TOPPING DX5 DAC 2x ES9068AS NFCA Headphone Amplifier XMOS Bluetooth 32bit 768kHz DSD512 MQA Black
Topping unveils its DX5, a DAC and headphone amplifier combo benefiting from both an exceptional conception and a resolutely modern design. At its heart is a digital to analog conversion stage carried by a pair of ESS ES9068ES DACs but also an excellent headphone amplifier section based on an NFCA circuit.
By buying this product you get 42 loyalty points
Reference : 16324
424,00 €tax incl.
353,33 € tax excl.
Topping DX5
Topping DX5 DAC 2x ES9068AS Amplificateur Casque NFCA XMOS Bluetooth 32bit 768kHz DSD512 MQA Noir
ES9068AS Dual DAC
The digital / analog conversion stage, entrusted to two ESS ES9068AS DAC chips, allows a sound reproduction of an incredible clarity and precision with a THD+N of only 0.00009%, a dynamic range of 128dB and a noise level below 2µVrms.
XMOS XU216
The USB input of the DX5 uses an XMOS XU216 interface. This interface offers a wide compatibility with the vast majority of devices but also allows the support of high sampling rates, up to PCM 32bit 768kHz, native DSD512 as well as MQA decoding.
MQA
The Topping DX5 supports the decoding and rendering of MQA (Master Quality Authenticated) files. This technology allows to enjoy high quality audio streams, as close as possible to the original studio recording.
Bluetooth
The DX5 benefits from the Hi-Res Audio Wireless certification thanks to the integration of a QCC5125 Bluetooth receiver chip supporting transmission codecs capable of high definition transmission. It is thus compatible with the aptX, aptX HD, aptX LL and LDAC protocols, as well as with the SBC and AAC standards. Moreover, the signal received by the Bluetooth chip is decoded by the pair of DAC ES9068AS, much more powerful than the DAC integrated in the Bluetooth receiver.
The NFCA headphone amplifier circuit of the DX5 is fully optimized specifically for this model, ensuring very low noise and distortion. It is also capable of supporting both high-sensitivity headphones and high-impedance headphones, with a power of 2x1800mW at 32Ω or 2x250mW at 300Ω. The DX5 also offers a gain control (0dB or 12dB) for even more versatility.
Outputs modes
Output channelDisplayHeadphone outputRCA outputXLR outputVolume control
AMPPO, Vol
AMP + Line outP+L, Vol
Line outDACRCA, DAC
XLR, DAC
X+R, DAC
PreRCA, Vol
XLR, Vol
X+R, Vol
1XLR 4 pins balanced headphone output
2IR Receiver
3Multi-function button
4Jack 6.35mm single-ended headphone output
5OLED Display
6Right channel XLR balanced output
7Left channel XLR balanced output
8Left channel RCA single-ended output
9Bluetooth antenna connector
10Coaxial input
11Power input
12Right channel RCA single-ended output
13USB-B input
14Optical input
15Power button
Test du Topping DX5 par Audio Science Review (Amir)
" We expect perfection from Topping and we almost get that in DX5. ESS IMD Hump and Toslink jitter are the only two areas of note but neither is an obstacle to superb performance. Delivering forth highest SINAD ever measured (out of nearly 400 DACs) is a major accomplishment. "
Product typeDAC
InputsBluetooth 5.0
1x USB-B
1x Coaxial
1x Optical Toslink
Outputs1x Balanced stereo XLR line output
1x Single-ended stereo RCA line output
1x Balanced XLR 4 pins headphone output
1x Single ended Jack 6.35mm headphone output
DAC Chip2x ESS ES9068AS
USB InterfaceXMOS XU216
Headphone amplification circuitNFCA
Supported Bluetooth codecsAAC, SBC, aptX, aptX LL, aptX HD, LDAC
Supported sampling ratesUSB : PCM up to 32bit 768kHz
DSD up to DSD512
MQA
Decoding parameters (Line out/ USB In @ 96kHz)
ParameterRCAXLR
THD+N @ 1kHz, A-Weighting< 0.0001%< 0.00009%
THD @ 20Hz-20kHz, 90kBw< 0.0005%< 0.0002%
SNR @ 1kHz, A-Weighting125dB128dB
Dynamic range @ 1kHz, A-Weighting125dB128dB
Frequency response20Hz-20kHz (±0.1dB)
20Hz-40kHz (±0.3dB)
20Hz-20kHz (±0.1dB)
20Hz-40kHz (±0.3dB)
Output level2.1Vrms @ 0dBFS4.2Vrms @ 0dBFS
Noise @ A-Weighting< 1.5µVrms< 2µVrms
Crosstalk-130dB @ 1kHz-140dB @ 1kHz
Channel balance0.3dB0.3dB
Output impedance50Ω50Ω
Headphone amplifier specifications (USB input @ 96kHz)
ParameterJack 6.35mm (single-ended)XLR 4 pins (balanced)
THD+N @ 1kHz, A-Weighting< 0.0001% @ 145mW, 32Ω
< 0.00009% @ 15mW, 300Ω
THD @ 20Hz-20kHz, 90kBw< 0.0005% @ 145mW, 32Ω
< 0.0002% @ 15mW, 300Ω
< 0.0003% @ 15mW, 300Ω
SNR @ Max output level, 1kHz, A-Weighting125dB @ 1kHz125dB @ 1kHz
Dynamic range @ 1kHz, A-Weighting125dB @ 1kHz125dB @ 1kHz
20Hz-40kHz (±0.3dB)
20Hz-20kHz (±0.1dB)
20Hz-40kHz (±0.3dB)
Output level6Vpp @ G=L
25Vpp @ G=H
6Vpp @ G=L
25Vpp @ G=H
Noise @ A-Weighting< 1.7µVrms @ G=L
< 5.5µVrms @ G=H
< 1.7µVrms @ G=L
< 5.5µVrms @ G=H
Crosstalk-114dB @ 1kHz-114dB @ 1kHz
GainG=L 6.7dB (Vrms/FS)
G=H 19dB (Vrms/FS)
G=L 6.7dB (Vrms/FS)
G=H 19dB (Vrms/FS)
Output impedance< 0.1Ω< 0.1Ω
Output power2x 1800mW @ 32Ω, THD+N < 1%
2x 1000mW @ 64Ω, THD+N < 1%
2x 250mW @ 300Ω, THD+N < 1%
Load impedance> 8Ω> 8Ω
Dimensions180 x 148 x 45mm
Package1x Topping DX5
1x Remote control
1x USB Cable
1x Jack 6.35mm to Jack 3.5mm adapter
1x Bluetooth antenna
1x Power cable
Topping DX5 DAC 2x ES9068AS Amplificateur Casque NFCA XMOS Bluetooth 32bit 768kHz DSD512 MQA Noir Topping DX5 DAC 2x ES9068AS Amplificateur Casque NFCA XMOS Bluetooth 32bit 768kHz DSD512 MQA Noir Topping DX5 DAC 2x ES9068AS Amplificateur Casque NFCA XMOS Bluetooth 32bit 768kHz DSD512 MQA Noir Topping DX5 DAC 2x ES9068AS Amplificateur Casque NFCA XMOS Bluetooth 32bit 768kHz DSD512 MQA Noir
OutputJack 6.35mm
DAC / ADC ChipES9068AS
Max sampling rate768kHz
Max sampling rateDSD512
Max sampling rateMQA
Remote ControlYes
Topping unveils its DX5, a DAC and headphone amplifier combo benefiting from both an exceptional conception and a resolutely modern design. At its...
