AUDIOPHONICS DAC AK4495SEQ 32bit 192kHz Asynchronous USB XMOS Black
AUDIOPHONICS DAC AK4495SEQ 32bit 384kHz Asynchronous USB XMOS Black
Excellent converter, this small solid aluminum case with a very elegant design features the AKM AK4495SEQ converter coupled with a digital AKM AK4118A interface with very low jitter (50ps).
4.7 / 5
Reference : 11961
199,00 €tax incl.
165,83 € tax excl.
AUDIOPHONICS DAC AK4495SEQ 32bit 384kHz Asynchrone USB XMOS Noir
Excellent converter, this small solid aluminum case with a very elegant design features the AKM AK4495SEQ converter coupled with a digital AKM AK4118A interface with very low jitter (50ps). This 32bit 192Khz DAC has a filter stage composed of a highly neutral operational amplifier, the LME49720HA. This PDO, known for its dynamics and precision, is mounted on an interchangeable DIP8 bracket to be replaced as you wish to adjust its sound signature.
Its Audiophonics XMOS U8 32bit 192Khz interface equipped with two high-precision clocks allows this DAC to read High Definition files up to DXD 32bit 384Khz. This DAC AK4495SEQ also has two digital filters Sharp (Filter 1) and Roll Off (Filter 2) accessible by pressing the "Input" button.
Equipped with high-end components (LDO LM2941 low noise controllers, R-Core transformer) of meticulous construction, this DAC will quickly become a powerful link for any high fidelity audio system.
Caution : the RCA sockets mounted on the back panel are not supported by CANARE cables.
Product typeDAC
Conversion chipAKM AK4495SEQ
SPDIF InterfaceAKM AK4118
THD0.001%
SNR120dB
Inputs1x USB XMOS up to 32bit 192kHz / DSD64 (PCM)
1x Coaxial 24bit 192kHz (Gold plated 24k)
1x Optical 24bit 96kHz
Output1x RCA Gold plated 24k
Dimensions261 x 190 x 62mm
Weight2.4kg
CompatibilityMAC OSX, Linux
Windows with driver
Câble secteur non fourni.
DAC / ADC ChipAK4495S
Max sampling rate192kHz
Max sampling rateDSD64
26 reviews
Superb
So i bought this used, just wanted to post this review because this really is an amazing DAC and even at retail value it is fully worth the price. It's a bit of a shame that Audiophonics discontinued it.
I use mine connected via USB to a computer running Roon.
Outputs to a Rotel pre and power amp driving a pair of B&W CDM7 SE speakers.
I'm not really sure about the filters but i listen to a lot of slow/ambient electronic music and prefer the slow roll filter in general, it seems to make the bass roll off in a smoother fashion.
However there's one quirk with mine (maybe can be fixed with software update? If Audiophonics can chime in that'd be much appreciated).
So when i turn it on and play files from different sample rates the display will get stuck and the source/filter button doesn't work anymore so the DAC needs to be restarted.
A workaround i've found to this issue is just switching the channel back and forth back to USB again first thing after power up
So a minor annoyance which i will gladly oversee, but would be nice to get fixed.
Overall superb value for money.
This review has been posted for AUDIOPHONICS DAC AK4495SEQ 32bit 192kHz Asynchronous USB XMOS Black
Un bon DAC
Bon RQP. Offert à mes parents qui ont très apprécié l'amélioration sur leur système.
Filtres... Quoi comment pourquoi ?
Bonjour
Ravi d'utiliser ce DAC, mais quelqu'un pourrait-il m'expliquer la signification et l'utilisation des différents filtres présents sur ce DAC ?
En l'absence de notice et d'explications, je suis totalement incapable d'exploiter ces fonctionnalités ajoutées, et cela est bien dommage... Merci pour votre aide à tous !
Bonjour,
Voici l'article le plus complet que nous connaissions sur le sujet :
https://www.audiostream.com/content/what-are-digital-filters-and-why-are-they-requried-todays-audio-dacs-resonessence-labs-tech-3
Bof
Avis mitigé sur ce DAC, je l’ai trouvé inférieur au FX-Audio FX01, alors qu’il coûte bien plus cher. Sur mon système haut de gamme (PLLXO sur Youtube) il manque sérieusement d’ouverture dans les médiums (nasillard) et les aigus sont plutôt durs, mes Magnepan ne font pas de cadeaux à ce niveau-là. Ceci comparé à un DAC Yggdrasil (ou un Dacgear), réputé pour son rendu naturel, quasi analogique. Le FX01, malgré un grave trop en avant, présentait des timbres plus réalistes. Sur mon second système, enceintes DIY (double Markaudio Alpair M10.3 en // enceinte MLTL), préampli FX-Audio Tube01 (tubes Russes) alimenté par batterie, amplis monoblocks 3e-audio TPA3255, le grave est spectaculaire, sec, profond et varié, la contrebasse est un régal. Là où cela se gâte c’est à nouveau dans les médiums et les aigus. Les Alpairs ont une tendance montante bien connue, en disposant bien les haut-parleurs, c’est presque « flat ». Avec mon Yggdrasil les médiums sont nettement plus riches, ouverts, spontanés et les aigus absolument pas agressifs. Ce n’est pas le cas avec ce DAC Audiophonics, même si sur mon second système cela se remarque moins. Pour les graves 10/10, les médiums 6/10 et les aigus 6/10. Attention aux voix féminines stridentes ! Sur un système avec un grave légèrement en retrait et avec des tweeters à dôme en tissu, il doit tirer son épingle du jeu.
Incontournable et musical ! excellent Rapport Q/P :-)
J'ai acheté ce Dac Audiophonics visiblement bien construit et équipé en AK4495SEQ sans pour autant avoir pu le testé...C'est chose faite, avec quelques semaines de recul voici mon ressenti : Incroyable à ce tarif encore raisonnable ! Relié à mon lecteur CD de bonne facture équipé en Sabre ES9018 pourtant mélodieux, je gagne en qualité de timbres sur les voix, c'est plus agréable mais je ne perd pas en détails, et surtout les notes ont plus de poids :-) c'est net ! tous les styles de musique y passe avec plus de corps. C'est réellement plaisant, idem avec mon PC/Foobar 2000 qui a fait un bon en avant qualitatif ! Le mariage avec mon ampli McIntosh MA252 (Quel régal cet ampli, la beauté des timbres, aigus, médiums, graves tout est beau et équilibré) est excellent même en comparaison d'autres DACs plus connus et plus chers...Pour le budget, pas de craintes à commander sans écouter, impossible d'être déçu à mon humble avis. Je n'ose imaginer les gammes supérieures à l'écoute...mais encore faut-il que la fabrication et les composants soient bons, bravo messieurs les techniciens pour votre conception de qualité à prix démocratique. Merci à vous, musicalement votre, Laurent J.
Excellent converter, this small solid aluminum case with a very elegant design features the AKM AK4495SEQ converter coupled with a digital AKM...
