This little AVANTREE DAC01 converter very affordable and capable of handling sampling rates up to 24bit / 192kHz (DAC WM8523) will prove to be the ideal companion for anyone wishing to move smoothly to dematerialized.
heis also useful for powering an analog stereo system from your modern TV with only digital outputs. Simply connect the DAC to your optical or coaxial TV, then connect the DAC to your amplificaudio actoranalog to RCA to enjoy its quality of conversion and decoding.
Its outputhelmet(can be used simultaneously with other outputs) will allow you to enjoy a clean and neat amplification thanks to its chip APA3541 Class A / B Stereo.
The present volume button is only used to control the headphone output, not the volume of the DAC itself.
Technical specifications:
Conneco / Packaging:
[Img-21424-left-thickbox_default]
[Img-21427-left-thickbox_default]
