TOPPING EX5 Headphone Amplifier DAC 2x ES9038Q2M Bluetooth 5.0 LDAC 32bit 768kHz DSD512 MQA Silver
Topping offers with its EX5 an extremely powerful DAC and headphone amplifier combo. Its conversion stage is indeed based on two ES908Q2M DAC chips and allows the reading of high resolution audio streams, while ensuring an incredible precision and sound richness.
4.5 / 5
By buying this product you get 36 loyalty points
Reference : 15493
369,00 €tax incl.
307,50 € tax excl.
Shipping date: 18-04-2025.
Topping EX5
Topping EX5 Amplificateur Casque DAC 2x ES9038Q2M Bluetooth 5.0 LDAC 32bit 768kHz DSD512 MQA Argent
Topping offers with its EX5 an extremely powerful DAC and headphone amplifier combo. Its conversion stage is indeed based on two ES908Q2M DAC chips and allows the reading of high resolution audio streams, while ensuring an incredible precision and sound richness. Versatile, the EX5 has a complete connectivity as well as a Bluetooth 5.0 connectivity. Its amplification stage, using an NFCA circuit, allows it to deliver a comfortable power to accompany the majority of the headphones of the market while ensuring a perfect audio transparency.
Dual ES9038Q2M DAC & USB XMOS
At the heart of the EX5 is a particularly efficient digital to analog conversion stage. Taking advantage of a symmetrical architecture, it uses two ESS ES9038Q2M chips, supporting PCM files up to 32bit 768kHz and DSD up to DSD512. These DACs allow to reach an excellent sound quality, marked by a great precision and a beautiful transparency. This conversion stage is associated with a USB XMOS XU216 interface which is also extremely powerful and allows the decoding of MQA files.
MQA
The Topping EX5 supports the decoding and rendering of MQA (Master Quality Authenticated) files. This technology allows to enjoy high quality audio streams, as close as possible to the original studio recording.
Bluetooth 5.0
The EX5 embeds a Bluetooth 5.0 Qualcomm CSR8675 chip. It is thus possible to broadcast your music remotely directly from your smartphone for example. In addition, this Bluetooth chip supports the high-resolution codecs aptX, aptX HD, aptX LL and LDAC, allowing you to achieve a very good quality of sound reproduction in Bluetooth.
Four output modes
The Topping EX5 has four outputs: one unbalanced headphone output on 6.35mm jack, one balanced headphone output on 4-pin XLR, and two line outputs on unbalanced RCA and balanced XLR. It is thus possible to define an output mode among four available: headphone output only, RCA only, XLR only or XLR + RCA. This selection allows the EX5 to adapt to different types of use. Regardless of the output mode, the volume control remains effective.
Product typeDAC
Headphone amplifier
Inputs1x USB-B
1x Optical Toslink
1x Coaxial
Bluetooth 5.0
Outputs1x Single-ended RCA
1x Balanced XLR
1x Single-ended Jack 6.35mm headphone output
1x Balanced XLR 4 pins headphone output
Supported sampling ratesUSB : PCM up to 32bit 768kHz, Native DSD up to DSD512, DSD DoP up to DSD256, MQA
Coaxial / Optical : PCM up to 24bit 192kHz, DSD DoP up to DSD64
Supported Bluetooth codecsAAC, SBC, aptX, aptX LL, aptX HD, LDAC
DAC (@ Line out/USB, 96kHz)
THD+N @ A-WeightingRCA : < 0.0001% @ 1kHz
XLR : < 0.0001% @ 1kHz
THD @ No-Weighting, 90kBwRCA : < 0.0005% @ 20Hz-20kHz
XLR : < 0.0004% @ 20Hz-20kHz
SNR @ A-WeightingRCA : 125dB @ 1kHz
XLR : 125dB @ 1kHz
Dynamic range @ A-WeightingRCA : 125dB @ 1kHz
