The NFB-1DAC (2016) is equipped with the ESS ES9018 Sabre component and the Amanero latest generation USB interface.
This new edition offers a better implementation of the Sabre offering a shorter signal path, the possibility of selecting the hardware filters and a DSD auto-sensing (with switching without noise switching).
NFB is the acronym for Non-feedback; technology used by Audio-Gd so as not to "color" the sound at the level of the electronics of the output stage giving you a sound of a very professional neutrality.
The 100% discreet design of this converter is backed by a high power (Class A) power supply.
The I2S input and output are compatible with the DI-2014 of the same brand.
Included Options:
INGREDIENTS | ||
Interface / ConverterAmanero / Sabre ESS ES9018 | ||
STARTERS | ||
USB | USB x1 | |
Coaxial | Digital coaxial x1 | |
Toslink I2S DSD CTR | Optical x1 I2S x1 DSD CTR x1 | |
EXITS | ||
analogXLR x2 RCA x 2 | ||
ACSSACSS x 2 |
Features:/ Strong>
Signal / noise ratio | > 120dB | ||
Output Impedance | 10 ohm / DAC output | ||
Output Level | 2.5V (RCA) 5V (XLR) 1.2 + 1.2MA (ACSS) | ||
Input sensitivity | 0.5 Vp-p (75 Ohms, Coaxial) 19 dBm (Optical) USB1.1, USB2.0 (Full Speed, Class 2) | Supported Systems | Windows, OSX |
Supported sampling rates | USB model: 44.1kHz, 48kHz, 88.2kHz, 96kHz, 176.4kHz, 192kHz, 352.8kHz, 384kHz | ||
Frequency Response | 20Hz - 20KHz (<- 0.2DB) | ||
Consumption | 22 W | ||
Dimensions | 240 x 360 x 80mm | ||
Weight | 5 Kg | ||
Accessories | AC power cord X1 USB cable X1 |
[Img-13671-left-thickbox_default]
[Img-13672-left-thickbox_default]
[Img-14087-left-thickbox_default]
[Img-14088-left-thickbox_default]
Average votes 5.0 / 5 1 reviews | Why write products reviews ? You can share your feelings about products and help other people by sharing your experience |
Stephane C.
