DENAFRIPS ENYO 15TH Balanced R2R DAC Black
The Denafrips Enyo 15TH DAC is an R2R digital-to-analog converter supporting high-resolution audio streams up to PCM 24bit 1536kHz and DSD1024. R2R technology enables Enyo to deliver a natural, faithful and musical sound reproduction.
By buying this product you get 79 loyalty points
Reference : 19477
790,00 €tax incl.
658,33 € tax excl.
Shipping date: 25-04-2025.
Denafrips Enyo 15TH Balanced R2R DAC 24bit 1536kHz DSD1024 Black
Denafrips Enyo : Front view
To obtain a high-performance R2R DAC, Denafrips Enyo 15TH uses a network of ultra-precise resistors. Each resistor is rigorously measured and matched by a machine and validated by human intervention.
Denafrips Enyo 15TH uses a fully symmetrical R2R design. Each channel is decoded by 4 sets of R2R networks. This design features very low linear error, high decoding speed and low digital noise, guaranteeing not only low distortion of the audio signal, but also very low background noise, enabling the listener to fully enjoy his or her music. The DAC also provides the user with NOS or OS and Slow or Sharp filters.
Key features:
  • Low-noise power supply
  • FPGA-based digital signal processing
  • Reclocking and adaptive FIFO buffer
  • Supports PCM 1536kHz and DSD1024 streams via USB
  • Proprietary USB audio solution via STM32F446 microcontroller
  • Proprietary USB interface via STM32F446 microcontroller based on AMR technology
  • Pilote USB Thesycon
Product typeBalanced R2R DAC
Inputs1x Coaxial
1x Optical Toslink
1x USB-B
1x I2S
1x Balanced stereo XLR
Supported sampling ratesUSB: PCM up to 1536kHz, DSD up to DSD1024
Optical / Coaxial: PCM up to 24bit 192kHz, DSD up to DSD64 (DoP)
Sampling rate modesNon onversampling (NOS)
Oversampling (OS)
Output impedances / levelsRCA : 625Ω @ 2Vrms
XLR : 1250Ω @ 4Vrms
FiltersSlow
Sharp
Frequency response20Hz - 70Hz (-3dB)
THD+N0.004%
SNR115dB
Dynamic range> 119dB
Crosstalk-124dB
Supply voltage100-240VAC 50/60Hz (selectable voltage)
Consumption≤ 20W
Dimensions230 x 215 x 45mm
Weight3.5kg
Package1x Denafrips Enyo 15th DAC
1x Power supply cable
InputI2S
DAC / ADC ChipR2R LADDER DAC
Max sampling rateDSD1024
Max sampling rate1536kHz
Remote ControlN/A
Un rêve d'audiophile tout simplement!
Quel bonheur de brancher son nouvel appareil, à savoir ce DAC, et rester figé des les premières secondes d'écoute tellement la scène sonore vous transporte. Les artistes sont désormais dans mon salon. Je ne suis pas un spécialiste, simple audiophile amateur, mais ce DAC qui représente un investissement important donne accès à une autre dimension. Merci à Audiophonics!
This review has been posted for DENAFRIPS ENYO 15TH Balanced R2R DAC 24bit 1536kHz DSD1024 Black
The Denafrips Enyo 15TH DAC is an R2R digital-to-analog converter supporting high-resolution audio streams up to PCM 24bit 1536kHz and DSD1024. R2R...
