AUDIO-GD DAC-19 2017 PCM1704UK & DSP USB AMANERO HDMI I2S 24bit 192kHz TCXO
This 2017 edition of the Audio-GD DAC-19 incorporates advanced technologies to ensure exceptional sound reproduction and complete connectivity to meet all your needs!
KEY POINTS:
  • DAC PCM1704UK
  • USB Amanero
  • I2S via HDMI
  • 24bits 192kHz
  • TCXO
By buying this product you get 89 loyalty points
Reference : 11959
899,00 €tax incl.
749,17 € tax excl.
Including 1,00 € for green tax
Audio-GD DAC-19
DAC / DSP / 24bit 192kHz / USB Amanero / HDMI I2S
Audio-GD DAC-19
Performances and rich musicality ...
After the DAC-19 in 2005, DAC-19SE in 2006, DAC-19MK3 in 2008 and DAC-19DSP in 2010, here is the DAC-19 PCM1704UK in its final version, integrating both AMANERO USB and HDMI I2S to meet all your connectivity needs.
Even if Audio-GD had already given it its nobility since 2005, the best technical engineers of the firm offer it here in its most accomplished form, with performances reaching a level that very rarely equaled.
This HiFi analog digital converter with recognized and approved results, received a Qobuzissime from Qobuz, excuse the bit!
Arrière Audio-GD DAC-19
A particularly efficient connection
The integrated PCM1704UK converter allows you to manage sources up to 24Bit / 192kHz. The DAC-19 has 4 inputs: Coaxial S / PDIF, OptiqToslink, USB and HDMI (I2S), as well as 2 analog outputs: RCA and ACSS.
Its SPDIF interface is extremely powerful in terms of data processing for better audio quality.
Great musicality and exceptional dynamics
24bit / 192kHz / USB AMANERO / HDMI (I2S) / TCXO / ACSS
Every product of the brand is scrupulously tested in all seams with one of the most powerful systems in the world: the Audio Analyzers 2700 Series from Audio Precision.
The DAC-19 is equipped with an R-Core transformer, WIMA capacitors, and Date resistors. It is designed around the PCM1704UK and the Altera Cyclone DSP that work in parallel, as well as a Class A ACSS discrete circuit without any PDO with separate power supply.
Audio-GD DAC-19
TCXO 100MHz
TCXO - 100MHz
Usually lAudio-GD devices are equipped with the standard 80MHz clock, except this Audio-GD DAC-19 includes the 100MHz TCXO Ultra Low Jitter option. This TCXO (Temperature Compensated X (Crystal) Oscillator) clock is more precise and significantly reduces the jitter.
PCM1704UK
This analog digital converter makes use of the R2R conversion which consists in directly using the bits of the digital signals to reconstruct the analog signals, all this acting on a network constituted solely of resistors having a given value (R) and its double (2R ), without going through an over-sampling phase.
PCM1704UK
SNR<108dB
THD<0.0005%
Frequency Response20Hz - 20kHz (-0.5dB)
Max Output Level2mA (ACSS) / 2.5V (RCA)
Output impedance10Ω
Input sensitivity0.5Vp-p (Coaxial, 75Ω) / 19dBm (Optical)
Supported sampling ratesUSB up to 192kHz / Coaxial up to 96kHz / Optical up to 96kHz / I2S up to 192kHz
<inputs/ Td>Coaxial SPDIF / Optical Toslink / USB Amanero (iPhone / iPad compatible via Camera Kit) / I2S via HDMI
ExitsRCA / ACSS
Miscellaneous
Consumption16W
Weight5kg
Housing material100% Anodized aluminum
Dimensions320 x 240 x 80mm
AccessoriesPower cable
Color
  • Black
This 2017 edition of the Audio-GD DAC-19 incorporates advanced technologies to ensure exceptional sound reproduction and complete connectivity to...
