TOPPING DX5 LITE DAC 2x ES9068AS NFCA Headphone Amplifier XMOS Bluetooth 32bit 768kHz DSD512 Black
Topping offers with its DX5 Lite a DAC and headphone amplifier combo benefiting from both an exceptional conception and a resolutely modern design. At its heart is a digital/analog conversion stage carried by a pair of ESS ES9068ES DACs but also an excellent headphone amplifier section based on an NFCA circuit.
4.7 / 5
By buying this product you get 34 loyalty points
Reference : 17415
349,00 €tax incl.
290,83 € tax excl.
The Topping DX5 Lite also exists in a version supporting MQA files, the Topping DX5.
Topping DX5 LITE
Topping DX5 Lite DAC 2x ES9068AS Amplificateur Casque NFCA XMOS Bluetooth 32bit 768kHz DSD512 Noir
Dual ES9068AS DAC
The digital / analog conversion stage, entrusted to two ESS ES9068AS DAC chips, allows a sound reproduction of an incredible clarity and precision with a THD+N of only 0.00009%, a dynamic range of 128dB and a noise level lower than 2µVrms.
XMOS XU216
The DX5 Lite's USB input uses an XMOS XU216 interface. This offers extensive compatibility with the vast majority of devices but also allows support for high sampling rates, up to 32bit 768kHz PCM and native DSD512.
Bluetooth
The DX5 Lite benefits from the Hi-Res Audio Wireless certification thanks to the integration of a QCC5125 Bluetooth receiver chip supporting transmission codecs capable of high definition transmission. It is thus compatible with the aptX, aptX HD, aptX LL and LDAC protocols, as well as with the SBC and AAC standards. Moreover, the signal received by the Bluetooth chip is decoded by the pair of DAC ES9068AS, much more powerful than the DAC integrated in the Bluetooth receiver.
NFCA Amplifier
The NFCA amplifier circuit of the DX5 Lite is fully optimized specifically for this model, ensuring very low noise and distortion. It is also capable of handling both high-sensitivity headphones and high-impedance headphones, with a output power of 2x1800mW at 32Ω or 2x250mW at 300Ω. The DX5 Lite also offers a gain control (0dB or 12dB) for even more versatility.
Output modes
Output channelDisplayHeadphone outputRCA outputXLR outputVolume control
AMPPO, Vol
AMP + Line outP+L, Vol
Line outDACRCA, DAC
XLR, DAC
X+R, DAC
PreRCA, Vol
XLR, Vol
X+R, Vol
Topping DX5 DAC 2x ES9068AS Amplificateur Casque NFCA XMOS Bluetooth 32bit 768kHz DSD512 MQA Noir
14 pins XLR balanced headphone output
2IR receiver
3Multi-function button
4Jack 6.35mm single-ended headphone output
5OLED screen
6Right channel XLR balanced output
7Left channel XLR balanced output
8Left channel RCA single-ended output
9Bluetooth antenna connector
10Coaxial input
11Power input
12Right channel RCA single-ended output
13USB-B input
14Optical input
15Power button
Topping DX5 review by Audio Science Review (Amir)
" We expect perfection from Topping and we almost get that in DX5. ESS IMD Hump and Toslink jitter are the only two areas of note but neither is an obstacle to superb performance. Delivering forth highest SINAD ever measured (out of nearly 400 DACs) is a major accomplishment. "
Test du Topping DX5 par Audio Science Review (Amir)
Product typeDAC
InputsBluetooth 5.0
1x USB-B
1x Coaxial
1x Optical Toslink
Outputs1x Stereo XLR balanced line output
1x Stereo RCA single-ended line output
