By buying this product you get 37 loyalty points
DAC, Preamplifier and Headphone Amplifier
The Topping DX7 thanks to its "form factor" and its 32bit 384khz capacity offers many configuration possibilities. Combining the functions of DAC, digital preamplifier and high impedance headphone amplifier, it will fulfill most needs with a balanced headphone output.
The fully symmetrical design of this Es9018K2M-based 2-Chip DAC gives it high-end technical qualities with minimal crosstalk and floor noise. Each standard PCM SPDIF digital input has a galvanic isolation transformer. The Topping Dx7 offers at a studied rate benefits rarely achieved.
The analog stage of this DAC is symmetrical with the output of both ES9018K2M. The analog part has separate OP amps for each left and right channel of Texas Instrument-grade audiophile quality.
The Topping DX7 DAC delivers optimal headphone output through two TPA6112A2 amplifiers. Thus, in addition to supporting the DSD / DXD and sampling rates up to 32bit / 384kHz, it benefits from a particularly neat analog output stage that can attack the market-leading audiophile headsets on XLR balanced 4 pin output.
This allows the DX7 to offer a lower sound color and therefore a faithful reproduction, a very low distortion and a high linearity. You gain in dynamics, details and neutrality.
Connections: Outputs | |
1x RCA | - |
1x XLR Symmetrical | - |
1x Digital Coaxial | 75Ω 16 to 24bit 44.1kHz to 192kHz |
1x Headphone Output | 6.35mm Jack |
1x balanced XLR headphone output | 4 pins |
Report ifgreat noise | 114dB |
crosstalk | -130dB at 1kHz |
Headphone output level 6.35 | 16Vpp |
Balanced headphone output level | 31Vpp |
Fixed | 2V RMS |
Headphone output impedance | 10Ω (20Ω symmetrical) |
Impedance output DAC line | 100Ω |
XLR line output impedance | 200Ω |
Coaxial input sensitivity | 0.5V pp (75Ω) |
Frequency response | 20Hz - 20kHz (-0.2dB) |
Power headphone output | |
Asymmetrical Jack 6.35mm | 640mW to 32Ω, 110mW to 300Ω (16 to 300Ω) |
Symmetrical XLR 4 pins | 420mW to 300Ω, 210mW to 600Ω (16 to 600Ω) |
Compatibility | Windows, Mac |
Consumption | 12W |
Weight | 1.95kg |
Dimensions | 250 x 205 x 50mm |
Accessories | 3.5mm Jack, 1x USB Cable, 1x Power Cable, 1x Remote Control |
