TOPPING DX7 PRO+ Balanced DAC Headphone Amplifier ES9038Pro Bluetooth 5.0 aptX HD LDAC 32bit 768kHz DSD512 Black
Topping proposes with the DX7 Pro+ DAC and headphone amplifier, a direct evolution of its predecessor, the DX7 Pro. Thus, this new model benefits from an improved architecture with updated components, allowing an improvement of the overall performance of the device. Its design has also been modernized, now displaying softer curved edges.
Reference : 16763
699,00 €tax incl.
582,50 € tax excl.
Topping DX7 Pro+
Topping DX7 Pro+ DAC Amplificateur Casque Symétrique ES9038Pro Bluetooth 5.0 aptX HD LDAC 32bit 768kHz DSD512 Noir
Differences between the DX7 Pro+ and the DX7 Pro
DX7 Pro+
DX7 Pro
Bluetooth
QCC5125
CSR8675
THD+N (DAC)
< 0.00006%
< 0.00014%
THD+N (headphone amplifier)
< 0.00009% @ 1kHz
< 0.0004% @ 1kHz
Noise (headphone amplifier) @ A-Weighting
< 1.4µVRMS @ G=L / < 2.5µVrms @ G=H
< 3.0µVrms @ G=L / < 5.0µVrms @ G=H
Output power (single-ended @ THD+N < 1%
2x1900mW @ 32 Ohm / 2x320mW @ 300 Ohm
2x840mW @ 32 Ohm / 2x115mmW @ 300 Ohm
Output impedance
< 0.1 Ohm
< 4.7 Ohm
Crosstalk
-120dB @ 1kHz
-80dB @ 1kHz
ES9038Pro DAC
The DX7 Pro+ has an ESS Sabre ES9038Pro DAC at its heart, taking advantage of the latter's 32bit HyperStream architecture, offering high quality audio performance. Each channel of the DX7 Pro+ is connected in parallel, each using four channels of the DAC chip. It is thus capable of revealing a rich and incredibly precise sound reproduction.
New I/V conversion circuit
For its DX7 Pro+, Topping has developed a brand new I/V conversion circuit, designed to achieve even better sound quality. It allows to reach a very low level of distortion and noise, while occupying less space. It is also pushed to its limits in order to make the most of the DAC chip's performance.
Integrated NFCA amplifier
The NFCA headphone amplifier of the DX7 Pro+ has been specifically optimized for this model, offering very low distortion and noise levels. In addition, it provides a nice power reserve that allows it to work equally well with high sensitivity IEMs or high impedance headphones. Still in this optics of adaptability, the device proposes two adjustments of gain.
Balanced & single-ended headphone outputs
As for its headphone outputs, the DX7 Pro+ offers three different formats, in order to adapt to different needs and equipment. There are two balanced outputs with XLR 4 pins and 4.4mm jack, and one single-ended output with 6.35mm jack.
Different output modes
By double-pressing the volume button, it is possible to select an output mode, each of which can be adapted to different usage scenarios.
Output channelDisplayAmplifier outputRCA outputXLR SortieVolume control
AmplifierPO, Vol
Amplifier + Line outP+L, Vol
Line outDACRCA, DAC
XLR, DAC
X+R, DAC
PreamplifierRCA, Vol
XLR, Vol
X+R, Vol
Selectable line output
The DX7 Pro+ has line outputs in XLR balanced and RCA single-ended format. It is thus possible to select to use only the XLR output with the "XLR Only" mode or RCA with the "RCA Only" mode, but also to activate both simultaneously with the "XLR+RCA" option.
I2S input
The Topping DX7 Pro+ integrates an I2S input using the HDMI connector and allowing to transmit the signal to the ES9038Pro DAC in the most direct way possible. This input supports PCM streams up to 32bit 768kHz and Native DSD up to DSD512. The I2S input provides settings for phase, DSD channels and the ability to select the pin for the DSD indicator. These settings allow the DX7 Pro+ I2S input to be compatible with the vast majority of devices using I2S via HDMI.
XMOS USB interface
The USB input of the DX7 Pro+ is not to be outdone and embeds an 8-core XMOS XU208 interface, compatible with Windows, Mac, Linux, iOS and Android and also supporting high-resolution audio streams, up to PCM 32bit 768kHz and DSD512.
Bluetooth
With its Qualcomm QCC5125 chip, the DX7 Pro+ allows you to broadcast your music via Bluetooth, while enjoying excellent sound quality. Indeed, this chip supports the high definition protocols aptX, aptX HD, aptX Adaptive and LDAC, allowing to reach or even exceed the CD quality, in wireless.
