AUDIO-GD R2R 2 DAC DSP FPGA USB AMANERO LVDS HDMI I2S INPUT 24bit 384KhzTCXO
By buying this product you get 81 loyalty points
Reference : 12261
819,00 €tax incl.
682,50 € tax excl.
AUDIO GD R2R 2 FPGA LADDER DAC
Audio-GD R2R 2 FPGA LADDER DAC
AUDIO GD pushes the limits of a DAC 24BIT 384khz based on R2R technology corrected by DSP FPGA. the DAC R2R 2 offers a formidable ratio pricing pleasure always allied with the technical choices that make AUDIO GD today a major player of the High Definition converters.
The advantage of discrete R2R DACs
A discrete R2R DAC is known to be superior to an integrated R2R chip setup like PCM1704K or AD5791 offering a more natural listening acumen. The technical advantages are: The R2R DACs filter the noise of clocks that are not found on the analog signal. The R2R DACs are less sensitive to jitter on the 16bit definitions. The analog signal is theoretically more accurate than a DAC based on Delta Sigma technology.
A DSP FPGA processor
The DSP FPGA installed in the DAC AUDIO GD R2R 2 allows to overcome the inaccuracy of the resistances beyond 16/21 bit. We thus benefit from anot high precision even in High Definition 24 bit 384khz. These technical qualities are also: better processing from the SPDIF (coaxial, optical) inputs than the usual integrated interfaces (WM8505, DIR9001) thanks to faster computing power and FIFO buffer stages reducing the jitter drastically.
Audio-GD R2R 2 FAD LADDER DAC
Analogue stages in pure class A
Based on an expertise of over 20 years, kingwa designer AUDIO GD excels in creating analog stages without counter-reaction. The output circuit of the DAC R2R 2 benefits from this long research work incressant with stages entirely discrete transistors sorted and paired. There are no surface components and minimal components on the signal path. The last buffer stages are single-ended FET-type transistors with two-stage parallel bandwidth guaranteeing a low output impedance. this latter part has no capacitors in the signal path. Well-on this converter has high-speed outputs with high-current ACSS stage. There is no relay on the analogue circuit in the pure spirit "less is better".
DAC24bits 384kHz R2R scale
Digital Input Sensitivity0.5V pp (75Ω Coaxial), 19dB on Toslink optics
Distortion rate per harmonic0.003% over 20 to 20kHz unweighted
Bandwidth20 to 20kHz
Output Voltage Level2.5V (RCA), 2mA (ACSS)
Signal Ratio108dB
Output impedance10Ω (RCA)
Adjustment oversampling by jumperX2, X4, X8
Non Over Sampling Mode (NOS)By jumper
Sampling rate per digital inputs
USB and HDMI LVDS I2SPCM 44.1kHz - 384kHz to 16-32bits
USB and HDMI DSDDSD64 to DSD256
Input SPDIF Coaxial24bits max 44.1kHz-192kHz
Input SPDIF Optical24bits max 44.1kHz - 96kHz
USB CompatibleWindows 7, 8, 8.1, 10 (requires a driver), MAC OS 10 and Linux
Internal clock
ClocksDouble TCXO high precision clocks
<!--CHARACTERISTICS SECTION ->
Miscellaneous
FoodLinear 3-stage power supply with 5 groups, low noise class A
Dimensions240 x 320 x 80mm
Weight5kg
Accessories1x USB cable, 1x IEC power cable
Mapping I2S / LVDS
A synthesis of main IIS on LVDS pinouts mapping is available here.
InputI2S via HDMI
OutputRJ45
OutputACSS
DAC / ADC ChipR2R LADDER DAC
Max sampling rateDSD256
Max sampling rate384kHz
audio-gd r2r
je sui pleinement satisfait de ce DAC , la qualité de cette appareil est au top il en vas de même pour le son
This review has been posted for AUDIO-GD R2R 2 DAC DSP FPGA USB AMANERO LVDS HDMI I2S INPUT 24bit 384KhzTCXO
