AUDIO-GD NFB-1.38 DAC ES9038pro DSD/DXD Sabre 32bit / 384K USB Amanero HDMI TCXO
The exceptional DAC Audio-GD NFB-1.38 is equipped with an ES9038Pro converter for incredible audio performance but also USB Amanero, I2S and many others ...
KEY POINTS:
  • DAC ES9038Pro
  • 32bits 384kHz
  • USB Amanero / I2S HDMI
  • TCXO
  • DSD128 / DXD
4.5 / 5
By buying this product you get 99 loyalty points
Reference : 11834
990,00 €tax incl.
825,00 € tax excl.
AUDIO-GD NFB-1.38 ES9038 TCXO
DAC 32bit 384khz AMANERO I2S HDMI USB
Audio-GD NFB-1.38
Versatile, efficient, unmissable
The NFB-1.38 DAC is equipped with the latest ESS ES9038pro Sabre component and Amanero latest generation asynchronous USB interface.
This new edition proposes a better implementation of the Sabre proposing a path of the even shorter signal really symmetric and the possibility to select the hardware filters FIR PCM, DSD. The detection of different DSD formats (with switching without noise switching) is now automatic.
NFB is the acronym for "No Feedback" used by Audio-GD. This technology on the analog stages allows a great respect of the harmonics, without distortions, without numerical durations.
USB AMANERO and I2S HDMI
The built-in SABRE ES9038Pro allows you to manage 32Bit / 192kHz sources both in SPDIF and USB, and up to 384kHz in USB. In order to use the NFB-1.38 on Windows via its USB-B input on the rear panel, you must firstdownload the Driver Amanero Combo 384 AUDIO GD: Amanero Combo NFB 1.38 ES9038 driver.
Audio-GD NFB-1.38
Bewitching sound reproduction
32bit / 384kHz / DSD / DXD / TCXO
The 100% discrete design of this DAC (no PDO) goes through three stages (voltage, low pass filter, buffer) with transistors without any capacitors on the audio path, supported by a class A power supply with a fast rise time capable of provide the necessary energy.
Nover (UK) capacitors have been specially manufactured on Audio-GD specifications. The output transistors Toshiba and Hitachi have been manually paired. AUDIO GD use the best available components: Wima, Dale, ESS, Atmel.
Audio-GD NFB-1.38
TCXO
TCXO - 100MHz
Usually appsAudio-GD's are equipped with standard 80MHz clocks, except this DAC Audio-GD NFB-1.38 includes the 100MHz TCXO Ultra Low Jitter option, perfectly associated with the ES9038. This TCXO (temperature compensated oscillator) clock is more accurate significantly lowering the Jitter.
SABRE ES9038 and ACSS
This high fidelity DAC is equipped with the famous ESS ES9038Pro 32 bit / 384kHz. This conversion chipset is capable of reading High Definition formats from DSD to PCM with one of the best signal-to-noise ratios on the market (120dB real on XLR). The ACSS analog output stage, which is a feature of AUDIO GD, reduces the signal with only one buffer stage and an original Dale (USA) resistor. This shortest signal path allows the ES9038Pro to reproduce the highest level of detail and dynamics on ESS SABRE DACs.
DAC ES9028Pro et ACSS
SNR120dB (XLR outputs)
Output LevelRCA: 2.5V RMS / XLR: 5V
ACSS Output Level1.2 + 1.2mA
Output impedance2 Ohm (Normal DAC Output)
Supported Operating Systems(44.1kHz to 384kHz) / OSX (44.1kHz to 384kHz) / USB compatible iPhone and iPad via Apple Camera Kit
Sample rateUSB and I2S up to 384kHz / Coaxial up to 192kHz / Optics up to 96kHZ / DSD64, DSD128 and DXD
Input sensitivity0.5Vp-p (75 Ohm, Coaxial) / 19dBm (Optical) / USB 2.0 (Full Speed)
Frequency Response20Hz - 20kHz (-0.2dB)
Miscellaneous
Consumption28W
Weight5kg
Housing material100% Aluminum
Dimensions240 x 360 x 55mm
Accessories1x Power cable / 1x USB cable
InputBNC
InputI2S via HDMI
OutputACSS
DAC / ADC ChipES9038PRO
Max sampling rateDSD128
Max sampling rate384kHz
2 reviews
très bon produit
après quelques heures d'écoutes, ce dac ne déçoit pas,
Très détaillé, offrant une scène sonore ample, cet audio-gd est un plaisir à écouter.
