AUNE S16 2016 DAC DSD / DXD AK4495S 32bit / 384kHz XMOS
By buying this product you get 66 loyalty points
Reference : 10955
669,00 €tax incl.
557,50 € tax excl.
The AUNE S16 comes back in version 2016 (evolution optimized for helmets and intraaricular low impedance).
It is equipped with the best in each domain and allows you to have a high quality conversion that supports all sampling rates as well as the DSD.
Equipped with four digital inputs, two analog RCA and XLR outputs from a selection of sources and a volume control by PGA2311, it is a serious converter with significant advantages.
Features:/ Strong>
  • White TFT display
  • DAC: AK4495S
  • Natively recognized on Mac OS and Linux without drivers
  • Bitperfect: Wasapi / Asio for Microsoft XP to Win8
  • Inputs: 1x Optical Toslink, 1x Coaxial, 1x USB B and 1x AES / EBU
  • Decoding up to 32bit / 384kHz (USB) per XMOS interface and 24bit / 192kHz for other digital inputs
  • DSD native support (DSD64 (dop / native), DSD128 (dop / native)
  • Digital isolation of USB and Coaxial inputs
  • 2x high precision clocks CRYSTEK CCHD-957
  • Shielded Toroidal Transformer
  • Stereo analog outputs on RCA and XLR
  • Output Voltage (RCA): 2.8Vrms
  • Output Voltage (XLR): 5.6Vrms
Headphone output:
  • 300mW @ 600 Ohm
  • 600mW @ 300 Ohm
  • 1500mW @ 120 Ohm
  • 3000mW @ 32 Ohm
The Bundle contains:
  • A USB cable of 1m50
  • A mains cable of 1m50
  • A mini CD containing Windows drivers
  • A manual in English
Physical characteristics:
  • Selecting sources by pushbutton
  • Volume control for helmet with notched potentiometer
  • Chassis Aluminum Black anti-oxidation treated
  • Non-slip rubber feet
  • Dimensions of the case: 255 x 211.5 x 58mm
  • Weight 2.450kg
AUNE S16
T
is in French(Click here)
Test in French (Click here)
[Img-14664-left-thickbox_default]
aune
aune
aune
aune s16
[Img-11896-left-thickbox_default]
[Img-11897-left-thickbox_default]
Illustration with the file player Aune S18.
