AUDIOPHONICS U-Sabre USB DAC 24Bit/96kHz SA9023 / ES9023 OTG V2.2E
4.9 / 5
Reference : 11055
39,90 €tax incl.
33,25 € tax excl.
Since January 15, 2025, some owners of USB Audio Class 1 DACs have reported the following error after installing Windows updates:
Code 10 ''Insufficient system resources to complete the API".
The cause seems to be linked to Windows Update KB5050009 or KB5050021 or KB5049981 . Uninstalling these updates will allow the device to work again. We therefore recommend that you uninstall these updates until Microsoft has corrected the problem.
This model is replaced by the new version: U-SABRE TCXO Edition.
AUDIOPHONICS U-SABRE
USB DAC 24bit/96kHz SA9023 / ES9023 V2.2E with Optical Output
Audiophonics U-Sabre ES9023
A DAC with a shimmering sound ...
The Audiophonics U-SABRE ES9023 USB DAC is evolving with the addition of a digital output in TOSLINK 24bit 96Khz optical format. The benefits of this nomadic DAC are numerous.
The quality of the components is first class with Vima brand condensers, Rodenstein. So here is a DAC pocket size with the great sound of Hifi lounge devices.
ES9023 ES9023 high accuracy ESS USB DAC
The analog output has only two high quality film capacitors on its way. The auditory result is immediately tangible with greater freedom in the treble medium and a serious register perfectly cut off. A USB DAC with high-end services in a compact format
This new version features a Mini Toslink 24/96 digital output paired with the 3.5mm analog output.
Compact and musical
A USB Audio Plug & Play Audiophile DAC
The USB Powered Audiophonics U-Sabre ES9023 DAC on any notebook or computer has an external 6V or 9V power port that addresses issues related to USB ports with low voltage and amperage.
Audiophonics U-Sabre ES9023 USB SA9023
USB SA9023 Input
The U-SABRE USB input uses the SAVITECH SA9023 to ensure low power consumption, ease of installation and the perfect ASIO Bit cable for seamless playback of High Definition audio files.
Audiophonics U-Sabre ES9023P
ES9023P
This high-definition nomadic DAC, equipped with the famous ES9023 SABRE 24bit 96Khz integrates Hyperstream technology overcoming the usual defects of conventional Delta Sigma DACs. The result is immediately tangible, with a feeling, a sound precision over competing technologies Delta Sigma.
Audiophonics U-Sabre ES9023 LDO LT1763
Linear technology LDO LT1763
This product can function as the older generations ie directly in USB, without additional power optimally thanks to its low noise regulator of origin Linear Technology LDO LT1763.
CompatibilityNative / Plug & Play sur Windows, Linux, OS X
USB ModeAdaptative
DACAsynchronous Sabre ES9023
Direct-Out(minimal analog output scheme)
PowerDoes not require external power supply - External power supply option on DC Jack 2.5x2.1mm 6V ~ 9V DC
ASIO SupportYes - Driver in attachments
Inputs
USB InterfaceSA9023 (SAVIAUDIO) : 16/24 bit and 32kHz, 44.1kHz, 48kHz, 88.2kHz, 96kHz
I2SI2S
USBwe recommend the use of qualitative cable and length less than 1.5m
Outputs
Jack 3.5mmline (1.7V rms)
RCA Stereo1.7Vrms
Optical ToslinkMini Toslink Format 24bit/96 Khz
Package content
Clubic
Micougnou
OutputJack 3.5mm
Max sampling rate96kHz
24 reviews
Parfait, fait le job !
Installation immédiate, mon ultra portable (HP) donne assez de courant sur l'USB pour être autonome. Installation immédiate, fonctionnement parfait avec Foobar. (bon il faut paramétrer un peu... mais ça c'est foobar)
PS en Revanche livraison Colissimo ZERO POINTE TOTAL comme d'hab !
This review has been posted for AUDIOPHONICS U-Sabre USB DAC 24Bit/96kHz SA9023 / ES9023 OTG V2.2E
Excellent
Commander pour bénéficier d'une meilleure qualité de son au bureau, je suis emballer par le rendu sonore. Je pense qu'elle restera chez moi en remplacement de mon DAC NG27MK2. Livraison impécable à la Réunion.
comment avoir un beau son pas cher sur son pc
pour une somme modique vous obtenez un amélioration de la qualité du son spectaculaire. J'ai équipé mes 2 pc de ce petit article qui se substitue automatiquement et avantageusement aux cartes son des pc. Derrière je n'ai un home cinéma entrée de gamme
Il faut y penser avant d'envisager de mettre cher dans la suite analogique (ampli & hp)
DL22
Facile à installer, reconnu sans problème, effets immédiats. Parfait.
Excellent
Reconnu immédiatement par Windows 10 et Linux Mint 18 (il suffit de sélectionner la sortie Audiophonics U-SABRE).
Fonctionne parfaitement avec la sortie mini-jack comme la sortie 2x RCA.
Le son est parfaitement propre.
