Audio-GD's HE-8 is a massive R2R DAC featuring a high-end design based on very high quality components and a symmetrical architecture. It features a conversion stage based on 4 PCM1704U-K DAC chips, discrete audio circuits, Accusilicon femtosecond clocks, FPGA clock management and Class A power supplies isolated in a regenerative system. Its main functions are as follows:
The integrated regenerative power supply works like an electrical generator. It blocks most of the disturbances in the power line, providing a clean power supply to the amplifiers and reproducing neutral, analogue sound. With this architecture, the alternating current passes through the regenerative input transformer, is converted into direct current and then routed to a Class A power supply and then to the regenerative wave generator and gain stages.
A regenerative regular wave generator produces a 50Hz wave with very low distortion that passes through the gain amplifiers and output stages. The regenerative transformers produce a clean AC power supply that feeds the separate Class A power supplies for the left and right channel preamplifiers.
The Class A parallel connection power supply has a very high input impedance to prevent disturbances through the PSU from affecting the signal, and a low output impedance with very high speed and linearity.
The HE-8 DAC is equipped with 4 PCM1704U chips in their K version. These chips, two per channel, perform digital/analogue conversion up to PCM 32bit 384kHz in R2R within a symmetrical design, enabling the HE-8 to offer sound reproduction that's as fine as it is musical.
The final signal stage is the analogue output, which can have a considerable impact on the sound quality of the DAC. After digital/analogue conversion by the R2R DAC modules, the analogue signal is carried by fully discrete matched transistor output stages. The DC-coupled design uses no surface-mount components. The output buffers are Single-ended FETs. Two stages are connected in parallel to achieve very low output impedance. All output stages operate in pure Class A, without any feedback, to achieve the purest, most transparent sound reproduction possible.
The HE-8 features an impressive power supply stage. It uses four high-performance R-Core transformers with a total power of 160W, as well as furthermore 60,000µF of filter capacitors to guarantee a clean and stable electrical signal. 12 sets of ultra-high-speed linear stabilised power supplies provide a separate power supply for the digital circuit, while the analogue part is served by 8 pure Class A power supplies and 4 discrete power supplies. The Class A parallel regulated power supply supplies the regenerative stage and each analogue section separately.
The HE-8 integrates an FPGA and CPLD in order to separate the various configured circuits and avoid interruptions. The internal components are entirely controlled by a complex software layer. A considerable advantage of using an FPGA is that it can be easily upgraded to improve the performance of the device, bringing a degree of flexibility to the device.
In the HE-8, the FPGA's high-performance SPDIF interface replaces traditional SPDIF interface chips, whose performance is inferior to that of an FPGA.
The reclocking process with FIFO design is applied to all inputs. In this way, the output data remains fully synchronised with the clock signal to reject jitter.
The HE-8 features 2x / 4x / 8x oversampling modes and built-in digital filters, as well as four different NOS modes, to suit your listening style and system.
| Specifications | |
| Product type | R2R DAC |
| DAC Chips | 4x PCM1704UK |
| Inputs | 1x AES/EBU 1x Optical Toslink 1x Coaxial 1x BNC 1x I2S via HDMI LVDS 1x USB-B 1x Port for software update |
| Outputs | 1x Single-ended RCA 1x Balanced XLR 1x Balanced ACSS |
| Signal-to-noise ratio (SNR) | > 120dB |
| Output impedance | < 5Ω |
| Output level | RCA : 2.5V XLR : 5V ACSS : 2+2mA |
| Frequency response | 20Hz - 20kHz |
| Total harmonic distortion (THD) | < 0.01% |
| Input sensitivity | Coaxial 75Ω : 0.5Vp-p Optical : 19dBm |
| Compatible OS (USB) | Windows, OSX, Linux, ISO |
| Supported sampling rates | USB, I2S : PCM up to 32bit 384kHz Coaxial, Optique : PCM up to 24bit 192kHz |
| General | |
| Supply voltage | 220-240V AC 50/60 Hz |
| Consumption | 48W |
| Dimensions | 430 x 445 x 80mm |
| Weight | 12kg |
| Color | Black |
| package | 1x AUDIO-GD HE-8 1x Power cable 1x USB cable 1x Remote control |
| Input | USB |
| Input | Optical |
| Input | AES/EBU |
| Input | SPDIF |
| Input | I2S via HDMI |
| Input | Clock (BNC) |
| Output | XLR |
| Output | RCA |
| Output | ACSS |
| DAC / ADC Chip | PCM1704UK |
| Max sampling rate | 384kHz |
| Color | Black |
| Networking | No |
| Remote Control | Yes |