XLR : 125dB @ 1kHz
Frequency responseRCA : 20Hz-20kHz (±0.1dB) / 20Hz-40kHz (±0.3dB)
XLR : 20Hz-20kHz (±0.1dB) / 20Hz-40kHz (±0.3dB)
Output levelRCA : 2.1Vrms @ 0dBFS
XLR : 4.3Vrms @ 0dBFS
Noise @ A-WeightingRCA : < 1.7µVrms
XLR : < 2.5µVrms
CrosstalkRCA : -85dB @ 1kHz
XLR : -85dB @ 1kHz
Channel balanceRCA : 0.3dB
XLR : 0.3dB
Output impedanceRCA : 100Ω
XLR : 200Ω
Headphone amplifier (@ USB, 96kHz)
THD+N @ 1kHz A-WeightingJack 6.35mm : < 0.0001% @ 145mW 32Ω / < 0.0001% @ 15mW 300Ω
XLR 4 Pins : < 0.0003% @ 145mW 32Ω / < 0.00015% @ 15mW 300Ω
THD @ 20Hz-20kHz 90kBWJack 6.35mm : < 0.00015% @ 145mW 32Ω / < 0.00015% @ 15mW 300Ω
XLR 4 Pins : < 0.0004% @ 145mW 32Ω / < 0.0002% @ 15mW 300Ω
SNR @ Max out, 1kHz, A-WeightingJack 6.35mm : 125dB
XLR 4 Pins : 125dB
Dynamic range @ 1kHz A-WeightingJack 6.35mm : 125dB
XLR 4 Pins : 125dB
Frequency responseJack 6.35mm : 20Hz-20kHz (±0.1dB) / 20Hz-40kHz (±0.3dB)
XLR 4 Pins : 20Hz-20kHz (±0.1dB) / 20Hz-40kHz (±0.3dB)
Output levelJack 6.35mm : 5.9Vpp @ G=L / 18.3Vpp @ G=H
XLR 4 Pins : 5.9Vpp @ G=L / 18.3Vpp @ G=H
Noise@ A-WeightingJack 6.35mm : < 1.5µVrms @ G=L / < 3Vrms @ G=H
XLR 4 Pins : < 1.5µVrms @ G=L / < 3Vrms @ G=H
Diaphonie @ 1kHzJack 6.35mm : -88dB
XLR 4 Pins : -99dB
GainJack 6.35mm : G=L 6dB (Vrms/FS) / G=H 16dB (Vrms/FS)
XLR 4 Pins : G=L 6dB (Vrms/FS) / G=H 16dB (Vrms/FS)
Channel balanceJack 6.35mm : 0.3dB
XLR 4 Pins : 0.3dB
Output impedanceJack 6.35mm : < 0.1Ω
XLR 4 Pins : < 0.1Ω
Output powerJack 6.35mm : 2x 1.3W @ 32Ω THD+N<1% / 2x 140mW @ 300Ω THD+N<1%
XLR 4 Pins : 2x 1.3W @ 32Ω THD+N<1% / 2x 140mW @ 300Ω THD+N<1%
Headphone impedance recommendedJack 6.35mm : 16-600Ω
XLR 4 Pins : 16-600Ω
Supply voltage100-240VAC 50Hz/60Hz (power cable included)
Dimensions17.4 x 13.8 x 4.5cm
Weight750g
ColorSilver
Package1x Toppping EX5
1x Remote control
1x USB cable
1x Jack 6.35mm to Jack 3.5mm adapter
1x Bluetooth antenna
1x Power cable
Topping EX5 Amplificateur Casque DAC 2x ES9038Q2M Bluetooth 5.0 LDAC 32bit 768kHz DSD512 MQA Argent Topping EX5 Amplificateur Casque DAC 2x ES9038Q2M Bluetooth 5.0 LDAC 32bit 768kHz DSD512 MQA Argent Topping EX5 Amplificateur Casque DAC 2x ES9038Q2M Bluetooth 5.0 LDAC 32bit 768kHz DSD512 MQA Argent Topping EX5 Amplificateur Casque DAC 2x ES9038Q2M Bluetooth 5.0 LDAC 32bit 768kHz DSD512 MQA Argent
OutputJack 6.35mm
DAC / ADC ChipES9038Q2M
Max sampling rateDSD512
Max sampling rate768kHz
ColorSilver
ClassN/A
Remote ControlYes
2 reviews
Excellent Dac
Passe quasi parfaitement le test de lecture de l'album Myopia d'Agnès Obel que tant de Dacs massacre. L'ampli n'est pas en reste et fait un très bon travail. Enchanté de mon achat chez Audiophonics
This review has been posted for TOPPING EX5 Headphone Amplifier DAC 2x ES9038Q2M Bluetooth 5.0 LDAC 32bit 768kHz DSD512 MQA Silver
Du bon et du mauvais
Avantage par rapport au Topping DX3pro+ son alimentation secteur intégrée au boitier, le deuxième dac ES9038
Désavantage en tout premier je trouve vraiment inintéressant le décodage MQA qui augmente nettement le coût de l'appareil et n'apporte rien pour la grande majorité des utilisateurs. Un petit regret encore, sur la puissance de sortie inférieure au DX3 pro+
Sinon quel plaisir de commander chez audiophonics à prix compétitif.
Envoi très rapide et bien emballé
Topping offers with its EX5 an extremely powerful DAC and headphone amplifier combo. Its conversion stage is indeed based on two ES908Q2M DAC chips...
