DAART Canary DAC USB XMOS DSD ES9018K2M 32Bit Headphone out class A Black
By buying this product you get 20 loyalty points
Reference : 11578
209,00 €tax incl.
174,17 € tax excl.
The DAART DAART Canary USB 32 bit 384Khz represents the new generation of audiophile converters with a powerful headphone output in discrete components. Equipped with a ES9018K2Mthe DAART Canary has 3 digital inputs for decoding all high-definition stereo signals up to DSD DOP 64/128 and PCM 384Khz (USB).
es9018k2m daart canary
the technological advantages of this CAD are many:
  • USB interface XMOS U8 and converter 32bit SABER ES9018K2M
  • Audiophile precision potentiometer
  • CLC-Type Conversion Filter
  • DAC reference voltage separated by low-voltage voltage regulator LDO
  • Double clocks 22 and 24mHZ
  • 5 separate LDO control groups for each voltage
  • Headphone Amplifier with JFET Class A Transistor
  • Aluminum housing
An analog output of very high quality:
The DAART canary USB digital converter features the latest generation of high-precision (rail to rail) OPA1688at high current. They allow a high dynamics and are particularly adapted to the high resolution sound of 32bit DACs. In addition, the current stage voltage at the output of DAC comprises ADA 4075 with very low noise.
Main Features :
  • Digital inputs : SPDIF / Optical Toslink compatible PCM 24bit 192KHz
  • Digital Input USB compatible Native DSD64 / 128 / PCM 16-32bit, 32-384KHZ.
  • Headphone output with high impedance input and JFET class A transistor.
  • RCA Stereo Outputs
  • Aluminum housing and feet.
Warning !Analog RCA outputs are fixed and non-variable.
USB Compatibility:
  • Windows 7/8/10, MAC OS10X, Linux, Android
  • Warning this DAC is not compatible Apple iOS
Test du Daart Canary par Qobuz
" Ce DAC Daart Canary offre une restitution un peu marquée dans le haut du spectre dont les résultats seront appréciés selon ses goûts et les musiques écoutées. Son amplificateur pour casque intégré, puissant et neutre pourra également se prêter à l'écoute d'une source analogique externe dans de très bonnes conditions. "
Test Qobuz
Specifications:
  • Noise signal ratio: -128dB.
  • Dynamic capacity: 120dB.
  • Harmonic distortion 0.0004%.
  • Frequency response: 20-30KHz to plus or minus 0.15dB.
  • Channel separation (crosstalk): -120dB.
  • Headphone output according to impedance: 100mW @ 600 Ohm, 200mW @ 300 Ohm, 400mW @ 150 Ohm, 1000mW @ 32 Ohm
Dimensions and weight:
  • Dimensions: 27.5 x 22.5 x 7cm
  • Weight: 1.2kg
XMOS U8 and dual clocks 22.579MHZ and 24.576MHZ
Class A helmet amplification with discrete components
OutputJack 6.35mm