1x 4 pins XLR balanced headphone output
1x Jack 6.35mm single-ended headphone output
DAC chip2x ESS ES9068AS
USB InterfaceXMOS XU216
Headphone amplification circuitNFCA
Supported Bluetooth codecsAAC, SBC, aptX, aptX LL, aptX HD, LDAC
Supported sampling ratesUSB : PCM up to 32bit 768kHz
DSD up to DSD512
Decoding parameters (Line out / USB Input @ 96kHz)
ParameterRCAXLR
THD+N @ 1kHz, A-Weighting< 0.0001%< 0.00009%
THD @ 20Hz-20kHz, 90kBw< 0.0005%< 0.0002%
SNR @ 1kHz, A-Weighting125dB128dB
Dynamic range @ 1kHz, A-Weighting125dB128dB
Frequency response20Hz-20kHz (±0.1dB)
20Hz-40kHz (±0.3dB)
20Hz-20kHz (±0.1dB)
20Hz-40kHz (±0.3dB)
Output level2.1Vrms @ 0dBFS4.2Vrms @ 0dBFS
Noise @ A-Weighting< 1.5µVrms< 2µVrms
Crosstalk-130dB @ 1kHz-140dB @ 1kHz
Channel balance0.3dB0.3dB
Output impedance50Ω50Ω
Headphone amplifier specifications (USB Input @ 96kHz)
ParameterJack 6.35mm (single-ended)XLR 4 pins (balanced)
THD+N @ 1kHz, A-Weighting< 0.0001% @ 145mW, 32Ω
< 0.00009% @ 15mW, 300Ω
THD @ 20Hz-20kHz, 90kBw< 0.0005% @ 145mW, 32Ω
< 0.0002% @ 15mW, 300Ω
< 0.0003% @ 15mW, 300Ω
SNR @ max out level, 1kHz, A-Weighting125dB @ 1kHz125dB @ 1kHz
Dynamic range @ 1kHz, A-Weighting125dB @ 1kHz125dB @ 1kHz
20Hz-40kHz (±0.3dB)
20Hz-20kHz (±0.1dB)
20Hz-40kHz (±0.3dB)
Output level6Vpp @ G=L
25Vpp @ G=H
6Vpp @ G=L
25Vpp @ G=H
Noise @ A-Weighting< 1.7µVrms @ G=L
< 5.5µVrms @ G=H
< 1.7µVrms @ G=L
< 5.5µVrms @ G=H
Crosstalk-114dB @ 1kHz-114dB @ 1kHz
GainG=L 6.7dB (Vrms/FS)
G=H 19dB (Vrms/FS)
G=L 6.7dB (Vrms/FS)
G=H 19dB (Vrms/FS)
Channel balanced0.3dB0.3dB
Output impedance< 0.1Ω< 0.1Ω
Output power2x 1800mW @ 32Ω, THD+N < 1%
2x 1000mW @ 64Ω, THD+N < 1%
2x 250mW @ 300Ω, THD+N < 1%
Load impedance> 8Ω> 8Ω
Dimensions180 x 148 x 45mm
Package1x Topping DX5
1x Remote control
1x USB cable
1x Jack 6.35mm to Jack 3.5mm adapter
1x Bluetooth antenna
1x Power cable
Topping DX5 DAC 2x ES9068AS Amplificateur Casque NFCA XMOS Bluetooth 32bit 768kHz DSD512 MQA Noir Topping DX5 DAC 2x ES9068AS Amplificateur Casque NFCA XMOS Bluetooth 32bit 768kHz DSD512 MQA Noir Topping DX5 DAC 2x ES9068AS Amplificateur Casque NFCA XMOS Bluetooth 32bit 768kHz DSD512 MQA Noir Topping DX5 DAC 2x ES9068AS Amplificateur Casque NFCA XMOS Bluetooth 32bit 768kHz DSD512 MQA Noir
OutputJack 6.35mm
DAC / ADC ChipES9068AS
Max sampling rateDSD512
Max sampling rate768kHz
Remote ControlYes
3 reviews
Great unit
I use it primarily as a dac/preamp for my Genelec monitors and as a dac/hp amp for my Beyerdynamic headphones. Does both jobs well and the unit is pretty compact. No complaints
This review has been posted for TOPPING DX5 LITE DAC 2x ES9068AS NFCA Headphone Amplifier XMOS Bluetooth 32bit 768kHz DSD512 Black
Pretty Good DAC/AMP
I was looking for a not super expensive DAC+AMP combination, and I am very happy with the DX5 lite. It works well with windows 10, and I dont have software bugs. Audio quality is good, as expected.
It works
It works and the sound is perfect. The only thing is that it does make little noises when changing programs on my computer. Its not disturbing. If I start Roon there are some noises when its opening.
Topping offers with its DX5 Lite a DAC and headphone amplifier combo benefiting from both an exceptional conception and a resolutely modern design....
