48 khz : Les fichiers en 24/ 96 khz ne sortiront qu'en 24/48!!
Surprise donc selon vos appareils;leDX3 vous montre leurs limites!
Pour l 'entrée Wireless la qualité reproduite sera évidemment fonction de l'appareil émetteur pour profiter de l'APTx-HD ou du LADC..
Mes essais casques ont été effectués avec :
- Beyer Dynamics DT 1990 PRO (250 ohms) qui est la version pro de l'"AMIRON" HI-res(seul la présentation change) - Technologie TESLA.
- Audio Technica ATH-SR5 (HI-RES) Excellent petit casque fermé ,léger et plus fabriqué( 5-40 khz)….. Il n'était pas assez cher….
-TASCAM DA 3000:enregistreur audio/convertisseur AN/NA PCM 24:192 KHZ et DSD- appareil pro de studio.
BRAVO AUDIOPHONICS pour cet import!!!!
SEUL BEMOL: faites imprimer une traduction même limité au plus important de la mode d'emploi -une 1/2 feuille A4 n'est pas ruineuse!!
The DAC combo and headphone amplifier DX3 Pro from Topping returns in a revised and improved V2, benefiting in particular from new practical...
