TOPPING E70 DAC ES9028Pro XMOS XU316 Bluetooth 5.1 aptX Adaptive LDAC 32bit 768kHz DSD512 Black
Topping offers with its E70 a powerful DAC with an accurate design. A model capable of offering a rich and precise sound reproduction, combined with smart and practical features, such as Bluetooth, a 12V trigger or an adaptable output level.
By buying this product you get 27 loyalty points
Reference : 16948
279,00 €tax incl.
232,50 € tax excl.
Shipping date: 22-04-2025.
Topping E70
Topping E70 DAC ES9028Pro XMOS XU316 Bluetooth 5.1 aptX Adaptive LDAC 32bit 768kHz DSD512 Noir
ES9028Pro DAC
The Topping E70 embeds a digital to analog conversion stage based on an ESS ES9028Pro chip. This 32bit DAC with eight channels benefits from the HyperStream II architecture and ensures a high quality sound reproduction, marked by a beautiful transparency and precision.
A brand new I/V conversion circuit
The E70 also benefits from an all-new I/V conversion circuit, designed to ensure low distortion and low noise, while taking up less space. This is pushed to its limits to allow the DAC to reveal its full potential.
Bluetooth 5.1
Equipped with a Qualcomm QCC5125 Bluetooth 5.1 receiver chip, the E70 allows you to remotely stream your music directly from your smartphone or tablet. It also supports the high-resolution transmission codecs aptX, aptX HD, aptX Adaptive and LDAC, guaranteeing high-quality playback over Bluetooth.
XMOS XU316 USB Interface
The USB input of the Topping E70 is associated with a latest generation XMOS XU316 interface with custom Thesycon driver. This powerful interface supports high resolution audio streams, up to PCM 32bit 768kHz and DSD512, for a very high quality listening.
12V Trigger
The E70 integrates a 12V trigger with active (trigger output) and passive (trigger input) control. With only a simple 3.5mm jack cable, the Topping E70 can be switched on and off in sync with your other equipment with a 12V trigger interface.
Selectable output modes
The E70 provides balanced XLR and single-ended RCA output. The input is selectable and allows to activate only one or both simultaneously. In addition, Topping offers a smart feature, allowing you to adjust the level of these outputs according to your use and desired integration. Thus, the level of the XLR output can be changed from 4V to 5V and the RCA output from 2V to 2.5V.
1ON-OFF / Input selection button
2Screen
3Volume button
4Coaxial input
5Bluetooth antenna connector
612V Trigger input
7Balanced XLR output
8Single-ended RCA output
9Optical Toslink input
10USB-B input
1112V Trigger output
12Power connector
13Power button
Product typeDAC
InputsBluetooth 5.1
1x USB-B
1x Coaxial
1x Optical Toslink
1x Balanced stereo XLR
DAC ChipES9028Pro
Bluetooth receiverQCC5125
USB InterfaceXMOS XU316
Supported Bluetooth codecsAAC, SBC, aptX, aptX HD, aptX LL, aptX Adaptive, LDAC
Supported sampling ratesUSB : PCM up to 32bit 768kHz, Native DSD up to DSD512, DSD DoP up to DSD256
Optical / Coaxial : PCM up to 24bit 192kHz, DSD DoP up to DSD64
Measurements
Paramètres DAC E70 (Sortie ligne / Entrée USB à 96kHz)
RCAXLR
THD+N @ 1kHz, A-Weighted< 0.00008%< 0.00006%
THD @ 20Hz-20kHz, 90kBw, Non-Weighted< 0.0007%< 0.0002%
SNR @ 1kHz, A-Weighted126dB132dB
Dynamic range @ 1kHz, A-Weighted126dB132dB
Frequency response20Hz-20kHz (±0.2dB)
20Hz-40kHz (±0.4dB)
20Hz-20kHz (±0.2dB)
20Hz-40kHz (±0.4dB)
Output level2.1Vrms @ 0dBFS (4V Mode )
2.5Vrms @ 0dBFS (5V Mode)
4.2Vrms @ 0dBFS (4V Mode)
Noise (A-Weighted)< 1.3µVrms< 1.3µVrms
Crosstalk-133dB @ 1kHz-149dB à 1kHz
Channels balance0.3dB0.3dB
Output impedance50Ω100Ω
Dimensions200*138*4mm
Package1x Topping E70
1x Remote cotnrol
1x USB cable
1x Power cable
1x Bluetooth antenna
DAC / ADC ChipES9028PRO
Max sampling rate768kHz
Max sampling rateDSD512
Remote ControlYes
Le summum musical !
Un appareil qui semble petit par sa taille mais qui s’avère immense dans ses prestations sonores. Tout d’abord, la qualité de fabrication est exemplaire, tout en métal avec des connecteurs solides. Le potentiomètre rotatif à cran est des plus agréable à l’usage. Le design est donc une totale réussite, avec une touche de rouge tout-à-fait bienvenue. Une fois, allumé, l’écran s’avère magnifique et surtout bien lisible en blanc. La réglage du volume est au quotidien un régal de précision et s’avère très précis et sans aucun décalage de volume entre les canaux. Une fois relié en XLR à l’amplificateur pour casque Topping L70 qui au niveau du design s’accorde avec lui à la perfection, c’est la claque sonore totale ! Il s’agit tout simplement du meilleur combo que j’ai pu entendre et peu importe le prix. Avec plusieurs casques Focal et Sennheiser, le résultat est toujours au top. Tous les qualificatifs habituels pour décrire précisément un signal sont de rigueur tant la retransmission est transparente. Ensuite, la sortie RCA connectée à mon système d’écoute composé de l’amplificateur Marantz PM 6005 et des enceintes Focal Aria 906, produit également un niveau de qualité rarement atteint ! Sinon, en mode sans-fil, je regrette simplement l’absence d’AirPlay ce qui aurait évidemment imposé une puce Wifi en plus de celle Bluetooth qui hélas propose une liaison qui dégrade forcément la qualité sonore. C’est quand même pratique pour y connecter rapidement n’importe quel appareil nomade. Le fabricant propose enfin des mises à jour du firmware ce qui est un très bon point. Bref, je recommande donc chaudement cette marque et cet appareil exceptionnel pour toutes ces raisons. Il procure un plaisir d’écoute sans précédant ! Bravo aux concepteurs !
 (3)
This review has been posted for TOPPING E70 DAC ES9028Pro XMOS XU316 Bluetooth 5.1 aptX Adaptive LDAC 32bit 768kHz DSD512 Black
Topping offers with its E70 a powerful DAC with an accurate design. A model capable of offering a rich and precise sound reproduction, combined...
