AUDIO-GD AS-1 2021 EDITION DAC 2x ES9038Pro 3x Accusilicon FPGA Amanero 32bit 384kHz DSD512
The Audio-GD AS-1 2021 Edition is a balanced DAC based on a duo of ESS ES9038Pro digital/analog converters. It ensures an extremely low level of distortion, very rarely reached by this type of product and especially at such a contained price.
By buying this product you get 114 loyalty points
Reference : 15129
1 149,00 €tax incl.
957,50 € tax excl.
Audio-GD AS-1 2021 EDITION
Audio-GD AS-1T DAC 2x ES9038PRO FPGA 32bit 384kHz DSD512
The Audio-GD AS-1 2021 Edition is a balanced DAC based on a duo of ESS ES9038Pro digital/analog converters. It ensures an extremely low level of distortion, very rarely reached by this type of product and especially at such a contained price. The ES9038Pro chips take advantage of HyperStream II 32bit technology offering high audio performance with a dynamic range (DNR) up to 140dB and a THD+N of -122dB.
The two ES9038Pro DACs are also supported by an FPGA. The FPGA takes care of the synchronization of the audio signals and thus of the jitter reduction. This results in a more accurate and transparent sound reproduction, while drastically reducing noise. Three Accusilicon clocks are also integrated, once again allowing the jitter to be reduced to a minimum thanks to optimal signal synchronization.
On the connection side, the AS-1 2021 Edition offers Coaxial SPDIF, Optical, USB-B, a BNC connector and finally I2S HDMI LVDS. On the output side, we find XLR 3 poles, ACSS and RCA Stereo. A complete range of connectors that satisfy the vast majority of needs, for easy integration into your audio system.
2021 Edition
The Audio-GD AS-1 in version 2021 benefits from new functionalities as well as certain improvements, with the aim of providing ever more precise and richer sound reproduction.
  • [New feature] The USB input transmits the I2S signal to the FPGA and receives the clock signal for more accurate playback.
  • [Upgrade] The clock of the ES9038Pro DAC and FPGA use the same signals.
Who is the Audio-GD AS-1 2021 Edition for?
Unlike the other products offered by Audio-GD, this AS-1 does not have discrete outputs. Indeed, it integrates AOPs and has been optimized to offer the best possible technical specifications. It is therefore aimed at a different audience, mainly interested in exceptional measures and wanting seamless transparency. This exceptional sound fidelity also makes it possible to test cables, parts, speakers or any other audio product in optimal conditions.
HDMI Pinout
Product typeBalanced DAC
DAC Chip2x ES9038Pro
FPGAYes
Clocks x3 Accusilicon
Supported sampling ratesUSB / I2S : PCM up to 384kHz - DSD up to DSD512
Coaxial : PCM up to 192kHz
Optical : PCM up to 96kHz
Inputs1x SPDIF Coaxial
1x BNC
1x Optical Toslink
1x I2S HDMI LVDS
1x USB-B
Outputs1x Balanced XLR
1x Single-ended RCA
1x ACSS
Output impedance10 Ohm
Output levelRCA : 2.25V
XLR : 4.5V
2+2mA (ACSS)
Input sensitivityCoaxial 75 Ohm : 0.5Vp-p
Optical : 19dBm
Frequency response20Hz - 20kHz (< -0.1dB)
SNR> 120dB (XLR output)
THD0.0002%
Supported OS (USB)Windows, OSX, Linux, ISO
Supply voltage220-240V AC 50/60Hz
Consumption23W
Package weight~ 5.5kg
Dimensions240 x 360 x 80mm
Housing materialAluminum
Package1x Audio-GD AS-1 2021 Edition
1x Power cable
1x USB cable
InputI2S via HDMI
InputBNC
OutputACSS
DAC / ADC ChipES9038PRO
Max sampling rate384kHz
Max sampling rateDSD512
AUDIO-GD AS 1 EDITION DAC
I am really very pleasantly surprised! Thank you!
This review has been posted for AUDIO-GD AS-1 2021 EDITION DAC 2x ES9038Pro 3x Accusilicon FPGA Amanero 32bit 384kHz DSD512
The Audio-GD AS-1 2021 Edition is a balanced DAC based on a duo of ESS ES9038Pro digital/analog converters. It ensures an...
