CYP DCT-9DD DAC and ADC Dolby Digital DTS 2.0 Digital Out 24bit 96kHz
The compact CYP DCT-9DD DAC and ADC will allow you to convert a digital stream into analog and vice versa. It integrates both input and output connections consisting of stereo RCA, coaxial and Toslink optical.
By buying this product you get 22 loyalty points
Reference : 16877
229,00 €tax incl.
190,83 € tax excl.
CYP DCT-9DD
DAC and ADC Dolby Digital DTS 2.0+ Digital Out 24bit 96kHz
CYP DCT-9DD DAC et ADC Dolby Digital DTS 2.0+ Digital Out 24bit 96kHz
The compact CYP DCT-9DD DAC and ADC will allow you to convert a digital stream into analog and vice versa. It integrates both input and output connections consisting of stereo RCA, coaxial and Toslink optical. The device also supports the simultaneous conversion of audio streams. It is thus possible, for example, to convert an optical input signal to both RCA and coaxial. It also supports Dolby Digital and DTS 2.0+ Digital Out audio formats. Ideal for integration into a home cinema system.
Product typeDAC
ADC
Inputs1x Optical Toslink
1x Coaxial
1x Stereo RCA
Outputs1x Optical Toslink
1x Coaxial
1x Steroe RCA
Supply voltage5VDC 1A (power supply included)
Consumption2.2W
Housing materialPlastic
Dimensions85*35*85mm (excluding connectors)
97*35*85mm (including connectors)
Weight108g
ColorWhite
OutputOptical Toslink
OutputCoaxial SPDIF
DAC / ADC ChipNC
Max sampling rate96kHz
ColorWhite
The compact CYP DCT-9DD DAC and ADC will allow you to convert a digital stream into analog and vice versa. It integrates both input and output...