Tube / Transistor simulation
Borrowing the sound signature of tube and transistor audio systems, Topping has created a system that simulates both in a single device. It is thus possible to enjoy three different listening modes: standard, tube and transistor.
12V Trigger
The DX7 Pro+'s convenient 12V trigger input and output allows for active control (trigger output) or passive control (trigger input). Using only a 3.5mm jack cable (sold separately), the DX7 Pro+ can be turned on and off automatically in full synchronization with other devices equipped with a 12V trigger interface.
Product typeDAC and headphone amplifier
InputsBluetooth 5.0
1x USB-B
1x AES/EBU
1x Coaxial
1x Optical Toslink
1x I2S LVDS (HDMI)
Outputs1x Single-ended stereo RCA line output
1x Balanced stereo XLR line output
1x Single-ended Jack 6.35mm headphone output
1x Balanced Jack 4.4mm headphone output
1x Balanced 4 poles XLR headphone output
DAC ChipES9038 Pro
USB InterfaceXMOS XU208
Supported sampling ratesUSB / I2S : PCM up to 32bit 768kHz, Native DSD up to DSD512, DSD DoP up to DSD256
Coaxial / Optical / AES : PCM up to 24bit 192kHz, DSD DoP up to DSD64
DAC Measurements (Line output/ USB Input @ 96kHz)
RCAXLR
THD+N @ 1kHz (A-Weighting)< 0.00008%< 0.00006%
THD @ 20Hz-20kHz 90kBw< 0.0008%< 0.0003%
SNR @ 1kHz (A-Weighting)127dB133dB
Dynamic range @ 1kHz (A-Weighting)127dB133dB
Frequency response20Hz-20kHz (±0.1dB)
20Hz-40kHz (±0.3dB)
20Hz-20kHz (±0.1dB)
20Hz-40kHz (±0.3dB)
Output level2.1Vrms @ 0dBFS4.2Vrms @ 0dBFS
Noise @ A-Weighting< 1.0µVrms< 1.0µVrms
Crosstalk-126dB @ 1kHz-139dB @ 1kHz
Channel balance0.3dB0.3dB
Output impedance100Ω100Ω
Headphone Amplifier measurements (USB Input @ 96kHz)
Jack 6.35mm4 poles XLR
THD+N @ 1kHz (A-Weighting)< 0.00009% @ 150mW, 32Ω
< 0.00007% @ 15mW, 300Ω
THD @ 20Hz-20kHz 90kBw< 0.0006% @ 150mW, 32Ω
< 0.0004% @ 15mW, 300Ω
SNR @ Niveau de sortie max, 1kHz (A-Weighting)127dB @ 1kHz127dB @ 1kHz
Dynamic range @ 1kHz (A-Weighting)127dB @ 1kHz127dB @ 1kHz
Frequeny response20Hz-20kHz (±0.1dB)
20Hz-40kHz (±0.3dB)
20Hz-20kHz (±0.1dB)
20Hz-40kHz (±0.3dB)
Output level6.2Vpp @ G=L
27.8Vpp @ G=H
6.2Vpp @ G=L
27.8Vpp @ G=H
Noise @ A-Weighting< 1.4µVrms @ G=L
< 2.5µVrms @ G=H
< 1.2µVrms @ G=L
< 2.5µVrms @ G=H
Crosstalk-120dB @ 1kHz-120dB @ 1kHz
GainG=L 6.9dB (Vrms/FS)
G=H 20dB (Vrms/FS)
G=L 6.9dB (Vrms/FS)
G=H 20dB (Vrms/FS)
Output impedance< 0.1Ω< 0.1Ω
Output power2x1900mW @ 32Ω, THD+N < 1%
2x1350mW @ 64Ω, THD+N < 1%
2x320mW @ 300Ω, THD+N < 1%
Load impedance> 8Ω> 8Ω
Dimensions185 x 113 x 50mm
Package1x DX7 Pro+
1x Remote control
1x USB cable
1x Jack 6.35mm to Jack 3.5mm adapter
1x Bluetooth antenna
1x Power cable
InputAES/EBU
InputI2S via HDMI
OutputJack 4.4mm
OutputJack 6.35mm
DAC / ADC ChipES9038PRO
Max sampling rate768kHz
Max sampling rateDSD512
Remote ControlYes
Topping proposes with the DX7 Pro+ DAC and headphone amplifier, a direct evolution of its predecessor, the DX7 Pro. Thus, this new model benefits...
