TOPPING E30 USB DAC AK4493 32bit/768kHz DSD512 XMOS Black
20%
The E30 from Topping is a DAC with very advantageous compact dimensions and surprising performance given its small size.
4.8 / 5
Reduced price!
Reference : 14486
Limited special offer
149,00 €tax incl.
-20%
119,20 €tax incl.
99,33 € tax excl.
Topping E30
USB DAC 32bit-768kHz / DSD512 XMOS
Topping's E30 is a USB DAC with very compact dimensions and surprising performances for its size. It uses a AK4493 DAC chip which is among the most famous compopents in High Fidelity Audio for this purpose. It also uses a Xmos interface providing a clear and transparent connection to any digital sources with a USB output.
This DAC has a volume control function which can be bypassed to use it either with a preamplifier or directly with active speakers or a power amplifier.
Topping has not forgotten to work on the product looks, since the E30 has an elegant and readable display accompanied by a beautiful touch control button.
Review by Audio Science Review
Distortion levels are incredibly low at -120 dB and lower. The addition of noise takes SINAD down to 112 dB which is most competent for a small little DAC like this:
 test by the measurement forum Audio Science Review
AK4493 DAC & XMOS USB
Digital to Analog audio conversion uses a AK4493EQ 32-bit Dac chip.  This modernized version of the famous AK4490EQ benefits from better distortion and signal-noise ration than its parent while keeping all the technologies that made it popular. It includes the famous Velvet Sound technology with increasingly accurate digital filters.
The USB input is controlled by a XMOS interface that enables to properly support very high sampling frequencies (up to 768kHz 16 and 32bit). This component also provides native DSD  compatibility up to DSD512 in addition to the DOP256 support.
When starting DSD through Foobar, a plop can occurr at the beginning of tthe first track.
These components are rigorously integrated and allow the E30 to achieve a clear signal with an extremely low distortion rate of 0.0003%, less than -130dB crosstalk, 121dB signal noise ratio and 119dB measured dynamic range. This kind of performance is usually found in more expensive and bulky equipment.
Impressive connectivity for its size
Unlike the majority of compact DACs that use a micro USB port, Topping gave its E30 an USB-B port. Thus giving it is a great advantage in terms of robustness and lifespan over its competitors.
The eneregy requirements are low enough to allow direct power supply through the USB port. There is also a DC jack which is ideal for connecting the E30 to any Hi-Fi grade power-supply (LPSU) without using any adapter.
A Coaxial SPDIF and an Optical SPDIF input enable the DAC E30 to work with external digital sources. Multiple devices (CD player, TV, media platform or game console) can be connected and enjoy its excellent audio decoding capability.
Its SPDIF interface use a CS8416 low-jitter chip, which supports digital audio streams up to 24-bit / 192kHz.
The touch button on the front panel can be used to change the active source. The source selection can also be done using the included infra-red remote control.
The output is a simple RCA stereo connector with variable volume.
Dimensions
Infrared remote control
The E30 comes with an sober infra-red remote to control all its functions remotely. This is a very rare feature in this price range.
TypeDAC
DAC chipAK4493
Sample rate (USB)PCM: 44.1-768kHz 16-32bit
DSD: DSD64-512 (native)
Sample rate (Optical & Coax)PCM: 44.1-192kHz
DOP: DOP64-256
THD + N0.0003%
CrosstalkLess than -130dB
Ratio signal / noise121dB
Dynamic119dB
Dimensions3.2 x 10 x 12.5cm
Package content
DAC E30x1
Male USB-A to Male Jack DC cable 5.5/2.1mmx1
Male USB to Male USB-A cablex1
Remotex1
Manual (EN)x1
Warranty Cardx1
DAC / ADC ChipAK4493EQ
Max sampling rateDSD512
Max sampling rate768kHz
Remote ControlYes
26 reviews
Magnifique petit DAC
Que dire de ce DAC…
Il est totalement invisible au niveau audio, mais c’est ce que je ressent avec n’importe quel DAC. Il est très transparent.
Par contre il est extrêmement pratique, pas encombrant, un bel écran qui permet de bien lire le volume si on l’utilise également en fonction pré ampli, une finition très propre.
Merci à Audiophonics pour tous ces services.
Pascal
This review has been posted for TOPPING E30 USB DAC AK4493 32bit/768kHz DSD512 XMOS Black
Coaxial not operate properly
Is a good DAC but the coax input operate with with continuous breaks when i connect a CD player !
could be problematic
Hello,
after purchaising the topping E30 in the audiophonics shop the item was delivered to Italy with some delay, maybe general christmas time delivery and not depending from audiophonics. Attention, it comes without power supply an this is not indicated very well. (you have to control the shipping list) My E30 did not work correctly, The music pieces are played with hundreds of mirco interruptions. So I can't describe very well the sound compared to my existing Project digital S2 box Dac. Very similar, a little bit darker and more cohesive. Without the malfunction I preferred it over the project S2. Due to the malfunction and scare support from topping and audiophonics I sent it back. Audiophonics said, the cannot detect errors on my E30. Tested in my hifi-sourrounding with 3 different CD-players as transport occurs always same error, same system and the project works fine. Now I'm waiting for over Two weeks to get my money back. Audiophonics say, I have to wait. Did you know that they have no telefon number.. .Their website is beautiful but if you have a problem with a product it seems its better to buy elsewhere, Michael
Ne convient pas pour un système haute-fidélité
Si vous recherchez un DAC simplissime pour une utilisation haute-fidélité, celui-ci ne conviendra pas; préférez le Topping E50.
DAC Imbattable à ce prix
Bonjour
Acheté suite au conseil d'audiophonics pour piloter un AKG 702.
Excellent DAC : son détaillé, équilibré et non agressif.
Par contre j'ai trouvé que les basses ne sont pas assez maitrisées et que les medium sont un tout petit peu mis en avant (je cherche la petite bête)
Cela n'enlève en rien son coté chaleureux et son incroyable musicalité et abscence de distortion.
A ce prix franchement, imbattable !!!
