CYP DCT-1D Optical DAC Dolby Digital 24Bit / 96kHz
Reference : 11641
95,00 €tax incl.
79,17 € tax excl.
The DAC Optical DCT-1D is an analog audio converter with Dolby Digital 2Ch decoder. It converts the Toslink digital audio signal into an analog stereo signal and can support audio streams up to 48kHz (Dolby Digital) or 96kHz (LPCM), and a transfer rate of up to 24Bit.
This small converter is the ideal solution to connect the sound of your TV to your HiFi system without any fault and loss of quality.
It offers high-performance sound conversion to analog stereo output, and guarantees Dolby Digital signal transmission without any loss of quality.
The DAC DCT-1D can be powered from any USB port: Televisions, Blu-Ray Player, Computers, etc. No need for a separate power supply.
User manual available in the "Download" tab.
Technical characteristics :
  • Supports LPCM 2Ch sampling frequencies: 32kHz, 44.1kHz, 48kHz, 88.2kHz, 96kHz
  • Supports uncompressed Dolby Digital 5.1Ch up to 48kHz
  • SPDIF 24 bit bitstream support for left and right channels
  • Ergonomic design and easy installation
  • Output Level: 1Vrms (+/- 10%)
  • THD + N: <0.018%
  • Signal Noise Ratio:> 80dB
  • Crosstalk: <80dB
Main Features :
  • Inputs: Toslink Optic (LPCM / Dolby Digital) / Micro USB (For power supply)
  • Output: RCA Stereo (Red and White)
  • Dimensions: 55x82x22mm
  • Weight: 65g
  • Supplies in 5V (Consumption 1.8W): power supply not delivered
  • White Colour
DAC / ADC ChipNC
Max sampling rate96kHz
ColorWhite
3 reviews
bien mais niveau de sortie un peu faible
Je l'ai acheté pour pouvoir avoir le son de Netflix sur ma chaine stéréo qui ne reconnaissait pas le dolby (via la sortie optique de ma TV)
Cela fonctionne parfaitement
Par contre le niveau de sortie est un peu faible , mais vu la puissance de mon ampli ça ne me pose pas de problèmes en pratique
This review has been posted for CYP DCT-1D Optical DAC Dolby Digital 24Bit / 96kHz
CYP DCT-1D DAC Optique Dolby Digital 24Bit / 96kHz
Très bon produit.
A priori c'est le seul convertisseur qui prend en compte le Dolby généré par les chaines TNT.
Pour ce qui concerne Audiophonics, ça parait sérieux, la livraison est rapide, le prix est compétitif ... rien que du positif sur cette commande.
Objet rare...
Ce modèle de convertisseur est le seul qui convienne lorsque vous souhaitez utiliser la sortie optique et que le menu de votre TV n'offre pas la possibilité de rétrograder le mode son en stéréo (au lieu de Dolby Digital + / DTS). De fait, il est un peu cher mais fonctionne parfaitement avec toutes les chaînes de la TNT HD et/ou issues d'une box câble. À la rigueur, on pourrait lui reprocher un niveau de sortie un peu faible sur les RCA ; il faut monter un peu le son de l'ampli auquel on raccorde ce système.
