TOPPING E50 Balanced DAC ES9068AS XMOS XU216 MQA 32bit 768kHz DSD512 Silver
Topping offers with its E50 a compact and very powerful DAC, using proven audio components widely recognized by audiophiles. This one is indeed based on an ESS ES9068AS digital/analog conversion chip as well as an XMOS XU216 USB interface, allowing it to read high resolution files but also to decode MQA files.
4.0 / 5
Reference : 15588
199,00 €tax incl.
165,83 € tax excl.
Shipping date: 16-04-2025.
Topping E50
DAC ES9068AS XMOS XU216 Symétrique MQA 32bit 768kHz DSD512 Silver
Topping E50 DAC ES9068AS XMOS XU216 Symétrique MQA 32bit 768kHz DSD512
Topping offers with its E50 a compact and very powerful DAC, using proven audio components widely recognized by audiophiles. This one is indeed based on an ESS ES9068AS digital/analog conversion chip as well as an XMOS XU216 USB interface, allowing it to read high resolution files but also to decode MQA files. It also benefits from a balanced output on TRS connectors.
ESS ES9068ASDAC
The E50's digital-to-analog conversion stage uses the latest ESS ES9068AS DAC chip to deliver a transparent and richly detailed sound. The device ensures excellent performance with a very low distortion of 0.00009% or a dynamic range of 126dB.
USB XMOS XU216
The USB interface of the Topping E50 uses a second generation XMOS XU216 16-core chip with custom Thesycon driver. Associated with the ES9068AS DAC, this combination allows a perfect sound neutrality but also the support of high resolution files, up to PCM 32bit 768kHz, DSD512 and MQA. The USB input also uses a CPLD to process the clock signal and thus considerably reduce the jitter level.
Full connectivity & Balanced output
Topping's DAC benefits from a complete connectivity to adapt to all types of audio systems. We can find USB-B, Optical Toslink and Coaxial as inputs. On the output side, the E50 offers both single-ended RCA and a double 6.35mm TRS jack for balanced output.
The TRS output does not support an adapter to convert the signal to single-ended and cannot be connected directly to headphones.
Power supply & Auto ON/OFF
The Topping E50 is powered by 5VDC, either via its DC jack connector or directly on its USB-B input. It also benefits from an automatic on/off function. Thus, if the E50 receives a signal, it turns on automatically. In the same way, if it does not receive any signal on the selected input during 1 minute, then the E50 turns off.
Preamplifier function
The E50 has a preamplifier function. It is thus possible to control the volume level thanks to the remote control supplied. Ideal for association with a power amplifier or active speakers.
Product typeDAC
DAC ChipESS ES9068AS
Supported sampling ratesUSB : PCM up to 32bit 768kHz, Native DSD up to DSD512, DSD DoP up to DSD256, MQA
Optical, Coaxial : PCM up to 24bit 192kHz, DSD DoP up to DSD64, MQA
Entrées1x USB-B
1x Optical Toslink
1x Coaxial
Outputs1x Single-ended stereo RCA
1x Balanced stereo Jack 6.35mm TRS
Measurements @ USB, 96kHz
THD+N @ A-WeightingSingle-ended: < 0.0001% @ 1kHz
Balanced : < 0.00009% @ 1kHz
THD @ No-Weighting 90kBwSingle-ended: < 0.0003% @ 20Hz-20kHz
Balanced : < 0.0003% @ 20Hz-20kHz
SNR @ A-WeightingSingle-ended : 124dB @ 1kHz
Balanced : 126dB @ 1kHz
Dynamic range @ A-WeightingSingle-ended : 124dB @ 1kHz
Frequency responseSingle-ended : 20Hz-40kHz (±0.3dB)
Balanced : 20Hz-40kHz (±0.3dB)
Output levelSingle-ended : 2Vrms @ 0dBFS
Balanced : 4Vrms @ 0dBFS
Noise @ A-WeightingSingle-ended : < 1.3µVrms
Balanced : < 2.3µVrms
CrosstalkSingle-ended : -130dB @ 1kHz
Balanced : -139dB @ 1kHz
Output impedanceSingle-ended : 20Ω
Balanced : 100Ω
Supply voltage5VDC
Dimensions129 x 155 x 41mm
ColorSilver
Package1x Topping E50
1x Remote control
1x USB-A to Jack DC power cable
1x USB-A to USB-B cable
Topping E50 DAC ES9068AS XMOS XU216 Symétrique MQA 32bit 768kHz DSD512 Topping E50 DAC ES9068AS XMOS XU216 Symétrique MQA 32bit 768kHz DSD512 Topping E50 DAC ES9068AS XMOS XU216 Symétrique MQA 32bit 768kHz DSD512
OutputJack 6.35mm
DAC / ADC ChipES9068AS
Max sampling rate768kHz
Max sampling rateDSD512
ColorSilver
Remote ControlYes
2 reviews
Parfait sauf...
Est arrivé très vite, bien emballé (mais il n'y avait plus le plastique de protection ?), Fonctionne parfaitement, facile d'utilisation même si j'aurais aimé pouvoir changer le volume autrement qu'avec la télécommande IR. Et il y a aussi l'histoire toirevdes filtre... Aucunes explications et impossible de les désactiver. Sinon le son est sublime, presque impossible d'entendre du bruit.
This review has been posted for TOPPING E50 Balanced DAC ES9068AS XMOS XU216 MQA 32bit 768kHz DSD512 Silver
good detail, really good but compressed dynamics even with linear psu
good detail, really good resolution but compressed dynamics even with linear psu 5 volts
Topping offers with its E50 a compact and very powerful DAC, using proven audio components widely recognized by audiophiles. This one is indeed...