En y associant un bon câble secteur et des cables XLR de qualité les résultats en rapport qualité/ prix sont très au-dessus de la moyenne.
Eric
Roers studio 1, Roksan, Yba cd1 alpa, hifi cables (Thot)
This review has been posted for AUDIO-GD NFB-1.38 DAC ES9038pro DSD/DXD Sabre 32bit / 384K USB Amanero HDMI TCXO
Implémentation originale du 9038 pro, sonorité analogique
J'ai mis un peu de temps avant de poster ce commentaire, afin de réécouter d'autres DAC avec le fameux 9038 pro d'ESS, qui rebat un peu les cartes au niveau des puces sigma delta.
J'ai été bluffé par la première écoute du 9038 pro, faite sur un oppo 205, dont c'est vraiment le point fort (le seul diront les mauvaises langues), et lors de l'écoute de ce NFB-1.38, même si la qualité était très élevée, je ne retrouvais pas la même signature sonore. Je ne souhaitais pas tirer de conclusions rapides sur une éventuelle implémentation "inférieure" d'Audio-GD.
A l'écoute, ce Audio-GD est excellent, avec beaucoup de matière et surtout ce rendu organique, mais excessivement propre, net précis. Assez troublant, je ne m'attendais pas à ce rendu après avoir écouté le Oppo, pourtant avec la même puce. J'ai également constaté ouverture de scène légèrement moins large sur le Audio-GD, mais la spatialisation est assez similaire.
En investiguant, mais surtout en réécoutant le Oppo après coup (je n'avais pas le oppo 205 en même temps que le NFB 1.38) j'ai compris le pourquoi du comment.
Audio-GD ne respecte pas tout à fait les recommandations d'ESS pour la mise en œuvre de son dernier-né le 9038, et assume ce choix : Kingwa souhaitait gommer l'aspect parfois perçu comme trop clinique de la techno d'ESS, et c'est réussi ! Ecoute fluide, ample, excellente dynamique, très belle matière sonore, avec un léger côté chaud (ou moins froid) très agréable. Dans ses dernières électroniques, Audio-GD a travaillé pour peaufiner un son plus analogique et c'est très encourageant.
En réécoutant le Oppo 205 par la suite le constat se confirme, une légèrement meilleure ouverture sonore pour ce dernier, mais un rendu un peu plus clinique.
Au niveau des entrées, le seul regret est qu'il soit difficile d'exploiter facilement l'entrée I2S (les cartes Pinkfaun I2S sont chères, et difficilement trouvables). L'entrée USB Amanero est de bon niveau mais les entrées SPDIF sont supérieures (si tant est qu'on se limite au PCM...dès que l'on passe au DSD, l'USB est incontournable).
Quant aux sorties, je n'arrive décidément pas à me faire à la connectique ACSS : testée avec un ampli casque audio-GD, le gain (le volume) de cette sortie est inférieur à la sortie XLR, et le rendu est excessivement plat, liquide, doux. On discerne quand même tous les détails, mais je ne me fais pas à la manière dont ils sont rendu. ça manque de punch, cette sortie est pourtant plus "pure" dans le sens où elle subit moins de conversions, mais je préfère la sortie XLR, vraiment excellente. D'ailleurs avec le XLR, je n'ai pas besoin de pousser très fort mon ampli casque Audio GD pour avoir un niveau sonore très satisfaisant. Je suis obligé de pousser un peu plus fort avec l'ACSS.
Concernant les sources, bluffant sur le PCM,et tout simplement incontournable sur le DSD en natif (testé jusqu'au DSD256). Mais même des mp3 passent très bien sur ce dac (enfin, les bons mp3 bien encodés, en 320kbps...).
Superbe DAC mais il y a beaucoup de concurrence sur ce segment, la plus violente vient selon moi du Oppo Sonica, qui apporte plus de fonctionnalités (notamment en termes de connectivité sans-fil), mais un son moins organique, moins singulier. Le Audio-GD a pour lui une entrée I2S, et des sorties ACSS compatible Krell dont il y a des inconditionnels.
Ce DAC m'a donné très envie d'écouter l'implémentation en dual mono d'audio-GD sur la série des .77 (7.77 ou le 27.77) avec deux ES9038 pro bridgés en mono.
 (5)
The exceptional DAC Audio-GD NFB-1.38 is equipped with an ES9038Pro converter for incredible audio performance but also USB Amanero, I2S and many...
