Yulong Audio SABRE DA8 II 2 DSD DAC 32bit / 384kHz Class A Black
By buying this product you get 115 loyalty points
Reference : 8080
1 159,00 €tax incl.
965,83 € tax excl.
At the same time, the DAC DSD, Preamplifier and Headphone Amplifier Class A, the Yulong SABRE DA8 2 has been designed to satisfy the most demanding audiophiles.
Equipped as standard with the most advanced Amanero USB interface on the market and many useful options (lowpass filters via AOP AD797, phase inversion, jitter reduction, etc.), it is at the same time one of the converters more modern and more musical on the market.
It now features a CRYSTEK high-precision clock, a new power supply and a more complete and powerful headphone amplification stage.
Features:/ Strong>
  • DAC Sabre ESS ES9018
  • High precision clock CRYSTEK CCHD-950-25-100
  • Preamp function (balanced and unbalanced outputs)
  • Supported Sampling Rate: PCM 32bit / 384kHz and DSD
  • Headphone Amplifier: Class A
  • Headphone Amplifier Power: 600Ω: 70mw 300Ω: 150mw 150Ω: 280mw 32Ω
  • LCD screen: TFT 6cm
  • Volume control: 80 levels
  • Different combinations of possible sounds (5 different filters)
  • Automatic configuration backup
  • Jitter Reduction Button
  • Phase reversal button
  • Case: Aluminum
  • Native support DSD 64/128/256/512
  • Teamof the AMANERO Combo 384 Interface digital USB 384khz to I2s / DSD
Specifications:
  • Frequency response: 20-30kHz to -0.2dB
  • Signal Noise Ratio: -135dB
  • THD + N: <0.0002%
  • Dynamic range:> 130dB
  • Crosstalk: -135dB
  • Symmetric Output Level: 4.2V
  • Power consumption: <30W
  • Chassis 100% Aluminum
  • Dimensions: (250 mm X 180mm X 60mm)
  • Weight: 2.5Kg
  • Compatible with Mac OS and Linux (with Kernel UAC2)
  • Supplied with manual, power cable and USB-B cable
Connectors:
  • Inputs:
    • 1x Optical
    • 1 x Coaxial RCA
    • 1 x AES / EBU
    • USB: PCM 16-32bit 44.1kHz, 48kHz, 88.2kHz, 96kHz, 176.4kHz, 192kHz, 352.8kHz 384kHz DSD64,128 - On Windows DSD256, 512
  • Exits :
    • 2 x RCA stereo
    • 2 x analog XLR
    Qobuz
    French testis (Click here).
https://www.audiophonics.fr/images2/7903/7903_yulong_sabreDA8_dac_ampli_5.jpg
https://www.audiophonics.fr/images2/7903/7903_yulong_sabreDA8_dac_ampli_6.jpg
2 reviews
J'utilise maintenant ce Yulong DA8 Noir depuis quelques semaines. Je l'ai installé successivement dans deux de mes systèmes. Un avec iMac muni de Amara, casque Grado GS1000i pour tester (j'ai déjà un Burson HA-160 D sur ce système), l'autre sur un PC fabrication maison, Windows 7-64, Foobar 2000 , casque Philips Fidelio L1, c'était là son affectation prévue. Dans le système Mac, le Yulong est immédiatement reconnu et opérationnel, sur le PC il faut télécharger les drivers, lire le mode d'emploi, et installer les drivers, puis paramétrer le système (configuration -_ son), puis Foobar, rien de réellement compliqué, et après quelques tâtonnements tout fonctionne bien. Notez bien que le Yulong devra être allumé quand le PC fonctionne, car sinon certains programmes passeront leur temps à chercher la sortie son (c'est le cas notamment des jeux de Windows).
Une fois installé, et connecté avec un câble USB correct (Câble Pangéa acheté ici sur le Mac, Aqvox sur le PC), tous les formats possibles et toutes les définitions possibles (enfin ceux dont je dispose, maxi en 192 Khz) sont reconnus et joués instantanément (chez moi essentiellement du flac).
Il faut le roder un peu, quelques dizaines d'heures, et le laisser chauffer (classe A oblige). Dans ma configuration, je lui trouve parfois quelques duretés dans le haut médium en particulier avec les enregistrements en très haute définition. Mon point de comparaison est 1 Naim DAC Alimenté par un Oppo 93 avec Kit Audiocom (le prix n'est pas le même bien sur). Les choses s'améliorent un peu quand le Yulong est chaud, mais les duretés évoquées ne disparaissent pas complètement.
Dernier point, c'est un DAC + ampli casque, mais pas un préampli comme j'avais cru le comprendre en lisant la description. Vous avez le choix en pressant sur le bouton de volume entre la sortie casque (avec préampli + ampli donc réglage de volume) et une sortie directe vers un préampli ou un intégré, le Yulong se comportant alors comme un DAC (il contourne l'ampli casque ET le préampli : le réglage de volume n'est alors plus opérationnel). En conséquence, vous ne pourrez pas le connecter directement à des enceintes actives (genre Focal Solo 6 Be en liaison XLR). J'ai donc acheté un préampli avec liaison symétrique (Pro-Ject Pre Box RS Noir - à tubes et en classe A, entrées et sorties sur XLR ou RCA que je n'ai pas encore reçu). Au global j'arrive à un prix qui se rapproche de celui du Burson Conductor (choix à considérer si vous avez par exemple des enceintes actives ou un ampli avec entrées RCA).
Conclusion : une bon DAC, très complet, facile d'emploi avec un excellent rapport qualité/prix.
This review has been posted for Yulong Audio SABRE DA8 II 2 DSD DAC 32bit / 384kHz Class A Black
