CHORD Mojo Headphone amplifier USB DAC 32bit 768khz Battery Android iOS DSD
By buying this product you get 54 loyalty points
Reference : 10974
545,00 €tax incl.
454,17 € tax excl.
Chord Mojo dac DSDCHORD Electronics demonstrates its great mastery in the DAC universe bringing the CHORD HUGO technologies at an affordable price.
the CHORD Mojo is designed to make its use simpler, bringing high resolution 32 bit 768Khzdefining the CHORD brand, flagship of the leading edge technology.
This famous CHORD MObile JOy (Mojo) featuresthe WTA filterincorporated in all DACs of the mark up to CHORD DAVE, one of the best converters in the world.
Incorporating theDAC FPGA (Xilinx)moving away from the classical solutions, Chord Electronics brings Hifi High-End in a handheld portable battery format./ P>
Highlight of the DAC CHORD Mojo:
  • Programmable DAC based on FPGA 64bit Xilinx Artix 7bringing computing power well above all integrated solutions.
  • 10 hours battery life (manufacturer data). (Background noise from power supplies at the limit of the measurable).
  • Digital WTA filterwithout phase rotation with 1024TAPS (number of calculation points) at 768 KHz.
  • High-precision digital volume on 64 bit non-destructive.
  • Wide headset compatibility up to 600 Ohm .
  • A "liquid" sound that does justice to high definition files compatible DSD Quad Rate.
  • Two 3.5mm headphone jacks for dual playback.
  • Box ina machined aluminum block , aviation-level aviation.
  • Color LEDs showing battery status, resolution, volume, easily identifiable.
  • Designed and manufactured in England
Chord Mojo review by Qobuz
" The DAC Chord Mojo, while abandoning the rich connectivity of its big brother Hugo, nevertheless offers the essential, in particular the same shimmering and more beautiful than life sound quality at a much more affordable price. "
Test Qobuz
Main Features:
  • DAC nomadic on high-definition battery 32bit 768Khz.
  • Compatibility DSD: (64, 128 to 256 Quad rate DOP format) and DXD 32bit.
  • Apple iOS compatiblecamera KIT .
Types of inputs and outputs:
  • 1 Micro USB: 32bit 768Khz. (compatible with Linux OS, Android, OSX Apple, Win 7,8,10.)
  • 1 coaxial input mini jack 3.5mm from 44.1Khz up to 384Khz.
  • 1 Micro USB port for charging.
  • 1 optical Toslink input 24bit 44.1khz to 192Khz and DSD64 (DOP format).
  • 2 stereo mini headphone jacks.
Specifications:
  • Output power at 1Khz: 35mW at 600Ohm / 720mW at 8Ohm.
  • Output impedance 0.075.
  • Dynamic range: 125dB.
  • Total harmonic distortion: on 3V: 0.00017%.
Food :
  • Sector or battery (10 hours of autonomy according to manufacturer data.)
  • Charger supplied.
Dimensions and weight:
  • Dimensions: 60 (L) X22 (H) X82 (P) mm.
  • Weight: 180g.
Video by Hans Beekhuyzen Channel
Meaning of CHORD MOJO color codes.
[IMG-17016-left-thickbox_default]
OutputJack 3.5mm
Max sampling rateDSD256
Max sampling rate768kHz
